Question about Sony PlayStation Portable (PSP) Console
Psp when turned on has no picture or sound - Sony PlayStation Portable (PSP) Console
  • 677 Answers
Hi, when a psp player has no sound, It might be from the speaker inside the psp or the sound IC that is damaged.
You open the psp and useameter or a battery to read if the speakers inside are working.
If the speaker are working,that means the sound IC has to be replaced.
Take care,
Posted on Jul 06, 2010
  • ikechukwu joshua
    ikechukwu joshua Jul 06, 2010
    If you are experiencing a problem with the volume on your Sony PSP
    device, there are a number of factors that may be contributing to the
    issue. It could be a problem with the hardware, or something as simple
    as a button accidentally left on while playing. Fixing the problem with
    your PSP volume is relatively easy in most cases, and after a few minor
    tweaks, you'll be back to playing your PSP at full volume in no time.
    Check the mute settings. Clear any current sound settings by pressing
    the audio button on the face of your PSP. Test to see if this solved
    your problem.
    Test to see if you accidentally turned the volume all the way down by
    raising the volume level and checking the sound quality.
    Remove headphones from the headphone jack. Having your headphones
    plugged into the device will prohibit sound from coming out of the
    actual speakers.
    Make sure the AVLS (automatic volume limiter system) is turned off. The
    AVLS is a safety precaution that limits the amount of sound that can
    come through headphones and speakers and may severely cut back on the
    sound quality when turned on.
    Disconnect and reconnect your memory stick. Sometimes when the memory
    stick is not fully connected, it can interfere with volume and game
    quality.
    Check whether or not your device is connected to a video output cable.
    In the event that you are connected to video output, you need to control
    the volume from the video device you are playing through.
    ry resetting your game system. Make sure you remove games and save
    devices before doing this to avoid erasing your saved settings. Remove
    the battery pack from the back of the PSP device. Hold in the start
    button for five seconds while the battery is out then replace the batter
    and restart your PSP. Test your volume to see if it's been restored.
    Tips & Warnings
    • In
      the event that none of the above methods fixes your problem, you may
      have a hardware issue. Some hardware issues can be corrected by a
      professional repairman, while others cannot be fixed at all. If your
      system is still under warranty, consider exchanging it for a new one.
How do i put ny computer pictures to my psp
Here are the steps. 1.connect you psp to the computer. 2.turn on your psp and go to usb mode. 3.open my computer then find the psp file. 4.open it and go yo ISO there are 2 ISO files but choose the first one. 5.download the picture you want. 6.copy the picture. 7.paste the picture in the ISO files. THEN VIOLA there you have it.
May 13, 2010 | Sony PlayStation Portable (PSP) Console
Psp turns on but no picture or sound
When a psp turns on but there is no sound and picture, there are few things to check open the screw and check are all OK and there is non that is cut or unfitted... If all this is done and there is no improvement then one is bad which is the sound/picture board and the solution is to replace the board. I will advise that you give it to a certified technician for repairs. Check
Dec 26, 2009 | Sony PlayStation Portable (PSP) Console
Psp1004 start up and click sounds hears but no backup
clicking sound is coming from the umd drive. no picture would be either the light or the main board is bad in the PSP.
To fix both issues would cost more then just getting a new psp. Get a new psp.
Dec 23, 2009 | Sony PlayStation Portable (PSP) Console
PSP AV component cable - no picture
Try setting your TV to AV1 setting to see if this fixes the problem. Hope this helps.
Aug 19, 2009 | Video Game Consoles & Games
No picture
Sounds like the screen is bad and if you charged up your battery and the PSP won't turn on then your battery needs to be replaced as well.
May 04, 2009 | Sony PlayStation Portable (PSP) Console
PSP Slim, picture problems
If he bought it from best buy, ask for a two year reeplacment plan. after that, you tell them what happend to your psp. by the way, the replacment plan is only $29.99. They will either try to fix it, or they will give you a new psp, the same exact type as you said psp slim, for free. But heres a catch. after you use the replacment plan once, you may not be able to use it again. good luck. P.S. what happend to your nephew, is what happend to me.
Jul 07, 2008 | Sony PlayStation Portable (PSP) Console
Psp
your psp'sattery is low or try using pandora battery
May 09, 2008 | Sony PlayStation Portable (PSP) Console
PSP No picture or sound
I have similar issue too.. I was replacing a crack lcd screen in my psp. After i finished installing the new lcd, turned it on, there was sound but no picture.. Can anyone tell me what could've caused that?
Feb 25, 2008 | Sony PlayStation Portable (PSP) Console
Psp support
Sounds like the Backlight is out. There is a fuse on the motherboard that can blow and cause this to happen.
You can fix it bu applying a drop of solder and bridge this fuse.
You can find tutorials and walkthoughs on youtube.
Jan 26, 2008 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
55 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
