Solution #1
posted on Apr 18, 2008
please check the following:-1-toner stiring roller in toner box is stucked and did not move to mix and supply toner-get toner box out and empty it from toner and clean it with air blower and check the condition of roller clean and lubricat the bearing carrying the roller-check toner motor is pluged firmly in its socket-go to rear frame and check toner selonid is working and in good condition-check gears that drive toner roller in good condition.
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To:
HP 280 Copier
Panasonic DP-C213 Color Copier
Panasonic Workio DP-150PA Copier
Panasonic Workio DP-2000P Grayscale Copier
Panasonic Workio DP-3530 Grayscale Copier
Panasonic DP-3030 Grayscale Copier
Panasonic DP-C322 Copier
Can you Help with these Copiers problems?
Repair Service
Find Copier Repairman Near You:
