Question about GE WBSR3140DW Top Load Washer
Ge washer overflows but stops overflowing when it is turned off - wondering if it is worth paying a repair person or if we should just scrap the washer and get a new one.
  • eweight Jul 06, 2010
    how much is it to replace a pressure switch? Because the washer is in the top floor of our home, it flooded our entire house - so I'm nervous...
    how much is it to replace the pressure switch?
  • 166 Answers
First check the hose that is attached to the pressure switch to make sure that it is not plugged up with gunk down inside the machine where it attaches to the outer tub of the machine. Clean out the hose and the connection that it is attached to. Also check for holes or crimps in the hose.
Posted on Jul 20, 2010
  • 523 Answers
Pressure switch is bad
Posted on Jul 06, 2010
Washer overflowed after moving Load Capacity Switch from Super to reset and then to Large load?
On this model of washer you have 4 separate components that could cause overflowing. The water valve, pressure switch, pressure switch hose & the air dome. If you have to turn the water off to prevent overflowing, I would recommend replacing the water valve. If you can turn the timer off & the water stops overflowing, I would recommend checking the pressure switch, hose & air dome.
Jan 16, 2011 | GE Washing Machines
Myn washer always overflowes as it filling it wont
This is usually the pressure switch. Also you could check the water inlet valve if water is still flowing in the machine after it stops. There are free videos on testing these components at www.appliancehelponline.com/servicemanual.html
You can also punch in your model # for diagrams
Mar 18, 2010 | GE Washing Machines
Washer is filling too much and water is coming out overflow
you need to clean the pressure swith hose on the lft side of tub small rubber hose stop use in liqid soap
Jan 30, 2010 | GE Washing Machines
When washing or rinsing water spills over the top of the tub and on to the floor
the transmition is bad,it does not hold the inner tube in wash cycle.as the ajitator work's the inner tube turns at the sam time,the inner tube turns faster and faster and a cyclone efect happens and the water go's out the overflow tube.the cost of repair would exceed the worth of the unit.
Dec 22, 2009 | GE Profile WPRE6100G Top Load Washer
It is leaking during the washing and ring but not the spin or drain
Check to see if the washer inner tub is spinning during the agitation. If it is it is causing the water to spin up and over the side during the wash cyle. Bad brake package and usually not worth repairing. You can also have too much high sudsing soap in your washer, causing it to over flow out the safety overflow pipe. Good Luck Appliance Specialists.
Dec 14, 2009 | GE Washing Machines
My washing machine is overflowing
I replace the inlet water value. The part was less than $40.00 and took about 30 minutes to do.
Mar 23, 2009 | GE Washing Machines
GE WBSR WASHER WATER OVERFLOWS
He probably disconnected the water level sensor when replacing the belt or the timer is dead.
Check for any unconnected sensor or check if the main program button is turning propely..
cheers
Dec 20, 2008 | GE WBSR3140DW Top Load Washer
GE WJXR2080T2WW Washer Fills with water - then stops
older machine would have been easier to fix ..remove front ck small hose to tub left side remove hose and clean crud from end as much as possible if still overflowing replace water level control..new machine may be timer or lid switch not closing properly remove front to acess lid switch on right side
Jul 22, 2008 | Washing Machines
Overflow
If you unplug the machine and the water still comes in, you have a bad Water Inlet Valve. If when you turn the machine on at in overfills and you can stop the water by turning off the washer timer then you have one of a couple possible issues.
First, you pressure sensing tube could be clogged
Second, you just plain have a defective pressure sensing switch.
If you have anymore questions, feel free to comment back.
Thank you
Mar 26, 2008 | Hotpoint VBSR3100D Top Load Washer
Hot water continues to run after rinse, filling tub overflowing
sounds like you are right the water inlet solenoid on the hot side is sticking remove the hoses and clean th escreen out and the valve try agin with a fill on hot to see if it stops on a small load if not replace the water inlet valve
Mar 15, 2008 | GE WVSR1060A Top Load Washer
GE WBSR3140DW Top Load Washer Logo
231 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
