Question about Dynex DXWEGRTR Router
Can't access internet on 2nd PC
Have iMac connected to internet via Comcast modem and Dynex router networked to Dell Laptop. Dell Laptop suddenly cannot open Internet Explorer. Tried everything!!!! Help!
    Novelist:
  • 112 Answers
Please follow these steps to resolve the issue:
  • Please press "Windows+R" key to open the Run command and enter inetcpl.cpl in the Run command.
  • Under General tab, click on "Delete" and then click on Delete all to clear all the history, cookies, temp files.
  • Please click on Advanced tab, click on Reset: to reset the Internet Explorer settings.
  • Now, try to open the Internet Explorer and check if that works.
Please let me know if you require further assistance.
Good Luck!
Thank you for contacting.
Posted on Jul 07, 2010
I am having trouble connecting my RCA dcm425 with a dynex 10base-t ethernet hub to two devices at once. Comcast said I should be able to connect two devices at once but I can only connect one at a time. ...
The RCA DCM425 is a cable modem. You need an Ethernet router to connect two devices to the wide area network provided by the modem. A router assigns I.P. (internet protocol) addresses. Your Dynex Ethernet hub is a switch which will enable you to share files between computers. It doesn't support directing traffic to and from the internet.
I wish that I had better news for you. You can get a router from many sources.
Feb 19, 2018 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Computer cabled to Dynex enhanced G wireless will not connect
Unplug the router for ten seconds and plug it back in, it needs to reset. Some routers have a reset button. I often wait longer than ten seconds, I find a beer is usually the right amount of time. Sometimes the modem needs a reset also; unplug everything, then plug back in sequence, with the modem first, the wait, then the router, wait, then turn on your computer. That system works for any brand modem and router.
Jun 09, 2009 | Dynex Enhanced-G Wireless Broadband Router
Connect Laptop to PC desktop which has cable connection.
YOU WILL NEED TO GET A WIRELESS ROUTER TO BE ABLE TO USE THE LAPTOP WIRELESS, iT IS A VERY EASY SET UP AND CONNECT THE DESKTOP WIRED AND THE LAPTOP WIRELESS TO A WIRELESS ROUTER.
May 06, 2009 | Arris SURFboard SB5120 Modem
Wireless signal keeps dropping/dissapearing
Check my tip
Using Router and Wlan adapter from different brand (Dynex + Belkin) is sometime calling for trouble: you must configure both to be sure to be on same standard (or change Both).
I'm using Netgear + Belkin and tune is not easy
On router config check radio power, reduce the used standard (B/G A/N) to the only one used by Belkin adapter (N).
Be sure you removed Windows zero wireless configuration (= use windows to manage my connection= OFF)
edit your belking wireless networking utility to automatic reconnect:
try downgrading to G standard from router side
Check your network connection plugging your laptop to router via lan cable.and check network params (DHCP DNS etc.).
Then check wlan connection near router, if you experience wlan drops only when far from router, find any possible interferences source (Microwave, cordless, remote) remove it or be ware you cannot have wlan when your wave is working.
Dec 13, 2008 | Dynex Enhanced-G Wireless Broadband Router
Dynex Router problem
You should first verify you have a internet connection to your computer directly from modem. If you do then turn your computer off unplug modem from power supply and remove ethernet connection. Then with cable only attached to modem plug in power supply. Allow enough time for modem to boot completely up. Then plug ethernet back into modem and the other end into router. Then power up router. Allow adequate time to router to sync up. If you never set up your router initially with all security features and access codes for wireless you may need to run set up disk. If this was all previously done then power up computer go to CONNECT TO option on START menu. Your wireless network should be listed with the name you gave it. Select your network. If it is a secured network it will ask for access codes. Enter the codes and you should be able to access internet. If not you may need to run set up disk again or contact manufacturer of router.Good luck
Oct 13, 2008 | Computers & Internet
Please help...internet won't connect
You may be running into a problem of your ISP only allowing one computer on the internet. while the internet is on can you access the internet from the desktop comcast originally setup?  If so that is more then likely your problem.
I have comcast myself and they told me they do not allow home networks. I fixed that problem by using the mac address cloning feature in my router.
The setup cd is also junk, all you should really need to do is:
1. unplug modem, router, and turn off computers
2. Plug modem into router
3. Plug computers into router (don't worry about wireless right now)
4. Turn on modem, wait 20 seconds or so for lights to set,
5. Turn on router. again wait for lights to set
6. Turn on ONE computer that is hard wired into the router
7 Try to surf the net.
8. If successfull try to connect wireless computers (Without using cd) and see if they surf.
If not call comcast and see if your computers are trying to obtain real-world ip's instead of LAN ip's like they should.
If so, you'll need to enable DHCP on the router.
Jul 18, 2008 | Belkin (F5D7230-4) Router (587009)
WIFI
You can go for a wireless router, so that you can access internet anywhere in your house, ,
Jul 18, 2008 | Dell Inspiron 5100 Laptop
Using laptop and pc on this router
You SHOULD NOT post your personal details here...
The dx esw5 is not a router, it is a switch so it cannot assign an IP to the second PC.
dx esw manual HERE
Which ever PC is turned on first will get an IP assigned by the modem and the other will not.
My guess is that the service provider for your internet only allows 1 IP to be assigned by the modem.
What model is the modem
I think you need a router to share the internet between 2 PC's
Jul 03, 2008 | Dynex 5 Port 10/100 Ethernet Switch...
Laptop
It really depends on what "modem" Orange provided you with and how your personal PC is connected to the modem.
If the "modem" provided by Orange uses WiFi (such as Livebox) networking, then it is a matter of setting up your daighter's laptop to access and use the Livebox WiFi Network. In this case no router is needed since your modem is also a router.
If your PC is connected via Ethernet port to the "modem" and Orange's "modem" is a single Ethernet output port, you would need an AP/Router (Wireless since I am presuming the your daughter's laptop would be accessing the Internet wirelessly) such as the LinkSys WRT54G.
If your PC is connected via USB port to the "modem" and Orange's "modem" has only a USB output port (no Ethernet), you need to make your PC as the default gateway/software router and share your PC's Internet connection. If you are connecting your daughter's laptop using Ethernet cable, then you don't need a WiFi AP/Router but an ordinary hub. If on the other hand the new laptop would connect wirelessly, you would still need something like the WRT54G.
Hope that this be of some help/idea. Pls post again how things turned out or should you need additional information.
Good luck and kind regards.
Dec 04, 2007 | 2wire (1000-400108-001) Router
Dynex DXWEGRTR Router Logo
66 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
