Its not very hard in this particular model. You simple need to access it from menu ->Setup-> Convergence. In convergence you will have 3 options. 1)Auto convergence 2)Red(red should be aligned with green as green is usually the reference point). 3)Blue should be aligned with red and green.
Controls: Use arrow keys to move the cross hairs and enter to save the settings. Once you are done exit the menu and the settings will be saved. If problem persists I am afraid you may need to replace the STK Ics and I can guide you with that if necessary.
To get the code to enter on your remote to engage multipoint convergence adjustments, you need to contact the rca customer care for that, you get them your model number and they will get your code for you.
To process and save the adjustment made, follow the steps below;
Take care
Problem with Hitachi 51F500 51 in. Rear Projection HDTV-Ready Television
i want to learn how to do convergence on my tv its a hitachi rear projection i have problums with colors not aligning,could you lead me in the right direction ps: i don't have the remote so i
can't magic focus
Posted by ejaparks on Mar 03, 2011
www.graysoncollinapplianceandac.comResidential/ Commercial, all brands Friendly, knowledgable technicians!
Get $75 of Advertising
www.Google.com/AdWordsPromote Your Business On Google. Claim Your $75 Coupon Now!
Solutions (1)
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Here is an example photo....
Need code to enter on remote to enter covergence mode to adjust multipoints,switch from red to blue,save adjustments,and how to exit,RCA Projection TV Model # HD52W59.
