Question about Kenmore Drop-In Bobbin 505S-21BH Mechanical Sewing Machine
Kenmore sewing machine 385 series: I can not pick up my bobbin thread. When I could pick it up, I was skipping stitches.
  • 4 more comments
  • AaronGo Apr 19, 2008
    My wife's Kenmore sewing machine, model 385.12812690 is having the same problem picking up the bobbin thread. Could someone share how to re-time her machine so we can determine if that is the problem?
    Thanks!
    Aaron
  • freckle Sep 22, 2008
    I have just gotten a Kenmore, model 385.16221, sewing machine and have
    followed the manual directions, yet I can not find out how to pull up
    the bobbin thread. The needle does not pull up the thread.
    How do I do this.
    I'd appreciate any help.
  • Anonymous Dec 05, 2008
    Kenmore sewing mavchine model 385 19030. Needle will not pick up the bobbin thread, except occationally when set in a zigzag stitch and then stitches a straingt line with many skipped stitches. None of the other stitches work at all. I have cleaned it and checked the belts. Everything seems to be in working order.
  • mncb Jan 27, 2009
    My Kenmore sewing machine, model 385.81155 is having a problem picking up the bobbin thread. I think it needs retiming, can you please send me timing instructions. I see you already helped someone with this problem before. I would greatly appreciate if you would help me.
    Thanks!
    Margaret
  • polarjohnjoh Feb 07, 2009
    kenmore 385 81608 sewing machine may need retiming
    It is not picking up the bobbin thread. do you have instructions on how to do
    retiming on this model and can you send them to me .
    polarjohnjohn@yahoo.ca
  • erin_shannon Apr 14, 2009
    I have the same problem. I need instructions on how to fix the timing on my Kenmore 385.16227300.
5 Suggested Answers
louislevel_2
  • 374 Answers
SOURCE: need sewing machince help????
hi;
breaking thread and thread below not hook up by upper thrread, this is due on not properly set up of thread tension,first check bobbins windin35caecd.jpgg see figure.the threads should
be counter clockwise.
the theading on upper set up should prorerly inserted follow figures.7dabcae.jpg
the dial set up tension should start at #3 to # 5
the stitch tension should be set to # 8 to # 12
use trial run for fabrics,diffferent set up in every fabric tru to study before sewing in other fabrics.have a nice day don't forget to rate me.thank s a lot
Posted on May 17, 2009
SewExpress
  • 41 Answers
SOURCE: Picking up the bobbin thread
A few suggestions:
  1. Rethread top of machine from scratch with the presser foot raised, i.e. remove thread completely from all thread guides & paths and start from scratch, making sure thread is securely seated between tension disks. Once the needle is re-threaded, lower the presser foot and give the tail end of the thread a tug to make sure there's tension on it.
  2. Make sure the bobbin is turning the correct direction for your machine - and that the thread tail is under the tension plate or bobbin tension guide (depending on machine).
  3. Blow out any fuzz.
  4. Insert a new needle, making sure needle is pushed all the way up.
  5. Oil machine (in locations recommended in your owner's manual).
If the basic cleaning and re-threading (above) don't help, your machine(s) may be out of time or have another mechanical issue that will require a repair technician. We recommend a tech trained on your specific brands - they'll be better trained and able to get any repair parts that may be needed.
Hope this helps narrow down your stitching problems.
Happy sewing,
Kim & Linnette
Posted on Jun 27, 2008
  • 323 Answers
SOURCE: Sears Kenmore Sewing Machine Model 385. 1254180 Bobbin Won't Wind
On some of these machines when the bobbin winder is on it stops the rest of the machine from working. Push the bobbin winder mechanism to the left and see if your machine will work.
sewman7
Posted on Jan 23, 2009
Mongo32
  • 111 Answers
SOURCE: my 385.15516000 Kenmore sewing machine is skipping
have you tried a new needle? needle in correctly? threaded correctly?
Posted on Jul 23, 2009
  • 5 Answers
SOURCE: Won't pick up bobbin thread
Does she have the right needle in? If the needle is to short it won't pick up the thread. If that is not the issue than it could be timing
Posted on Jul 29, 2009
Wont pickup bobbin thread when sewing.
