We have roadrunner internet and are trying to hook our WII console up we are going from the internet modem into a 5-port 10/100 fast ethernet switch and from there we are going through a usb to 10/100 mbps adapter into the wii console . everytime we try we get an error code; 51420 . what are we doing wrong ?
Error
Code: 51420
The Wii console is
not able to connect to your wired router or modem.
Wii generate lot of network errors ........ so don't worry, youcan solve this easily ..... i got some problem with my wii and its resolved bythe help of Repair Guide
it covers network problems thoroughly so checkthis out !!
it will definitely helps you CLICKHERE
The Wii console is not able to connect to your wired router or modem.
1. If your connection worked previously, check to see if there is a Wii System Update that you have not aquired. To get the latest Wii System Update:
From the Wii's main menu, select the Wii icon along the bottom left of the screen.
Select "Wii Settings".
Click the left arrow to get to Wii System Settings 3
Choose "Wii System Update"
Choose "Yes" to connect to the internet and perform a Wii system update.
2. Make sure that you are using the Wii LAN Adapter made by Nintendo (click here for a picture and connection steps). LAN adapters not made by Nintendo likely will not work with the Wii console.
3. Check to make sure you are not running the Wii LAN Adapter from a USB hub (a device that connects multiple USB products through a single device), as this will likely not work. Connect the USB Connector directly to the modem or router.
4. Ensure that the Wii LAN Adapter setup is correct, and that the Wii LAN Adapter was connected with the console turned off. For step by step connection instructions, please click here.
5. Check to see if the ethernet cable you are using is not working properly, by connecting another ethernet cable from your router/modem to the Wii LAN Adapter. If the connection works using a different cable, then the problem was with the first cable.
6. If possible, try another Wii LAN Adapter. If you are unable to try another Wii LAN Adapter, or are still receiving this error code, please call 1-800-255-3700 for assistance.
For any help click here
