Question about Vizio SV422XVT 42 in. LCD HDTV
Vizio SV422XVT, AT&T Uverse: volume gets quieter on its own
Hi, I have a SV422XVT with AT&T Uverse. Most of the time when I put on a channel, the volume is fine... then gets quieter to the point that it is annoying and I just turn the volume up. If I click Pause (DVR), wait 3-5 seconds, the hit Play then the volume is back to being fine (very nice, actually) then immediately begins to get quieter.
I have tried various HDMI cables. The component cables seem to work fine.
5 Suggested Answers
SOURCE: Vizio 42'' LCD having intermittent fuzzy screen on stdrd channels
you might have an overheating problem- make sure you have adequate ventilation around your tv
Posted on Jan 29, 2009
phongnv
  • 56 Answers
SOURCE: Vizio Model#:L37HDTV10A
Is the HDMI port 2 work? Try to turn it off and turn it back on. If it is still not working then the HDMI ports have gone bad. You will need to replace the main board.
Posted on May 12, 2009
SOURCE: When I connect HDMI from a Time Warner DVR to my
Use the Time Warner remote and hit the settings button twice. Scroll down to "audio: digital out" and select HDMI. That solved it for me.
The only issue I have now is that I also have component sound outputs going from the cable box to a receiver. When I turn off the TV while the HDMI cable is hooked up to both the box and the tv the sound goes out to the receiver...
Posted on Dec 03, 2009
  • 101 Answers
SOURCE: 47" Vizio Flat screen HD LCD freezes up and remote will not work.
could it be Ch 9's digital signal is not broadcasting right? what is your refresh rate on your tv? 60 or 120hz? if its 120hz, then its more then likely the digital broadcast, if its 60hz I think its your tv can't keep up with their signal that may be at 120hz. Make since??
Posted on Apr 28, 2010
Getting hdmi problems between vizio e550vl and uverse
more likely the receiver or a connection than the set
Aug 27, 2012 | Vizio E550VL 55 in. LCD HDTV
Uverse says no channels in master list
Do resetting and go for auto scan. If the channels are not stored, there is something wrong with the memory chip inside.
Jul 29, 2012 | Vizio Televison & Video
Problems with vizio vf550m
These new plasmas are very sensitive to dust I had the same problem with mine I would press the volume and the channel would change or i would put it on one channel and it would go to component by itself I took it apart and blew it with a can of computer air and cleaned the buttons with alcohol and swabs works perfect now. hope this helps
Jun 30, 2012 | Vizio VF550M 55 in. LCD HDTV
How to program vizio remote
Hi Stairs123,
I have this link for you on how to set up your Vizio remote to your Uverse system. Hope it helps
Search Results for program other remote to my uverse
May 27, 2012 | AT&T Televison & Video
Vizio sv422xvt lcd tv , freezes shuts off and reboots at random, need fix advice, total reset didn't work
Sounds like you might need to replace the main board on the unit. Make certain you get the right one or it will not work. E-Bay might have one.
Oct 03, 2017 | Vizio SV422XVT 42 in. LCD HDTV
I have lost my remote and the kids pushed the side buttons on the TV to raise the volume but instead changed the channel. Now I can't get back to the channel that works with my AT&T uverse box.
Instead of changing the channels, press the "INPUT" button on the side of the TV slowly and repeatedly. The TV will cycle through all of the available external inputs one of which will be for your Uverse box. If this doesn't work, try switching to channel 3 or 4. I can't say which will be correct as it depends how the equipment is setup.
Hope this helps.
Regards,
BElectric
Jan 07, 2011 | Vizio VX32LHDTV10A 32 in. LCD HDTV
Just bought E420VL 42" LCD
Go into menu, sound set-up, and switch SRS to off. It's a vizio thing they came up with to act like "Smart Sound" where commercials won't be louder. It is total BS and does not work, it makes your normal sound fluctuate. Worked on all 3 of my Vizios. Hope it helps you.
Dec 13, 2010 | Vizio Televison & Video
Need a code for att uverse for the remote for vizio lcd
Click Here for the list of Manufacturer's Code for AT&T Uverse
May 13, 2010 | Zenith ZEN700 Remote Control
Not able to program vizio remote towork with att uverse Cisco box
Maybe too late for you but ATT just gave me a code that works with my Vizio plasma. Code is 1343. Even the mute works correctly. They gave me some others to try but I didn't need them. Other codes were 1018, 0030 and 0056.
Mar 19, 2009 | Vizio VO47L 47 in. LCD TV
Open Questions:
Vizio SV422XVT 42 in. LCD HDTV Logo
152 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