Make sure you are using a brand new needle. Bent/damaged/dull needles frequently will fail to pick up the thread.
If it continues to skip stitches, it most likely has a needle/hook timing issue--the needle arrives at the bobbin at the wrong time to intercept the bobbin thread.
There are web sites and videos available that discuss sewing machine timing, or you can take it for service.
Sep 10, 2016 | Sewing Machines
I have a XL2600I and the top thread is only picking up the bottom thread about every inch. What can I do or replace?
try a new needle--use the right needle for the fabric being sewed
rethread the machine, using every thread guide
take the bobbin out of the bobbin case and reinsert it, making it sure it counter clock wise in the bobbin case
also could be a timing problem
Mar 15, 2016 | Sewing Machines
Sewing machine not stitching
SKIPPED STITCHES
1.the needle is not inserted correctly
2.the needle is damaged
3.the wrong size needle is being used
4.the foot is not attached correctly
it's also possible that the machine needs to be serviced
May 31, 2012 | Singer Sewing Machines
Kenmore 100 stitch 385 Bobbin thread does not engage into stitch, Needle goes down but thread does not pull up into stitch. Threading bobbin according to diagram on foldout section. replaced the bobbin...
make sure that you have enough of a tail on your thread, at least 3-4 inches and hold it with your left hand until the needle picks up the thread. I am assuming that you have your bobbin threaded correctly and your needle is inserted with the flat side facing the rear of the machine.
Sep 10, 2010 | Kenmore Sewing Machines
Kenmore 100 stitch 385 It will not pull the bobin thread up into the stitch. It does all the fancy patterns but the bobbin thread does not ingage in the stitch. Please help
Make sure that you have the bobbin threaded correctly, and that you have a tail of 3-4 inches held in your left hand until the top thread catches, make sure you move your handwheel towards you and your needle is inserted with the flat side facing the rear of your machinine.
I have a Kenmore 385 1664180...the top thread won't pick up bobbin thread...I have done a good cleaning job and still cannot get a stitch...
Rule #1: DON'T PANIC!! :-)
Change the needle (it might be bent). Make sure the flat part of the shank of the needle is facing the correct way according to your manual. Then take all the thread out and rethread everything, making absolutely sure you're threading it correctly.
This should solve your problem. Let me know, ok? And kudos to you for keeping your machine clean!
Robbie
Jan 26, 2010 | Euro-Pro 150 Mechanical Sewing Machine
Why is my machine skipping stitches
this is caused by uneven winding of the bobbin, sometimes the spool of thread winds unevenly when it travels up and down the spool. the best solution i have found is to use small spools of thread when winding the bobbins
Dec 02, 2009 | Kenmore 15516 Mechanical Sewing Machine
Kenmore 385 model Automatic Button Hole Apparatus Jams Thread?
Practice and practice some more! Use the same fabric and interfacing as your project and a NEW needle (the correct needle) This is for the Sears Kenmore 385 automatic button hole maker. Make sure you pull the bobbin thread through the Guide Block - it is that simple. Make sure you pull your thread to the back of the machine though the presser foot slot - the correct presser foot. Account for both thread tails before starting to sew. Keep thread tails to the back of the machine 4-5", insert fabric under presser foot keeping thread tails clear. Mark button hole and sew.
Mar 30, 2009 | Kenmore Drop-In Bobbin 505S-21BH...
Problem with my machine
If you're not picking up a bobbin thread, it's either a timing issue, or the hook/needle clearance. Usually, with the hook/needle clearance the skipping stitch problem will be intermittent. If it's a timing issue, it may not pick up the bobbin at all.
Sep 08, 2008 | Kenmore 15516 Mechanical Sewing Machine
Kenmore Drop-In Bobbin 505S-21BH Mechanical Sewing Machine Logo
2,341 people viewed this question
Top Kenmore Sewing Machines Experts
Bargain Box
Bargain Box
SewTechWayne
SewTechWayne
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
