Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
I want to know how to configure this router
I just want to know how to configure so i can use on my wifi devices its all hooked up right now what do i do mine didnt come with any driver software where can i find then what do i do thank you four any help offered
    Champion:
  • 200 Answers
Go to belkins website and download the driver for the wreless G plus MIMO the router does not require a router it has firmware
Posted on Jul 06, 2010
Does wifi require a router? What is the difference between a router and a cable modem? I have activated a network connection, but I don't know how to activate wifi to use my browsers.
Modem- connects to incoming cable or phone line, it creates a connection between the internet your computer or other internet using items.
Router- splits up the connection to the internet to share it with multiple computers, TV's, cell phones, ect. Can be wired or wireless (wifi)
Wifi- wireless connection, it's always a router too because multiple devices work with it.
Now here's the confusing part, you can get any combination in one modem.
Cable modem, no router, no wifi, just hooks up to one wired device.
Cable modem, with router, no wifi, usually can hook up to 4 wired devices.
Cable modem, with router, with wifi, can have 1 to 4 wired devices and has wifi which can connect to hundreds of devices.
You can also get Cable modems with phone connections they use the internet service to connect to the phone system.
To activate the wifi, you usually need one computer to change the settings to set a name and password for your wifi. Then all your other devices will have to be connected to that named signal and use that password to set them up.
Nov 12, 2016 | Computers & Internet
I cant get wifi and internet on my computer at the same time
Hi. Let's hava look at what you are doing.
I'm guessing that you have a cable modem a dlink router with wifi and a computer, right?
If you connect the cable modem to the computer you have internet. You shouild also have wfi but the wifi will not give you internet because it is disconnected from the modem.
The Dlink has to be connected to the modem but it will also need to be configured. To *** that you will need help from your cable company.
The connections should be. Modem connected to the outside world. Dlink connected to the Modem. Computer connected to the Dlink by either wifi or Ethernet.
Feb 28, 2012 | D-Link RangeBooster G WBR-2310 Wireless...
No wifi available device missing
You own the router? Have you know its configuration? Can you log on the device pluged in by wire?
Run the software setup that comes with the device and go through all the configuration parameters, then disconnect and verify WIFI is turned on on your computer. Copy the information (encryption Key) using a USB pendrive from the information in the router configuration *you did save this?) to the key required to connect by wireless... it will ask for it!
Sep 12, 2011 | Computers & Internet
How do i find my router or wpa on a acer aspire one thanks
Your router is a separate hardware
its the device that allows you to have internet
usually a small box, the wpa should be there on the router thats a password to access the
wifi network, if its not on a sticker call your service provider and also verify that your router has wifi
May 04, 2011 | Computers & Internet
I just hooked up the wrt120n to my desktop and have the configuration working for it but my ipod touch 4g can't get on wifi. How to I fix this?
Have you tried to go into the wireless section? what I suggest go into your router, and go into your wireless selection. There is connect manually or wifi protected set up,. go ahead and select the wi fi set up option,. You can then enter your pin number from said device, or if your device has a search option or a wifi protected button hit that as well as the icon inside the router menu they should synch. Hope that gives you what you need
Feb 03, 2011 | Linksys WRT160N Wireless Router
Just bought a ASUS 1015 peb netbook- also have a phone router with iwi-fi-cannot figure out how to connect it to the netbook
if you have a built in wifi adapter, open your network connections icon in the control panel with a right click and send a short cut to your desk top, youll probably be using this short cut a couple of times. then left double click on the desk top network connections icon to open it.you should see all the devices in use on your laptop including your wifi adapter if you have one. right click on your wifi adapter, it should have a red x thru it. scoll to properties at the bottom, click on it it will open up the wireless properties. if windows is configuring your adapter youll see a connections tab in the center, click that and the big box at the bottom youll see a add button. click that add your wifi routers info there. if theres no connections tab go to programs and locate the utility for your wifi adaptor because your utility is controlling the wifi. open the utility, add the wifi router info as before when related to windows configuration. you should be good to go.
Jan 22, 2011 | ASUS Computers & Internet
Cant connect to wifi
Please tell what is your Wi-Fi LED status. what channel count you configured inside the configuration of router. Please be sure that your wi-fi signal is transmitting or the device is able to receive the wi-fi signal.And please tell what router you using as host and what device you using as receiver. Thanks for subscribing Fixya... All the best
Nov 15, 2009 | Computers & Internet
Wifi not connecting correctly
Windows WiFi Fix,
Windows Zero Wireless Configuration is one of the best programs to run a WiFi in Windows XP or Vista. Most of the other software packages that come with the different adapters have been poor at best in keeping a connection through Windows. Here is the best guide to get you back up and connected.
Windows XP:
Click Start
Right click on My Computer
When a window pops up click on properties
Click on the Hardware tab
Click Device Manager
Click the [+] next to Network Adapters
Find your wireless card and right click on it.
Click Disable
Windows may warn you that disabling the device may make it stop functioning.
Continue disabling the device.
Wait 30 seconds or so.
Right click on your wireless again and click Enable.
Exit the device manager.
Reconnect to your router.
You should now be able to connect to the internet.
Windows Vista:
Click Start Logo
Right Click Computer
Windows will ask you about opening Device Manager Click Continue
Click Disable
Sep 28, 2009 | Compaq Presario 700 470024-192 Notebook
So i have my desktop set up online, but i want to get my laptop hooked up as well and i have a router. how do i hook that up to?
On the right bottom corner of your screen, you should see a message/icon about wireless networks.
Select the icon and you should see a list of wireless networks. Select your network, add your password (if you set up a password) and you should be connected.
Open your browser.
Hope this helps.
Sep 08, 2009 | NetGear WGR614 Wireless Router
Can't Access Web configuraton for Cnet CWR-854 Wifi router
Have you try to update the firmware by any chance?
Let me know
comier957
Aug 10, 2008 | Cnet CWR-854 Router
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
99 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
