Question about Mr. Coffee 072179228578 12 Cup Coffee Maker
The red clean light was flashing, I ran a pot of white vinegar through it, and then two pots of fresh water to rinse, the red clean light will not stop blinking, what do I do?
  • 3 Answers
Turn the power off after you clean and rinse it. Leave it off for a minute. Plug it back in and all's well.
Posted on Jul 13, 2010
    Problem Solver:
  • 25 Answers
I have run the instructed cleaning cycle, including the add'l pots of water afterward. The cleaning light stays on when I try to brew a pot of coffee. I unplugged the unit for over 8 hours and when I plugged it back in, the cleaning light still comes on when I attempt to brew.
I've done this twice...with the same result. There's got to be some way to reset it!! >:(
Posted on Oct 08, 2011
  • Nancy Jenkinson Oct 29, 2011
    Someone on here had the solution. Run 10 cups through the cleaning cycle - not the amount recommended in the instructions. =)
Mr coffee problems
You didn't indicate a specific model. So, I'm going to assume yours is relatively the same as my JWX27.
Let me start by clarifying what the red light indicates.
A solid red light indicates the cleaning cycle is in progress. A blinking red light indicates the coffeemaker is off, but due to be cleaned. When the coffeemaker is due to be cleaned, the red light will continue to blink while the coffeemaker is off until the cleaning cycle has been completed fully. The entire cleaning process takes about an hour and a half. And, it is not intuitive. So, here are my instructions.
With the coffeemaker off (with the red light blinking), pour four cups of pure white vinegar (no water added) into the reservoir. Don't short the amount. You'll need four cups to complete the cycle. Remove any filters, but leave the strainer basket in place. Tap the "select" button three times until the red light is on (and stays on, not blinking). The cleaning cycle now begins. It should take between 45 minutes and an hour to complete. Don't be concerned about the 30-minute long pause during the cycle when nothing happens. This is intentional and part of the cycle.
After the cleaning cycle has completed, get rid of the vinegar. Rinse out the strainer basket and the coffee pot. Run a full pot of clean water thru a regular brew cycle (with the pot and basket in place, of course). Then, dump the water, rinse the pot and basket again, and run another full pot of clean water thru a regular brew cycle. Dump that water too. And, you're done!
Jul 20, 2014 | Mr. Coffee Coffee Makers & Espresso...
Tip
How to properly clean and care for your airpot
To clean your airpot you have to first make sure that it is turned off and unplugged. Pour out the water that is still in the airpot if there is some and allow it to cool down. Once it has cooled down you can begin to clean it.
You want to start with a since of the inner lining using hot water. Use a sponge to get loose debris off the lining and rinse again.
Fill the pot up again with hot water and few drops of mild dish soap, let this solution sit for 10-15 minutes. Using your sponge again scrub the inside of the pot then make sure to rinse both the sponge and the inside of the pot to get all the soap out.
If there are any mineral deposits in the pot you should fill it with hot water and about 2 Tbsp of white vinegar. Let it soak for about an hour an then rinse thoroughly you don't want the taste of vinegar in your water.
To clean the spout you pour some of the water and vinegar solution out the spout then rinse with fresh hot water.
Finally to clean the outside use a damp cloth to wipe it down and a dry one to wipe it dry. in the case that you have stains on the outside use a mild dish soap to clean, rinse with clean cloth and then use a dry one to wipe dry.
on Oct 06, 2013 | Home
Clean instructions
First, let me clarify what the red light indicates.
Feb 04, 2014 | Mr. Coffee JWX27 12-Cup Coffee Maker
Clean instructions
I presume you are requesting instructions for cleaning this coffeemaker...
With the coffeemaker off (either a red blinking light or no light on), pour four cups of pure white vinegar (no water added) into the reservoir. Remove any filters, but leave the strainer basket in place. Tap the "select" button three times until the red light is on (and stays on, not blinking). The cleaning cycle now begins. It should take between 45 minutes and an hour to complete. Don't be concerned about the 30-minute long pause during the cycle when nothing happens. This is intentional and part of the cycle.
