Question about Mag Innovision InnoVision XJ 717 Monitor
Sony Videoscope XBR tv
I am getting double images, with outlines of color.
  • memazza Apr 18, 2008
    Yes: kp-53XBR200 thank you!
  • chichicharly Jul 30, 2008
    I to have a sony videoscope XBR tv but the problem is the volume. There is no volume. I have followed the manual but the option or feature that it wants me to do is not available. What do I do?
My 14 month old sony xbr 4 is not working right, 2 month out of warranty looking at a thousand $ repair, 2700.00 $ paid for 14 month use, I am very upset.
Right half of picture is darkish with dark red discoloration,left side picture is o.k. When I hit the tv lightly on the back at right side the picture goes back to normal for short while.Repairmen took out part and "repaired" power inverter, Tv was o.k. for a few hours, then the old problem startet up again.He said he needed to get avery expensive part to fix tv. Please HELP. Gloria I.
Posted on Jun 02, 2009
I have the same problerm with a 61 inch sony it is a VideoScopexbr. What do you need of the TV to know how to fix or just send me in the right derection to get it fixed. I hope to hear back from you.
Posted on Jul 30, 2008
  • 4,234 Answers
This is usually a convergence problem.. Could you update this with the model number please. That will allow me to give you some specifics about what could be wrong and how to fix it.
Dan
Posted on Apr 18, 2008
Sony videoscope xbr
would think you need to replace the cable board etc. the signal is not getting in and out right. can also be a fault on the power board giving the wrong volts so would check this to. it will tell you on the board what volts is supposed to be. the 5v and 12v should be spot on other volts will vary a little. also check the capacitors for the caps to be bowed up and a brown/ yellow gunk around them and under the board this can be a sign they are failing.
Feb 25, 2014 | Televison & Video
My sony videoscope XBR tv has a pink picture and no control. Also nothing is in enlish.
the model listed is a very old set---parts may not be available----language can be selected in the menu but the pink may be a adjustment of the screens (controls) or a circuit problem.
Aug 26, 2012 | Sony KP-53XBR45 53" Rear Projection...
Sony videoscope XBR colors completely messed up how can I fix this?
Its a very old set if that is on it, what is model number?
Apr 17, 2012 | Sony Televison & Video
Can't turn off pip on sony XBR videoscope TV
Look on your TV remote and press the button clearly labled PIP or Picture-In-Picture and press that button over and over. It will cycle through all the PIP modes until it turns it off!
May 02, 2011 | Televison & Video
Sony videoscope XBR - Side by Side screens can't change it back.
Sounds like your TV has a PIP (picture in picture) that allows your AVI (audio visual input) to be viewed simultaneously with your cable input. Check the manual for the correct buttons, but the one you're looking for says either PIP or AVI or something along those lines. Hope this helps
Jun 11, 2009 | Mag Innovision InnoVision XJ 717 Monitor
TV has sound no picture, Sony Videoscope xbr
Please post both the exact model number (on the back) and the blink count. The standby light should be blinking a repeated pattern. That info will indicate the problem circuit and allow us to provide you with the proper parts/steps to resolve this.
Thanks,
Dan
Feb 10, 2009 | Sony KP-53XBR45 53" Rear Projection...
Sony Videoscope XBR 53
This is a convergence problem. Look in the back for a couple of large black ICs attached to a heatsnik. These should be marked STKxxx. These are the convergence ICs and either have bad connections or are defective. If you can solder, try resoldering the pins on these ICs. If that fails to resolve the problem, replace the ICs. There may be other parts that need to be replaced as well. I'll look up your model to find the other parts to check. The convergence board as an assembly, I believe, is no longer available. The parts that you require are available.
Dan
Sep 18, 2008 | Televison & Video
Sony Videoscope XBR TV
just need to balance the three colors red,green and blue that may help remove the front covers and look for black module that have sccree and focus controls just move a little bet left or right be carefull because you can loos the picture e-mail me for more info
Apr 07, 2008 | Sony KP-53XBR45 53" Rear Projection...
PIP won't turn off
I pressed "Demo" on the front of my TV and it worked, I have an old Sony KP-53XBR35 VIDEOSCOPE XBR - no original remote and the Universal remote has PIP button but would not shut it off.
Finally it's off!!!!
Jan 23, 2007 | Sony KV-35V35 TV
Mag Innovision InnoVision XJ 717 Monitor Logo
793 people viewed this question
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Rommel Balcita
Tony
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
