Lose 3 quarts of oil within 1,000 miles driven
Is your car burning or leaking oil. If it's burning oil, you'll see a large amount of blue smoke coming out of the exhaust pipe. To find out if you're leaking oil, start parking in a different spot, or put a flat piece of cardboard under the front end of the car. Hopefully the oil will drip onto the area where you can determine where the leak is. If it's burning oil, that usually means a major engine problem. Such as piston rings, valve guides.......$$$$
Have your valve seals checked, Mits is back on valve seals leaking and burning oil.
Testimonial: "I will have this done and get back with you with a response, thanks!"
