Question about Canon PIXMA iP90 InkJet Printer
New print head on my Canon IP90 and still a blank page
I replaced the print head on my Canon IP90 printer and installed new cartridges and still it prints out a blank page. What's wrong?
  • jeffner_c Jul 07, 2010
    The print head is new and it works on my other Canon IP90 printer.
  • 6,993 Answers
The printer needs to be serviced in order for it to pick up. Below is what you need to do to solve the problem.
Here's what you should do. Pop out the print-head, and cleaned it using the alcohol solution provided in my ink cartridge refill kit. Then force some of the alcohol solution through the nozzles. After submersing it in warm water for five minutes, blot it dry and used some q-tips to dry around the nozzles. Let it sit for ten minutes or so to be sure it is dry, and then pop it back in the printer.
Also, do a deep clean on the printer, clean every area. Wait for a while and print a test page, you will see that it will print okay.
Good luck.
Posted on Jul 07, 2010
  • 600 Answers
The problem would be in your print heads.
The print head may have clogged due to usage, the only remedy for it is to dismantle the printer and clean the heads.
Also try checking if you have your cartridges in the right slot, meaning black ink to black cartridge port and color cartridge on the colored port,
You may try uninstalling and then reinstalling the printer driver and then rebooting and try printing again,
if it still doesnt solve the problem i would suggest you bring the printer where you bought the printer for repairs.
Posted on Jul 06, 2010
My Canon IP90 printer in printing blank paper
If the inkjet printer has not been used for some time, and the ink cartridges are full then the print head nozzles may be blocked. If running the maintenance nozzle cleaning does not clear the print head nozzles then the print head will need to be replaces.
NOTE - inkjet print heads are not cheap, it may be better to purchase a new injet printer.
Jan 16, 2011 | Canon PIXMA iP90 InkJet Printer
My printer Canon iP90 does not print black color. Advise what to do. Thanks.
chances are, the blank cartridge is empty and needs to be replaced. if it is new, make sure the plastic cover is removed from the cartridge, try to remove the ink cartridge and shake it a bit and connect it back, then check your printer settings to verify if it is set to print in blank ink/color.
Sep 16, 2010 | Canon PIXMA iP90 Mobile Printer
New canon ip90 printer prints blank pages
New it should have warranty, Canon suggests trying cartridge first, at least 3 deep cleanings, still blank you need either printhead or shop to service.
Jan 12, 2010 | Canon PIXMA iP90 Mobile Printer
It is not printing using black ink. I have
Sounds like your black print head may be clogged. You can get a new one from Precision Roller for $60. Another fact that would confirm that your print head is clogged is if you let the printer sit for more than a few weeks without printing with it.
http://www.precisionroller.com/k_canon_pixma_ip90_print_head/m114d7411c104/
Nov 02, 2009 | Canon PIXMA iP90 Mobile Printer
Canon iP90 only prints blank pages
Did you try to wipe the cartridge.Maybe there's a clogs. inside.
May 28, 2009 | Canon PIXMA iP90 InkJet Printer
IP90 WONT PRINT BLACK
I had this problem recently with my IP90. Both the black and color heads were clogged. After running the "canned" routines several times to clean the heads and deep clean the heads...still didn't help...here's what I did:
1. open the top lid to have the cartridges that are inserted in the print head move to the middle of the printer.
2. remove both cartridges
3. What is left there is the print head holder. Slightly move it to the right and gently lift the print head lock.
4. Grasp the print head and lift it out of the tank.
5. Have several paper towels hand and know that you will have color and bw ink on your fingers
6. Put the print head on the paper towel
7. Pour rubbing alcohol on the blk and color heads and let them sit of about 10-15 minutes.
8. after that dry the heads and re-insert them in the printer
9. I put new cartridges in the printer and ran clean and deep clean a few times.
10. My color and black and white print came right back!
Hope this helps.
Jan 30, 2009 | Canon PIXMA iP90 InkJet Printer
Canon IP90 portable . No ink printing.
Have you performed a nozzle test? If one or more of the colors is missing when you do the nozzle test, the printhead itself is likely in need of replacement.
Before considering replacment, perform a clean on the printer. Due to variations between mac and pc, please see your documentation / support files on how to perform the clean on your printer.
After performing the clean, again perform the nozzle check to see if the problem is resolved.
If still not resolved, remove and re-install any cartridges you recently replaced to make certain they are installed correctly.
May 01, 2008 | Canon PIXMA iP90 Mobile Printer
Print head for canon ip90
There is a very easy fix for a Canon IP90 not printing either color or black. I just fixed mine a few minutes ago. Go to the local Dollar store and buy some nail polish remover. Then open up the printer, remove the ink cartridge(s) and put a few drops of nail polish remover in the hole that receives the ink. Works like a charm and fixed mine in just minutes. After inserting the polish remover (actually just Acetone with some glycerin) reinsert the ink cartridge and do a deep clean using the Canon utility from the Control Panel under "Printers > Properties > Maintenance (right click on the Printer icon in Control Panel to start)." You can also simply use acetone. Another trick is to remove the print head which holds the ink cartridges (although I could not figure out how to do this but it's doable) then put a paper towel soaked with distilled water (tap water probably OK) in the microwave, heat the towel and quickly put the print head on the hot paper towel. As a last resort simply order a new print head from the Internet and replace the print head. I would presume it would come with instructions for removing the old print head.
Dec 29, 2007 | Canon PIXMA iP90 InkJet Printer
Prints without any errors but no ink on the paper.
if you have new print head assembly and cartridges, and waited for flow, and the printer is MECHANICALLY sound (not dropped or G-force damaged), then all that is left is improper cartridge installation. You may not have the cartridges fully inserted/, or maybe they are not PROPERLY inserted. Look for a snap when in place (and no wiggle). I suspect this is your problem, because one symptom you mention, ink accumulation INSIDE the head/cartridge cradle, is VERY rare -unless the cartridge is inserted improperly. The cartridges/head assemblies have VERY good seals to prevent leakage. Unless the o-rings/seals are damaged, leakage outside the seal just does not happen at all, normally.
*New head/cartridge installs can take several hours -sometimes even a day in cold weather, for small iP90-like printers to saturate the heads -and print.
Oct 08, 2007 | Canon PIXMA iP90 Mobile Printer
Canon PIXMA iP90 InkJet Printer Logo
118 people viewed this question
old marine
old marine
