Question about MSI MS-6758-040 Motherboard
After movig to another country i've changed TACENS RADIX II 420 Watts power supply for 220 Volt to 600 Watts AGIL-PS600-P4 110 Volt new power supply and the PC doesn't boot, just fans move slowly. Why?
  • 977 Answers
Hi!
First, unplug the power cord from the computer.
Push the power button of the computer several times.
Reconnect the cable and try powering up again.
Next, double check all internal power connections...
It's only a thought, but it sounds like you forgot to connect the 4-pins extra power connector:
Some graphic cards demand extra power (and have a special connector for it); If your card is one of those, make sure to connect it as well.
Also, most power supplies have a switch for 110-220V. Make sure yours if properly adjusted to 110V.
At last, take a look at those tips. Maybe it's just a coincidence that your computer doesn't boot now, and there's other reason for this problem.
Good luck,
Pelu.
Posted on Jul 06, 2010
  • vruiz228 Jul 06, 2010
    thanks for the answer. I thoroughly checked all connections, including the four pins auxiliary plug, the video card is a simple NVIDIA FX500, the monitor says no signal, after pressing power button with 220 volts power supply, only the fans move slowly, when powered with 110 volts nothing happens.
  • Ran Kedar
    Ran Kedar Jul 07, 2010
    It sounds like a faulty power supply if it doesn't even power up on 110V. It's like the 220-110V switch is only "for decoration".... Try using, as a check, another power supply, preferably of other model.
I wish to take the Ellure Plus machine to India where the power supply is 240 volt. What shall I do? What is the power requirement in Watts for this machine. Your feedback is highly appreciated.
You will need to check with the instruction manual of your machine what the specifications are.
Today the 120 volt mains, I am told, is almost a thing of the past and 220 volt is much more common. The UK mains electricity used to be 250 volts but it has been lowered to 240 and eventually it will be lowered to 230 volts to bring us closer to the European specification.
Because most electrical equipment is imported and we are a minority market, electrical manafacturers didn't want to produce specail goods just for us and so for 20 years or so most of our electrical goods are suitable for use in a range of mains voltages from 220 to 240. Sometimes they are marked as such and sometimes marked as 230 volts but we are told 240 won't damage them and they will still work efficiently at 220. It is only very old electrical equipment made for 250 volts that seems slightly less efficient.
Some equipment is made for universal use and will accept 120 volt mains as well as the 220 to 240 range. In this case there is usually a provision to select a different voltage by means of a switch or by changing some simple internal wiring connections. Details of how to do this is invariably printed in the manual.
Equipment produced for 110/120 volts only would become dangerous and be soon destroyed if plugged directly into a 240 volt mains but a transformer can easily be obtained to allow 120 volt equipment to be used on 220/240 volt mains. A great many professional tools are still produced to use 120 volt electricity for reasons of safety and so auto-transformers of all sizes are commonly available and not too expensive.
I have a fairly limited experience of sewing machines but I think a domestic machine has only a very small appetite for power and a supply suitable for a reading lamp will be more than adequate. The exact wattage of your machine will be found in the instruction manual.
Apr 10, 2016 | Sewing Machines
India 220watts how I cAn use brother cs6000i sewing machine in India
The only way I know is a 110/220 volt transformer.
They are available in any electronics supply house.
As I remember the motors in these machines are only two lead, and they put the motor in for the country it will be sold in.
Dual voltage motors have three or four leads (wires).
Jul 28, 2015 | Brother CS6000i Computerized Sewing...
Panasonic th42ph10uka can work with 220 Volt ?
The power supply can be changed, but it is a very skilled work.
Apr 02, 2013 | Televison & Video
Modifying Power Supply for 220 to 110
If you cannot get a ECU board from HP to replace the 220 volt model.
Then
The easiest solution, use a stepdown transformer fro 22m to 110 volts. Make sure the stepdown ransformer has a power rating that can supply enought watts to run the printer.
Mar 25, 2012 | HP LaserJet 1300 Printer
I want to buy a brother pc-420 in australia, how do i achieve that?
I suggest to ,, on the internet look for sewing machine shops in your town in australia, & even look in the phone book in the yellow pages
do you have a hancock fabric in your area? they have sewing machines & sergers
Feb 11, 2012 | Brother PC-420
I have a electric dryer Model WED5810SW0 THAT I WAS TOLD I COULD CONVERT TO 120V from 240v is this true and if so how do i do this?
If you consider doing this the first thing is SHUT THE MAIN BREAKER OFF. Use an auxiliary light source to see when working in a dead panel. Always keep in mind an ARC FLASH ACROSS HOT MAINS HAS ENOUGH HEAT TO PEAL THE SKIN OFF OF YOU. Before an explanation of how to do it you should keep in mind that this is for a single receptacle only. If any other receptacles are on the same circuit they will also be changed to 240 volt receptacles and if you plug any 120 volt device into them, the 120 volt device will be destroyed. That said OK, any 120 volt outlet can be changed to 240 volt by removing the 120 volt circuits neutral, re identifying the white wire with red or black phase tape and connecting it to a new 2 pole 15 amp breaker. The maximum that this circuit will now load up to is, on #14 wire at 80% = 12 amps at 240 volts. The 120V receptacle must be changed to a 15A - 240V receptacle so that 120 volt devices can not be plugged into it. Never use 2 single pole breakers together because code requires that on a fault trip both legs of the 240V circuit must be disconnected simultaneously. OR USED A Quick 220 Voltage Converting Power Supply
Voltage converter buying guide. Voltage Transformer Buying guide.Voltage converters also known as voltage transformers are devices that convert foreign electricity to power devices from different parts of the world. A step down voltage converter is a 220 to 110 volts converter. A step up converter is a 110 volts to 220 volts converter. Our 2-way converters are voltage transformers that convert power from both 220 to 110 volts and 110 to 220 volts. They also work with 100 volts, 110 volts, 120 volts, 220 volts and 240 volts. This model is a 2 way voltage converter / voltage transformer available in many different sizes including 100 watts, 200 watts, 300 watts, 500 watts, 750 watts, 1000 watts, 1500 watts, 2000 watts, 3000 watts and 5000 watts.
