Net connection even thought I have a net connection , I get thrown from the net all the time.
  • Missuri Apr 28, 2008
    Actually I did that in the past by clicking Fix ya 3 times , don't know why it wasn't showing. Thanks for your help anyway, however, I have to reinstall the software in my router,so I asked one of my friends and he will take care of it soon.
    Nice day
    Missuri
    President:
  • 2,712 Answers
Do you get any error messages? Or do you just get disconnected often? If it is the second scenario, I recommend you contact your internet service providers. They may be in a better position to help.
Posted on Apr 18, 2008
  • Swilin Sampson
    Swilin Sampson Apr 28, 2008
    Just checking to see if your issue has been resolved… If
    you find that the solution/answer I provided led you to, or resulted in a fix,
    please close the ticket with a FixYa! Rating under my solution.
    I
    would be very grateful for your show of appreciation.
    Should you have any further questions, please feel free to
    post them here.
    Thank you for using FIXYA!
    Cheers!
    IrishDruid
Wireless adapter on toshiba laptop just stops working
On some laptops you can access the wireless adapter quite easily. perhaps it's only a bad connection, requiring some Electronic Contact Cleaner, or loose connection. Or the antenna, usually located behind the monitor, has a pinched , broken wire. The wire feeds through the hinges. Or , as you most likely suspect, the wireless adapter may be bad. I don't know the model of Toshiba. Take a look at this: http://www.youtube.com/watch?v=z19kc5fERsE
Dec 30, 2012 | Computers & Internet
I have a 97 Volvo 850 base model with the 2.4 engine. Engine stalls ONLY in hot weather. I've replaced the MAF 3 times, No OBDII codes are thrown. I replaced the fuel filter. Cleaned all electri
Fuel injection relay. It is located under the hood inside the fuse box. It is either red or green in color. It is one of the larger relays. This is classic symptom of these things going bad. The heat causes the relay to swell and not engage properly. They die out every couple of years. Usually the car will start again after it cools down.
Apr 17, 2017 | 1997 Volvo 850
Kia optima cluster pinouts
Sorry this sort of information isnt available even in the haynes manuals its like closely guarded secret and not even the dealers are told as the car is connected to the internet for any diagnostics .Frustrating i know but imagine for a mechanic like myself being thrown out in favour for a computer nerd with a white coat on and funny gloves on.Someone like me who can reset cars with rod brakes and remetal big end shells with some lead and spoke shave .Done years at school and earnt pennies whilst learning to be thrown on the scrapheap,and then nothing but semi skilled unit changers employed .Come back the trade unions
Mar 16, 2012 | 2005 Kia Optima
Garage door only goes one third of the way down and stops. It was about to hit the car and I hit the button a couple of times so that could have thrown it off. Any thoughts???? Thanks so much
hello sue... That activity must have thrown the door out of adjustment.. On the motor unit there are high limit and a low limit adjusting screws. The low limit screw needs to be adjusted to move the door down until it closes properly. Just adjust it 1/4 turn at a time and then test it to see where the door is at. Joe
Mar 28, 2011 | Electrical Supplies
My wife was driving her 97 bonneville she said it lost all power smoked really bad and barely made it off the road i cramked it over and it wasnt even trying to start would it be fuel or timing
Fuel or timing would not explain the smoke.
Start by checking fluids.
Then do compression check.
Watch for cam so that you can see if timing belt thrown.
You may find water on plugs or something.
Could have thrown timing belt, cracked a piston, etc.
Only after everything seems normal, then try starting fluid spray, to see if may be fuel problem.
Use inductive timing light to ensure spark.
Mar 12, 2011 | 1997 Pontiac Bonneville
Emgine ribuild question
Well, any lateral movement of the connecting rod with the piston is not acceptable because it could wear to the point of being thrown apart over time.
Also, pins can be pressed out, I believe, even though I have never done this.
I have overhauled a 1979 Honda Accord and took the pistons out, but the machine shop said that they were ok, at the time.
Jul 04, 2010 | 1997 Toyota Tercel
I have connected an HDMI cable to my Mitsubishi 837 Series television and all I get is a blue screen. The new device detected is not even showing up. I also have an HDMI cable connected to my blu-ray...
you may have to reset your net command setup. try to do a reset and unhook all devices. turn the tv on and the devices on. then hook up each device one at a time and set them up. i've seen some of these that wouldn't work at all and just resetting everything fixed the issues. the tv wants you to set everything up a certain way and hook up each device one at a time. if problems persist, check for software updates on either device.
May 26, 2010 | Televison & Video
While in Yahoo mail, it is sending me to a Google web page.
for this the net connections in slow loading the file
Apr 10, 2009 | Yahoo Mail
Wireless network connection paradox
terry i agree with you.goto cnet.com and upgrade your drivers.if the network is stable and others can access it your problem lies within your pc.first try to remove then reinstall your adapter,if this doesnt work get the latest drivers.
Jan 07, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