Sep 30, 2013 | Mr. Coffee JWX27 12-Cup Coffee Maker
Cant get the cleaning cycle to end dont know how to get it off
If the red light is still blinking, then the cleaning cycle has not yet been completed. The cleaning cycle is not intuitive. So, here are my instructions.
Jan 07, 2012 | Mr. Coffee JWX27 12-Cup Coffee Maker
Model # jwx23 mr coffee cleaning instructions
I couldn't find any model JWX23. So, since your question (as much as it is) is categorized under model JWX27, I'm going to presume you need the cleaning instructions for model JWX27.
With the coffeemaker off (with no lights on or with the red light blinking), pour four cups of pure white vinegar (no water added) into the reservoir. Don't short the amount. You'll need four cups to complete the cycle. Remove any filters, but leave the strainer basket in place. Tap the "select" button three times until the red light is on (and stays on, not blinking). The cleaning cycle now begins. It should take between 45 minutes and an hour to complete. Don't be concerned about the 30-minute long pause during the cycle when nothing happens. This is intentional and part of the cycle.
Jan 01, 2012 | Mr. Coffee JWX27 12-Cup Coffee Maker
Coffee has a tangy flavor
You need to clean the coffee maker.Use white vinegar.Just fill the reservoir with and hit brew.When it is done.Fill the pot half way with ice and one hand full if salt.Swirl the pot till all stains are gone.Then run one full pot of clean water,to rinse.Make yourself a fresh pot and enjoy.
May 16, 2011 | Keurig B60 Coffee Maker
We ran the clean cycle on the coffee maker and the clean cycle will not turn off.
First, let me clarify what the red light indicates. A solid red light indicates the cleaning cycle is in progress. A blinking red light indicates the coffeemaker is off, but is due to be cleaned.
The red light will continue to blink while the coffeemaker is off until the cleaning cycle has been completed fully. The process takes about an hour and a half and is not intuitive. So, here are my instructions.
May 15, 2011 | Mr. Coffee JWX27 12-Cup Coffee Maker
Self cleaning the quisinart coffee maker
I always use a mixture of 50:50 of cold water and white vinegar to help clean the internal parts of any minerals and scaling.
Unplug the coffee maker first, then add the water/vinegar mix to the reservoir.
Place a new, clean paper filter in the basket to help catch any deposits that will be dislodged and cleaned from the coffee maker.
As far as having the coffee pot dry, there is no need for that. I do tend to wait about 15 minutes to let the cleaning mixture disolve any deposits in the main water reservoir and then I turn on the coffee maker and let it process the water/vinegar solution through it.
Once it's done, turn off the coffee maker and discard the solution in the pot. And rinse out the coffee pot/carafe with clean, fresh cold water. Remove and throw away the used paper filter element andrinse out the basket with warm water and put it back on the unit.
Now fill the coffee pot/carafe with fresh, clean water and pour that into the coffee maker's water reservoir. Put in a new, clean, paper filter and turn the unit on and run a plain pot of water. This will help to clean out any remaining residue and clear the unit of the vinegar taste and odor.
Now you're all set to start making fresh tasting coffee again. I always recommend using filtered water for the best tasting coffee, as the taste is a direct result of brewing temperature, water purity, and the coffee you use.
Hope you find this Very Helpful and best regards!
Sep 22, 2009 | Cuisinart DCC-1200 Coffee Maker
The red cleaning light on my cuisinart coffee maker is still flashing even after running several pots of first vinegar water and then clean water through the maker.
Hello sandra_strat,
There are two possible issues, but easy to do. When decalcifying your unit the solution should be 2 parts water and 1 part vinegar. So if you have a 12 cup maker it would be 8 cups water and 4 cups vinegar. Complete the process with a pot or two of fresh water to rinse. Second, there may be a water filter stick that is removable. Open the lid and look for it in one of the corners, pull it out and remove the carbon filter there. (You can get a new on Amazon). Then replace the stick.
I hope this is a help for you. If it is please leave positive feedback for me. Thanks! NormanZ
Jul 14, 2009 | Cuisinart Coffeemakers
Mr. Coffee 072179228578 12 Cup Coffee Maker Logo
1,958 people viewed this question
Top Mr. Coffee Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Henry  Thomas
Henry Thomas
Are you a Mr. Coffee Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