Sep 07, 2011 | Whirlpool Dryers
My Dell XPS 420 will not turn on. Power light
Hey! Nice Computer! ( At least while it was working! Specifications show some high-end hardware parts)
Steady amber light on the Power On light, means a bad power supply.
The Dell XPS 420 uses the standard ATX style of power supply found in 90% of computers out there.
(Personal computers. Not the Cray Supercomputers!)
This is Dell Support, and the User Manual - Removing and Replacing Parts - part of the manual,
http://support.dell.com/support/edocs/systems/xps420/en/OM/HTML/parts.htm#wp1466871
From Me:
1) Computer unplugged from power, computer case open. TOUCH the metal frame BEFORE you reach inside.
Your body carries Static electricity.
Static will fry out computer hardware components.
You won't see it, or feel it.
Computer unplugged from power, you are safe.
Touch the metal frame Before reaching inside, your computer is safe.
Should you get up for any reason, walk away, then return, Touch the metal frame again)
You either have a 375 Watt, or a 425 Watt power supply.
I would recommend a power supply with more Wattage, and more Amp's on the 12 Volt power rail.
The Dell XPS 420 comes with an Intel Core2 Duo processor, or an Intel Core2 Extreme processor.
These puppy's can use a lot of power when gamin', or other intense programs are being used.
The Nvidia GeForce 8800 Series of graphics cards offered, use a lot of power when maxed out.
The motherboard with the Intel X38 motherboard chipset, uses a lot of power.
I would recommend a 600 watt power supply for a replacement.
My recommendation would be an OCZ StealthXStream 600W
Why?
1) If the temperature of this PSU is kept under 118 degrees Fahrenheit, the PSU can put out 728.8 Watts reliably. (47.9 degrees Celsuis)
2) It has Four - 12 Volt power rails.
EACH power rail can handle 18 Amps.
That's a total of 72 Amps!
3) It has all the power cables you'll need.
A) 20 + 4-pin ATX motherboard power cable
B) 8-pin 12 Volt power cable (8-pin EPS)
C) 4-pin ATX power cable
D) SATA power cables [ 3 ]
E) Peripheral power cables, (4-pin Molex) [ 6 ]
F) 6-pin PCI power cables. [ 2 ]
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3092557&CatId=106
Not advertising for the above website, nor the PSU manufacturer. Recommendation supported by personal preference, and experience.
Information about the various PC power cables and connectors,
http://www.playtool.com/pages/psuconnectors/connectors.html
Jan 04, 2010 | Dell XPS 420 PC Desktop
Just installed new steam shower, it produces steam for about 5 minutes and then blows the fuse
Based from your comments, a new steam shower that blows the fuse in five minutes. You could have installed a new steam shower that is much bigger than what you previously have.
1. For a 5000 watts steam shower at 220 volts
power must have a fuse rating of 40 amps, supply
wires of at least No. 6 AWG Type THW ; and at
110 volts a fuse rating of 80Amps, supply wires
of at least No. 2 AWG type THW.
2. For a 4000 watts at 220 volts, Fuse: 30 amps,
Supply wire: No. 10 AWG type THW. At 110volts
60 amps, Supply wires : No. 4 AWG Type THW
3. For a 3000 watts at 220 volts, Fuse: 20 amps
Supply wire: No. 10 AWG type THW; At 110volts
Fuse: 40 amps, Supply wire: No. 6 AWG THW
4. For a 2000 watts at 220 volts, Fuse: 15 amps
Supply wire: No. 10 AWG THW and at 110 volts
Fuse: 30 amps, Supply wire: No, 8 AWG THW
Nov 27, 2009 | Hammering
I am moving to a 220 volt country
Get a transformer to take with you, but make sure it is sufficient
for the watts of the Keurig.
Aug 21, 2008 | Keurig B70 Coffee Maker
HP laptops power supply
Well, as a rule for electronics:
The United States and Canada use 110-volt electricity.
Most countries outside North America use 220-volt electricity.
Unless your appliance is dual voltage, you need to use a "converter" or a "transformer" to change the 220-volt electricity into 110-volt electricity in order to use a 110-volt appliance.
If your appliance is dual voltage, you can switch it to work on 220-volts, without a transformer or converter.
HOWEVER
Desktop units have a selector switch for 110 / 220 volts., which is done away with in the case of laptop one's which sense the input voltage and regulate accordingly.
I think your main concern is just that you have an adapter for the plug to go into the wall outlet.
Hope that helps :)
TM
Apr 15, 2008 | Computers & Internet
MSI MS-6758-040 Motherboard Logo
41 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
