Question about Thermasol Steam Bath Generators - Ambiance Pro - AMBPRO
Light flashing no steam
Unit noit working, timer light flashing, not energizing unit
    Problem Solver:
  • 7 Answers
Please call Thermasol tech support at 800-776-0711 and our techs will gladly help you out.
Posted on Aug 24, 2010
Why does my Energizer CHVCM3 battery charger flash green lights with four batteries in it
The manual says it will be green when the batteries are placed in charger correctly. It has an automatic charge timer an shuts down.
May 03, 2017 | Energizer Electronics - Others
Fujitsu asta24 Lcc timer light flashing all the time even when off no cool air coming thru
A continuous blinking timer light is a "model error" meaning the indoor and outdoor unit is mismatched. If the timer light flashes a number of times, pauses, then repeats, count the number of flashes and then you can work out the error code.
Nov 17, 2016 | Fujitsu Heating & Cooling
MY FIJITSU inverter is not working correctly, the timer light is flashing continuously and the timer lights flashes 5 times can anyone help pleawe
fujitsu is a good brand.
try one of these two things:
Turn the unit off then on again. After that press test button on remote control (rear side) and look how many times now operation and timer LED flashes. Note that. Then press MANUAL/AUTO button on indoor unit until you hear 3 beeps from buzzer. That will erase error memory.
Switch off and than on unit and see if indication repeat or it is gone. If it is gone, keep using your unit.
If it is repeated post your notes here.
OR+++++++++++++++++++++FOR OTHER MODELS
5 x Operation flash and a constant Timer flash indicates an outdoor unit control error. With this code flashing on the indoor unit, you need to point the remote at the unit and push the test run button. The flash pattern will change to a continuously flashing Operation light and a number of flashes of the timer light which gives more detail on what the error is.
To get the unit to try to restart you need to push and hold the manual/auto button on the indoor unit for a few seconds then reset the mains power supply but leave it off for a minute or so for the unit to power down completely. If you are going to try this make sure you make a note of any error codes first if you have to get someone out to look at it, it will help them a lot.
Jan 05, 2015 | Inverter Heating & Cooling
Technika lcd 32-207 television powers up but will noit come on blkue light keeps flashing
Hello.
if the blue lights keep flashing you have shorted parts inside. usually the inverter board have a shorted IC, try to remove the connector from inverter then try again..
if your blue lights lit replace the inverter which you disconnect.
Dec 06, 2012 | Televison & Video
Iam using Energizer 15min charger. I have used for a longer time. Now the charger red light blinks while trying to re-charge batteries. I have tried various batteries but red light blinks. Failed to charge...
A flashing light indicates that the charger seems to detect a problem with the cells. (two or more cells form a battery). Since you've tried other cells, it can be reasonably assumed that the charger is faulty and should be replaced.
Feb 14, 2011 | Energizer 15 Minute Battery Charger Combo...
Air con not working. Operation and timer lights flashing, then operation light flashes and then lights go off. Air con is blowing air but the outside unit is not blowing any air.
First check your timer on and off. If you want to reset, remove batteries from remote and power off to unit. Reset it. Now run the unit. Set temp mode once again in your remote and wait for 3 minutes. If still out door unit not working, check power line to out door unit.
Dec 31, 2010 | Fujitsu Heating & Cooling
I have a Mr. Steam unit installed in my shower room. When i turn the steamer on it sounds like it is working and the lights are on but no steam coming through!!
Hi I am with Mr. Steam Tech Support please call 1-800-767-8326 and ask for tech support we will also need you model and SN that are located on your steam unit
Nov 27, 2010 | Mr Steam Hardware & Accessories
Energizer 15 minute Ni-MH Battery charger
A flashing red light indicates that there's an error, or the batteries are defective.
No, the unit won't switch itself off once the batteries have been fully charged. The unit will start trickle charging instead.
Dec 24, 2008 | Energizer 15 Minute Battery Charger Combo...
Mr. Steam CU-750 not working
Try replacing the safety valve or look at your pressure controls which may be clogged.
Dec 01, 2008 | Mr Steam Mr. Steam Commercial Steambath...
Swan steam station S12010
i have a steam station , the stand-by light keeps flashing on and off, how do i reset it, there is no steam comin thriugh at all, please help.......thank you xx
Oct 14, 2008 | Irons
Thermasol Steam Bath Generators - Ambiance Pro - AMBPRO  Logo
646 people viewed this question
Top Thermasol Electrical Supplies Experts
Steve
Gene Haynes
Are you a Thermasol Electrical Supply Expert? Answer questions, earn points and help others
