Question about Fisher Price Power Wheels Cadillac Escalade
Won't run! I bought a used, although in very good condition, Jeep...probably 3 yrs. old...the owners purchased a new battery last's been working fine and our grandkids are LOVING it...however, it just stopped running. I will take the battery somewhere to have it checked but our son doesn't think that is the problem...where can we take it to have it "serviced" or fixed? We are in St. Louis, MO. PLEASE do not add/sell my email address to solicitors.
    Top Expert:
  • Fisher Price Master
  • 48,384 Answers
Have the fault codes read to determine the problem sensors
Posted on Jun 04, 2017
4 Suggested Answers
  • 1340 Answers
SOURCE: I just bought a barbie
Well I do hope it dries out...and works.Good luck!Let me know if you need help.I don't really trust battery testers as much as an actual reading,but with all that water,depending on the battery(s),they may be no good now.
Posted on Aug 05, 2010
  • 3 Answers
SOURCE: I have a powerwheels barbie
I would suggest checking all of the connections in the wiring. Often the spade type connections can come unseated during use.
Check the following areas:
  1. Connection to the battery itself
  2. Connection to the foot switch (you may need to unscrew it from the floorboard to check)
  3. Connection to the electric motor(s) attached to the rear wheels
If the battery is older, it may have failed. If you have a multimeter, or even a simple test light, you can check to see if the battery has voltage. You're looking for around 5-6 volts. Anything below just off the charger could indicate failure.
Hope that's helpful!
Posted on Feb 28, 2011
  • 811 Answers
SOURCE: We bought a Tickle Me
There is usually a warrenty issue with the time frame that you have waited to return the item to Walmart. If you still have the receipt which you will need take it to the return counter with receipt and the item and ask them if they can or will exchange the item for you. That is really all you can do to get this exchanged they will not even work with you if you do not have a receipt for the item and all the parts and stuff with you. Walmart is usually good with their customer support and exchanges, however you may have an issue with the length of time you have had it.
You might want to check the charger for it for the battery the charger may not be working you can possibly try to get another charger for it if the batteries are new then try another charger for it. I hope that this assisted you my son is lost without his so I understand. I replaced my charger and it worked great after that. Thanks for using FixYa! John
Posted on Apr 12, 2011
I bought Dash 5,0 3 yrs ago. For 2dys now phone will not charge battery seems to be dead. DO I NEED A NEW BATTERY?
If the battery is 3 years old and will not charge, it probably should be replaced.
Feb 06, 2017 | Cell Phones
1998 Toyota Avalon XLS -- Will not start. No clicking.
It definitely sounds like a weak battery issue. Ck your connections at the battery for cleanliness & tightness. U need to have the batt checked along w the charging system & ckd for electrical shorts. If no problem is found that is the starting line. It may be a prob in the ignition system etc. if the problem isn't found by here. Good Luck
Mar 16, 2017 | 1999 Toyota Avalon
I have a black/decker drill Fire/Strom 12V When I pug the charger into the electric outlet the light doesnt come on. So I leave it in but the battery never get charger. is it the charger or the battery.
How old is the battery there olny good for 3 or4 years and if you leave themin the cold they won;t last half that long yours is an older one the battery dosn;t come off it although i like black and decker i would have to say even if it was the charger and you got a new one the battery wouldn;t live vary much longer
Nov 23, 2010 | Black & Decker Drills
I just bought a 2000 vstar 650 yamaha classic. it was sitting for 1 year. i replace the sparks,fuel filter,new gas. it still will not turn over and acts like it will take a charge for a while and...
Hi, Jaynell if your bike has been sitting idle for months or years and you did not do any pre-storage maintenance I feel your pain it will probably have a dead battery and not want to start or if it starts it will idle and run poorly, here are the following steps necessary to complete in order to get your bike back to an acceptable running condition.
