Question about Kenmore 24032\24036 Top Load Washer
Tub will fill up but won't spin or empty tub.
  • Kenmore Master
  • 8,220 Answers
This washer is a simple design. The motor has a double shaft. One end of it drives the transmission while the other end drives the pump. When it is washing the water cannot escape. In spin mode the motor reverses and the water is tossed out. As you may know manufacturers have installed a lid switch to kill the power to the motor to prevent injury to people. I suspect the lid switch on this washer has failed. I have a video which shows how to replace it:
I wrote a TIp for FY: How it works Direct drive washer
I compiled a page of Direct Drive repair photos HERE
Posted on Jul 06, 2010
  • buysellgb Jan 23, 2011
    DnC Sourcing is to make an Expert of developing products. ---> www.artdnc.com (82) 70-7893-2100)http://www.sourcingbuysell.com
    We have 15 years developing experiences and will implement the advanced products to our customer.
    Electronics, home appliances, sporting goods, medical products, smart phone, General Phones, machine equipment, cattle. Midsize engine
    * Mechanical design, tooling, product design, machine design, reverse engineering (image), product design, MOLD Analysis
    * Processor: AVR series, DSP, FPGA, ARM7, ARM9, etc.
    * Circuit design, PCB ARTWORK Use Program: ORCAD, PADS
    70% Motor Sales ---> www.buysellmotor.net, sourcing everything ->http://www.sourcingbuysell.com
The machine doesn't spin properly and doesn't drain the water
see this causes and fix it. God bless you
Lid Switch Assembly If the washer won't spin the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Motor Coupling If the washer won't spin the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission. Another common problem is the lid switch.
Drive Belt If the washer won't spin, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin properly.
Door Lock Motor and Switch Assembly If the washer spin the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Drive Block If the washer won't spin the drive block might be worn out or may have come loose. Underneath the agitator the drive block connects the inner tub (the one that spins around) to the transmission. If the drive block wears out the transmission shaft will still spin but the tub may not - or it may spin slowly. This also usually causes a lot of noise. The drive block is relatively easy to replace.
Clutch Assembly If the washer won't spin, the clutch assembly might be worn out. The clutch assembly makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may prevent the tub from spinning. The clutch is not repairable, if it is loud or not working properly it will need to be replaced.
Clutch Band kit If the washer won't spin, the clutch band kit might be worn out. The clutch makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may prevent the tub from spinning. If the washer won't spin, this clutch band kit may need to be replaced.
Drive Motor If the washer won't spin the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged It will have to be replaced.
Tub Bearing If the washer won't spin the tub bearing might have seized. This is a common problem and relatively easy to replace.
Tub Seal and Bearing Kit If the washer won't spin the tub seal and bearing might have seized. This is a common problem and relatively easy to replace.
Bearing If the washer won't spin the bearing might have seized. This is not common. The bearing doesn't require any normal maintenance. They generally go bad when the tub seal fails and allows water to leak past into the bearing.
Basket Drive If the washer won't spin the basket drive clutch might be worn out. The basket drive sits on top of the transmission and engages with the inner tub. If the basket drive wears out the tub won't spin.
Basket Drive Hub Kit If the washer won't spin the basket drive hub might be worn out. The hub is a set of plastic gears underneath the agitator. The basket drive hub kit is easy to replace with standard hand tools.
Transmission If the washer won't spin the transmission might be worn out or defective. There are numerous more likely causes when a washer won't spin, which should be checked first.
Sep 28, 2012 | Hotpoint Washing Machines
How do you find something stuck between the tubs
Does it fill and wash, but just won't spin the clothes out? If so, you will need to replace the lid switch.
May 23, 2012 | Maytag PAV2300 Top Load Washer
Fills with water, drains, will not spin. sometimes will not fill
This is almost certainly the filter to the empty pump blocked. When you power up the machine, the first thing it does is make sure there is no water left over in the tub, if it can't evacuate any water it finds there, it won't go any further. Same on a spin, if after a set time the water hasn't emptied the empty cycle will stop but the spine cycle wont start because there is still water in the drum.
Locate and clean your empty pump filter.
Jun 29, 2011 | GE Washing Machines
Will not fill with water but works on spin cycle
If your washer won't fill with water, but works in the spin cycle then the washer is sensing that water is in the tub. If there isn't water in the tub, then it is probably a sensor. If there is water but the spin cycle doesn't get it out, then look at the pump or control board.
Jun 08, 2011 | Maytag Washing Machines
Agitator won,t work tub will fill, and empty but won't spin and agitator won't work
Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Dec 01, 2010 | KitchenAid Washing Machines
Series 70 washer will not aggitate, spin or drain
Even "empty" - there is still water in the tub to keep the seals moist.
Let it thaw completely - or put some hot water in the tub to thaw.
You may already have damaged the coupling/drive belt if it was frozen.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 18, 2009 | Kenmore 20722
Neptune washer tangles all cloths
the washer has a balance ring that hold water that is ok. as of the tangleing you may have a low water fill
Nov 24, 2008 | Maytag Neptune MAH5500B Front Load Washer
Frigidaire GLET1142CS0 washer wont spin
I Changed the TUB belt and now it spins.
Jun 10, 2008 | Washing Machines
Kenmore 24032\24036 Top Load Washer Logo
395 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
