My friend is trying to connect to msn and it says the default gateway has a problem. can u help?
    President:
  • 2,712 Answers
You may want to contact your internet provider and get them to help you with this one, as gateways differ from provider to provider.
Posted on Apr 18, 2008
  • 2 more comments
  • Swilin Sampson
    Swilin Sampson Apr 28, 2008
    Just checking to see if your issue has been resolved… If
    you find that the solution/answer I provided led you to, or resulted in a fix,
    please close the ticket with a FixYa! Rating under my solution.
    I
    would be very grateful for your show of appreciation.
    Should you have any further questions, please feel free to
    post them here.
    Thank you for using FIXYA!
    Cheers!
    IrishDruid
  • Swilin Sampson
    Swilin Sampson May 03, 2008
    Just wanted to inquire if your issue is resolved, or if there is anything
    further I can do to assist you…
    If you find that the solution/answer I provided led you
    to, or resulted in a fix, please take a moment to close the ticket with a FixYa!
    rating under my solution.
    I would be very grateful for your show of appreciation.
    post them here.
    Cheers!
    IrishDruid
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    P.S. -You can rate this solution with one of
    four votes, if you feel your issue is resolved.
    • "FixYa!"
      - The solution provides great advice on how to solve the problem.
      (Positive Rating)
    • "Helpful"
      - The solution provides useful leads that helps solve the problem.
      (Positive Rating)
    • "Thanks
      for Trying
      " - The solution does not solve the problem but the
      effort is appreciated. (Negative Rating)
    • "Inappropriate"
      - The solution has absolutely nothing to do with the problem.
      (Negative
      Rating)
    If your issue is not still not resolved, do not
    assign a rating just yet. Please post back as to what steps you took, results,
    etc, and I will try to assist you further as best I can.
    IrishDruid
  • Swilin Sampson
    Swilin Sampson Jun 28, 2008
    Kindly close this thread with a “Fixya” rating if you have been able to
    fix the problem, so that I can remove it from my work queue.
    If the issue is not resolved, please post back with latest developments, what
    steps you took, etc. and I will assist you further as best I can.
    Thank you for understanding,
    IrishDruid
Trying to connect multiple computers but need wep code . where is it?
Hi Friend,
Please follow the steps in order to retrieve the WEP code from the router.
1. Click Start\ Run\ type cmd and hit enter.
2. In the black window type ipconfig and hit enter.
3. Note down the default gateway and close this window.
4.Open web browser and type the default gateway adn hit enter.
5. If you have not changed the default password of the router then type admin as the password and leave the username blank.
6. In the router setup page click Wireless and then click Wireless Security.
7. You may note down the passphrase and try to connect the wireless devices with this passphrase.
8. in case if there is something written in Key 1, then try this instead of passphrase.
I hope this will resolve the issue.
Regards
Chiranjeet
Dec 10, 2010 | Linksys WRT160N Wireless Router
How to open the key ports for windows XP professional
You have probably set up your system to use DHCP - that is non-static IPs.
Right Click on your connection, go to properties, click IPv4, properties again
if it says get settings automatically then you are using dynamic IP addressing DHCP... this can cause problems,
To set up your Static IP on your computer
you will need your routers default gateway
you get that by typing ipconfig at the command prompt... found under Start menu ->Accessories, Command Prompt
Type in IPconfig
look for default gateway - write it down.
Go to your ISPs web site and see if you can find their DNS server IP addresses -or search under google - as a last resort use these
62.24.199.13
62.24.199.23
All DNS servers are public and free to use.
Then enter your Static IP which is derived from your default gateway. So if your default gateway is 192.168.1.1 then your IP can be anything between
192.168.1.2 and 92.168.1.254
Subnet = 255.255.255.0
Enter your default gateway
Enter your DNS server IPs and you should be good to go....
Remember if it all goes horribly wrong for some reason (It shouldn't) then just return and reset everything to get settings to automatic and all will return unrtil another solution is discovered.
Oct 06, 2009 | Microsoft Windows XP Professional
I have a zyxel router, after connecting to the laptop via wireless, sometime it cant load the webpage such as www.google.com. but the wireless signal there showing "Connected" with full tab. After once...
well!! I have an answer for you.your comp is loosing the IP address. goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center in vista and network connection under control panel in XP,IN Vista,click on view status,goto properties and double click on internet protocol(tcp/ip) or IPv4In XP,right click wireless network connection and goto properties and double click on internet protocol(tcp/ip).type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
Jul 01, 2009 | Zyxel ZyAIR B-100 802.11b (AM5009004)...
PLEASE HELP ME I CANNOT CONNECT WITH MY FRIENDS BECAUSE MY VERSION IS UNAVAILABLE PLEASE HELP ME WITH MSN MESSENGER THAT I CAN CONNECT WITH SOMEBODY please
This is your alternative MSN web
http://webmessenger.msn.com/
select on line
select start MSN web mesenger
If you see somebody elso e-mail add yours by selecting sign in with diferetn e-mail .
your password n enjoy.
Your Rating is very important to me
Was this helpful?
May 16, 2009 | Google Computers & Internet
Many websites are not loading. MSN, Microsoft, etc.
There are a few ways to get this going again.
Goto your control panel;network places;show network connections
Right click your connection, disable it, unplug the power cord from the modem itself for 10 seconds, click the reset button on it, plug it back in, enable the connection, repair.
You can also go into your command prompt.
start;programs;accessories,command prompt
type:
ipconfig
You should see 3 sets of numbers- IP address, subnet mask, and default gateway. If all the numbers are zero, that's a problem!
type this next, remember to have a space before the forward slash:
ipconfig /release_all
after that
ipconfig /renew
Try connecting and let me know what happens
Apr 08, 2009 | Actiontec Computers & Internet
Webcam not workin on msn but workin on the notebook how do i get it to show up on msn messenger
Can you see an option of Live Update on the Acer? you will need to run that, download all updates, reboot & it should work ok for you then. Hope that helps. Merry xmas.
Dec 10, 2008 | Acer Aspire One PC Notebook
Gateway appears to be offline
It is best to use the reset button on the router to start over.
if it then connects you will have to reset all the passwords and setting you had previously.
Jan 26, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
Does not work!!!
type 192.168.100.1 in your browser
Dec 08, 2007 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Getting booted???
If your internet connection is fine elsewhere - you are being blocked by Yahoo/Msn Regards, Freddie
Sep 07, 2007 | Gateway M305CRV Notebook
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
