Question about Dell 3300MP Multimedia Projector
Dell 3300mp projector makes a very loud buzzing sound-dispay indicating bulb failure.I bought new bulb that works but loud buzzing sound persists.All the fans work good-sound source seems to originate near the lamp-lens area
  • tonash25 Jul 07, 2010
    dell 3300mp makes a very loud buzzing sound-the whole projector vibrates.Receive advice but not comfortable with this procedure-could it be the color wheel malfunctioning?--bulb works,image shows on screen but is very blurring due to vibration
    Guru:
  • Dell Master
  • 468 Answers
Try Power cycling by removing and inserting the power cord may fix the problem for now.
Posted on Jul 07, 2010
  • 677 Answers
Well here is a partial solution. Turn off Dynamic Iris and the noise will go away. Now could someone tell me how to fix the Dynamic Iris?
Turning off Auto Iris helps but it can still make noise. Disabling the mechanism by unplugging it will eliminate the noise and the Iris should open fully when unplugged. So this is a fix for the noise, not the Iris. Remove the Shift Lever that adjust the lens direction (unscrew and pull). Remove the filter on the right side. Remove six screws marked with arrow on the bottom. Remove one screw marked with arrow on the rear. Remove the top cover. On the front side of the main board locate the third connector from the left with eight blue wires and one white. Disconnect this connector. Reassemble projector.
Posted on Jul 06, 2010
I have dell 3300mp,when I turn the power on it makes a very loud noise. It does not make the sound in standby or cool down. It does work and display a signal okay, but it is very loud. Sound like a fan?,...
The main fan that cools the lamp is mostly high speed when the unit is running. when it shuts down it slows the fan down, until it stops in standby. So the noise is only really loud when it is showing a picture.
try setting the fan to eco mode (slower running) and see if the noise is acceptable. If it is still too loud then you will have to replace it. Have a look at the fan and see if any of the plastic blades are missing.
Mar 26, 2011 | Dell 3300MP Multimedia Projector
I have a dell 3300mp projector hooked up to a dvd player and I cannot get any sound. What do I do?
sound form your projector? or from your speakers? set the volume of your projector to maximum. then check your connection cables if good your speakers if working. check all your component have pwoer supply.
Oct 28, 2009 | Dell 3300MP Multimedia Projector
Dell 3300mp Projector Loud Noise
Judging by the mains hum noise and now shaking it sounds as if a motorized component has broken.
Humming could have been the initial jam, then shaking the damaged part attempting to rotate.
Maybe check your cooling fan blades?
Dec 02, 2017 | Dell 3300MP Multimedia Projector
Dell 3300MP
How old is your unit and or how many hours are on the lamp?
As the lamps age they run hotter and it could need replacing.
If so, buy just the bulb instead of the lamp assy and install it yourself.
Dec 31, 2007 | Dell 3300MP Multimedia Projector
Dell 3300MP Projector
my advise is to get a new one or try ebay - i got my dell 3300mp NEW in box for under $400 - and have looked at other projectors there are very good deals on ebay but make sure you read the entire listing
Sep 13, 2007 | Dell 3300MP Multimedia Projector
New lamp/ LAMP FAILURE
how did you get the cover off and was it the top or bottom cover?
Aug 21, 2007 | Dell 3300MP Multimedia Projector
No lit / projected image even with a new bulb!
Let me add...
I had one 3300MP and removed/replaced the bulb to dust off as it was overheating. There is a small metal like switch that resets the bulb replacement (physical switch - take a good look) -- This helped to reset the first time I did this, but doesn't reset the hours on the chip.
However, since this bulb was problematic for me, I have done this a couple of times and since has stopped powering the bulb now. So, thinking it was the bulb, I replaced the bulb, -- No good... So, thinking it was the projector, I bought a new/refurbished one on ebay -- tested the NEW bulb - NO GOOD. now I have TWO PROJECTORS, THREE BULBS and NOTHING THAT WORKS...
WHAT AM I DOING WRONG?
Apr 27, 2007 | Dell 3300MP Multimedia Projector
Dell 3300MP Multimedia Projector Logo
526 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