1. If your battery was 2-3 years old when you last had the bike running you should replace it.
2. If you believe your battery might still be serviceable remove it from the bike and put it on a 1 or 2 amp trickle charger for 24 hours. If it is the old lead acid type with visible cells and acid levels fill each cell to the top line with distilled water and replace the caps, run the vent tube into a plastic or styrofoam cup, any cells that are cloudy/milky replace the battery.
3. After charging remove the leads and let the battery sit for a couple of hours then check the battery voltage with a volt meter, you should have 12.5 volts or better, any readings in the 11 volt range you need to do a proper load test on the battery and replace as necessary, any readings in the 10 volt range you have a dead cell and replace the battery.
4. Drain and flush fuel tank, google " how to clean a motorcycle gas tank" find a couple forums to view the different options available.
5. Remove your air cleaner and clean and re-oil per Mfg. specifications.
6. Remove the carburetor, disassemble and decontaminate with a carb dip or if you have EFI remove injectors and clean with carb spray and compressed air
7. Remove fuel valve and filter disassemble and clean as necessary, remove fuel lines and replace with new ones.
8. Replace spark plug with a new one and check for spark.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
VStar 650 won start
V650 won start in 650 Star Tech Forum
OEM parts for Yamaha
Oct 07, 2010 | 2000 Yamaha V Star Classic
I bought a used Acer Aspire One model KAV60. The battery won't charge past 60%. Do I need a new battery or is it something I can fix?
If the computer is more than 2 yrs old you must change the battery. Also the battery due to overcharging looses its capability to last long which probably may have happened in this case. My advice buy a new one as it has already showing signs of Fatigue
Sep 10, 2010 | Computers & Internet
Battery is about 3 years old, bought the car used last year.
You need to check the voltage in the battery. Depending on the quality of the battery, 3 years in some cases means its time for a new one. Have it checked first before you replace it. Auto zone or any good service place can check the battery to determine how good it is.
May 30, 2009 | 1999 Volkswagen Jetta
Braun shaver won't charge
Batteries have an expiry date, Even if you're not using them they are still discharging. Even the regular AA type you buy at the shops.
Batteries can die even if there is a lack of use. And even regular rechargeable shavers that are used all the time have only a limited life a little shorter that=n what you've had.
Should you get new batteries or a new shaver? probably not, you're using 2-3 times a year. I'd recommend buying a cheap Braun or Remington that can take AA's.
Apr 07, 2009 | Braun Health & Beauty
Car won't start even after new battery purchase
Alternator problem, the alternator charges the battery when car is running, so it has probably died now. Was working at reduced capacity for a while, which is why you were only getting a partial charge for some time. Now you have an open circuit completely as alternator has failed completely, time for a visit to an auto electrician. PS replacing acid in battery with distilled water is not a good idea. It probably was time for a new battery anyway.
Mar 19, 2009 | 2003 Toyota Camry Solara
Digital rebel battery drain with flash only
I would suspect the batteries
Ive got an eos Rebel think its just over 4 years old
for the last year its been used every weekend for several hours 300+ pics per weekend between 2 nights I found that recently where one battery would last a night the battery was running out midway through & also taking longer to charge afterwards
2 after market replacements cost me about £10 and things are back to normal
5 years is a pretty good lifespan for a battery so its probably just getting old
Nov 29, 2008 | Canon Digital Rebel / EOS-300D Digital...
After reading comments and complaints from other frustrated Maytag owners, I just went out and bought a new LG EnergyStar dehumidifier. I'm taping the receipt inside a plastic bag, along with the user manual, to the side of the machine. Hope this one works for a LONG time! Ronnisue
Jun 15, 2008 | Maytag Dehumidifiers
Fisher Price Power Wheels Cadillac Escalade Logo
66 people viewed this question
Top Fisher Price Toys Experts
Bill Boyd
Jennifer Rock
Jennifer Rock
Are you a Fisher Price Toy Expert? Answer questions, earn points and help others
