Question about MSI K9VGM-V Motherboard
Don't have manual and I am not sure how to connect the power switch, reset switch, power LED and HDD LED
  • 93 Answers
If you do not have the manual it's here.
http://www.msi.com/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=260
those leads go on pins that are together usually by one edge of the board.They are hard to see but are marked.you should be able to see the reset and power switch quite clearly and if the leads are not lablelled then trace them back to the small reset switch and the power on switch
Posted on Jul 06, 2010
  • 45 Answers
Motherboard User Manual For SiS965L?
SiS965L is a chipset designation, not a motherboard model number. That said, most motherboards do label the header pins for the front panel connections on the motherboard, though they are a bit small and sometimes are not adjacent to the pins themselves. The Power Switch and Reset Switch pins are not polarized, and when you determine which they are, the connector plug can be installed on them either way. The Power LED and HDD LEDs ARE polarized. The positive pin is marked with a "+" sign and the Green wore of the Power LED and the Red wire of the HDD LED must be on the "+" terminal.
Nov 09, 2015 | Computers & Internet
FX58M powerSW
thank to answer.
@Jorico no threr is nothing wrote on the mobo (expt fp1)
Aug 19, 2012 | Computers & Internet
Where doe's power led,power sw,hdd led on my e-machine
You will need the user's manual for your machine to make sure that you are hooking the wires up correctly. However, most motherboards label these connections directly on the motherboard next to their pins.
Look for an area on the mother motherboard with two rows of six to eight pins. Next to them you should labels such as PWR_SW (power switch), RST_SW (reset switch), HDD_LED, PWR_LED, etc. You won't mess anything up connecting something to the wrong pins, but it isn't that hard to figure out as the wires are usually labeled in the same manner as the pins. So HDD_LED would plug into the HDD_LED pins, PWR_SW to PWR_SW, etc.
Jun 30, 2012 | E-Machines Computers & Internet
Wiring motherboard to a atx tower
The motherboard manual will give you a breakdown of the cast-to-motherboard connections for the board. They differ slightly from board to board, but the connections are almost always found at the bottom front corner of the motherboard. There will be connections for the hard drive LED, the power LED, the power switch, the reset switch, and on some, the speaker (optional). The power switch and the reset switch connectors , 2-pin plugs, are not polarized, meaning that they can be connected to their pins either way without issue. The Power and HDD LED plugs are polarized, as LEDs have a positive and negative. Get this plug backward and the LED won't work. These are also 2-pin plugs. The power LED usually has a green and white wire (Green is +) and the HDD is usually red and white (Red is +) . Some motherboards have color-coded pins -- DO NOT TRUST THEM IF YOU DON'T HAVE A MANUAL -- they are not always standardized. Some motherboards have small print on the board adjacent to the pins to identify them. You CAN trust these. Otherwise, go to the Motherboard manufacturers site and get the manual for the board. The model number is on the board and can be searched for. If the manufacturer's name is not obvious, Google the model number and it will usually lead you to the manufacturer.
Dec 17, 2011 | Intel Motherboard
I have asrock agp8x p4i65g and don`t know how connect fron power/reset buttons and fron lights. There`re 5 lines power sw, reset sw, H.D.D. led and 2 ampty
yea there are 5 lines one is power switch other is reset the power led then hdd led then in older motherboard there is provision for speaker The power switch is in the front pannel of the motherboard if you have multitester the power which will indicate 5v the power switch is to be conected to the 5v and the ground normally the front pannels details will be given in the motherboard
Mar 28, 2011 | Computers & Internet
Where can i get pyramid-9 PCB No BA41-00167A manual book for setting up power switch,hdd led,reset etc connection setting ???????????
Hello, i was made a search in google, i guess you must look it too, and a don't get nothing, but, I think i've a solution for you, according my own experience, i've installed 2 kinds of different MB, and, althoug there are different brands, the connection pins are the same, ie, the front panel connector that connect HDD Led, Power Led, Reset and Power, is a 9 pin conectors (really have 10, but 1 pin is cut for reference) and commonly is called PANEL 1
Then, i guide you
2 8
. . . . this will be 2,4,6 and 8 pins (from left to right)
. . . . . this will be 1,3,5,7 and 9 pins
1 9
Power Led + in pin 2
Power Led - in pin 4
Power Button # or + in pin 6 (It's no critic the orientation, it have no polarity, is a push buttom)
Power Button GND or - in pin 8
HDD Led + in pin 1
HDD Led - in pin 3
GND from Reset Buttom in pin 5
# from Reset Buttom in pin 7
THE PIN 9 has no connection
Source: My own experience, and check this instalation manual, at 21st Page
http://download.asrock.com/manual/Wolfdale1333-D667%20R2.0.pdf
Jan 07, 2011 | EPoX EP-3PTA Motherboard
About MSI K8N Neo4
http://www.fixya.com/support/p298028-msi_k8n_neo4_f_motherboard/manual-15408
Sep 14, 2009 | MSI K8N Neo4-F Motherboard
Lookig for a manual for an fic au13 motherboard
Front Panel Block Cable Connections
f_Panel
1 3 5 7 9
2 4 6 8
1] HDD-LED (+)
2] Dual Power-LED* (+)
3] HDD-LED (+)
4] Dual Power-LED* (-)
5] Reset Switch
6] Power Switch
7] Reset Switch
8] Power Switch
9] Dual Power-LED* (**)
* Single Color Power-LED 2 or 3 pins:
1 2 3
1]Power-LED (+)
2] GND
3] GND
** Dual Power-LED:
if useing dual power LED,
Green: pin2
Yellow: pin4
otherwise, Pin2 is positive (+) Pin4 is negative (-
For future Reference you can download your manual directly from the manufacturer's website HERE
Or directly from HERE
May 30, 2009 | FIC AU13 Chameleon Motherboard
Connecting the case to my motherboard
Pin arrangment is Industry Standard Architecture.....
pwr led pwr sw N/C
X X X X O
X X X X O
hdd rst N/C
translated this is top row left to right ...... power led, power switch no connection
Bottom row is left to right........ hard drive, reset, no connection
Note: not all computer cases have a reset button, also the connectors for power led and hard drive produce a light, if the light does not show, power off the pc swithc the cable rooun 180deg on the connector pins and reconnect.
Dec 04, 2008 | Computers & Internet
Help me on how to connect my samsung motherboard!
Power>Red & white
Reset>Purple & white
HDD Led>Green+
HDD Led>White-
HDD Tx>Yellow & white
Select each pin & correspond with block on FSB M/B panel
Jan 17, 2008 | Computers & Internet
MSI K9VGM-V Motherboard Logo
348 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
