Question about Whirlpool Refrigerators
Whirlpool AFG 8241 NF Freezer. When we first got it, it did not seem to take long to cool down to -18. But now temperature seems to take a long time to recover from door being opened. Example: freezer nearly full and temperature -17. Put in three loaves of bread. Shortly afterwards temperature was -12. Set the fast freeze overnight but even by this midday today temperature is only -16.
  • 1462 Answers
SOURCE: cannot open the bottom freezer door anymore; it seems stuck
sounds as though the defrost system has failed or the freezer defrost drain is blocked. take off the back panel of the freezer and see if excess ice build up. if so, defrost carefully with a hairdryer. at bottom is a drain. check if blocked with ice and if so melt off with hot water till water flows away freely. if i'm right, appliance will start to work. if fault re-occure then defrost system is at fault
Posted on May 06, 2007
  • 1314 Answers
SOURCE: Temperature variation in freezer on Whirlpool ED22TQFXN
need your model number for unit reply but dont rare me till we are done get model num off serial plate in fridge
Posted on Jan 02, 2008
22yooper
  • 828 Answers
SOURCE: ffa70 hotpoint fridge freezer
Adjust the temperature control for the freezer to a normal setting. Fast freeze is only for when new products are put in that need to be frozen. This locks the system into a continuous run mode and could be responsible for the freezing condition in the refrigerator section. Check the temperatures with a thermometer as the sensor for the freezer temperature could be bad causing the light to come on.
Posted on May 18, 2008
blueextc3221
  • 15935 Answers
SOURCE: Freezer does not freeze fast enough, icecream gets soft
Faulty Cold control (Temperature Control)
The cold control is a temperature actuated switch and should open when the set temperature has been achieved. If the control does not open and turn the compressor off, it will continue to run and all items in the fresh food section will begin to freeze.
If the control is not closing, the compressor and all fans will cease to operate. Check the control for continuity.
This is usually not a do it your selfer.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Apr 25, 2009
heatman101
  • 43501 Answers
SOURCE: FREEZER TOO COLD - REFRIGERATOR TOO WARM
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on May 25, 2010
Kenmore freezer won't reach freezing temperature
When the compressor gets worn it loses it's ability to cool. 18 years is a long time for a fridge. The last fridge that did this to me, I paid the appliance guy $20 to tell me it was broke (I knew that part). Then he told me it wasn't worth the money to repair it and to buy a new one. Time for a new fridge.
Nov 27, 2013 | Refrigerators
Whirlpool freezer AFG 8060 indicates red light and sounds alarm. Temp always held at -16 to -20, though now indicates only -1.
Please check : - Your door for small leak ( gasket / seals) - Temperature sensor for malfunction. A failed sensor will show wrong data.
Regards,
Dec 04, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
It seems the my freezer is not cooling down. When I set it up, as the instructed by the freezer manual, I turned the temperature setting to level 4. Then after waiting 24 hours, I adjusted the setting to...
I would unplug it and leave it set level. When you tilt it some of the oil in the compressor can get up into the upper pare. in some cases if the motor can't move it will either burn up or burn out the starting capacitor or coil. Plug it in again the next day and see what happens. Small freezers may take a long time to cool down and they need something in them to cool. Put pans of water or something in it and see if it will get cold enough to freeze them
Sep 21, 2010 | Haier 3.5 cu. ft. Chest Freezer HNCM035E
Whirlpool frig. Freezer warm, frig seems ok.
Since the temperature is already 40°, the cold control is satisfied and will not run. Thus the freezer will warm up to 40°.
Jan 06, 2010 | Refrigerators
Whirlpool 6 sense model WSC5513- A+ X side by side, without ice or water dispenser. Refrigerator part not cooling properly. Temperature setting is -18 degrees Celsius for the freezer and 2 degrees...
The temp for the fridge is about right and -18 for the freezer is ok so check to see if the water filter is plugged, at 8 degrees Celsius is about 18 degrees fht. Which is freezing so the numbers don't add up. 26 degrees below zero on the freezer side is what you want if it that cold it could have frozen the water line.
Aug 20, 2009 | Refrigerators
S20b rsb21 whirlpool
Your freezer section has a defrost system problem. A device (Timer) schedules defrosts, energizes electric heaters which melt the frost, when the temperature of the coil gets above the point where all ice is melted a thermostat opens cutting the electrical circuit for the heater(s). The defrost cycle continues until the time expires (18-22 minutes). Therefore your problem could be any one of the three elements. Timer, heater, or thermostat.
May 29, 2008 | Refrigerators
Philips whirlpool AFG 027 freezer
The orange button is the "turbo boost" - for reduzing the temperature the fast way. Mostly used when first time use or you put in a lot of unfrozen things at once. When reaching optimal temperture it goes off automatically. The red one is the alert button. Not sure about the green one. Under normal conditions none of the lights is on.
Apr 02, 2008 | Freezers
Temperature Control
check if that condenser's dirty first. i suspect that... try that first
Dec 23, 2007 | Freezers
Whirlpool AFG 7080 Freezer - Relay noises
It sure sounds like you have a problem with the board. It may just be a dry joint or a faulty component. Normally one would replace the board.
Nov 01, 2007 | Freezers
Refrigerators Logo
88 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
