I have a frigidaire affinity washer and it makes a buzzing sound when it washes the clothes. this sound gets louder or softer when you touch the door.
  • bwilley Apr 24, 2008
    I have a the same issue. When washing my machine buzzes. Its totally related to the door. When you push in on the door it stops. I called Frigidaire and they said i had error code 41. To check our code hold in the start and cancel buttons. This required a service person to come out. They have not yet been out so I do not know the results but I can tell you once you push the cancel and start buttons the machine now wont start. If you are having the same problem be prepared to be without your machine before you push these buttons. I am very disappointed with this product. I only bought it because consumer reports rated it #1. Imagine that. I suppose thats just bad luck; I got the lemmon. Either way I will not purchase another Frigidaire machine again. First and last.
  • Anonymous May 05, 2008
    I have the same exact problem and found this site via search for Frigidaire Affinity buzzing. Will update if find a solution to the problem. What a pain. Great washer though!
  • 145 Answers
The door lock makes this noise. It is held on by the two screws you see when you open the door. You have to take the front of the door boot loose to change it and you don't have much room to work.
Posted on Apr 18, 2008
Washer states sensing with a buzz sound?
Hello keisha, thank you for your post!
I understand that your Frigidaire washer is making a buzzing sound until the cancel or start button has been pushed. It sounds like it could be a possible issue within the door either not being fully closed or it could be a defective switch. I would recommend resetting your appliance which can be done by disconnecting power to the appliance for roughly ten minutes. Please comment back if that did not help correct the issue. -Matt
Sep 05, 2014 | Frigidaire Affinity ATF7000E Front Load...
My frigidaire affinity front load washer buzzes and will not cycle what wouldcause that?
Good Morning Friend,
I see that your Frigidaire Affinity washer, model# ATF7000E, is buzzing and will not cycle. Some possible causes of this could be:
-Your washer is overloaded with clothes. Try taking some clothes out and restarting.
-There could be an article of clothing that might have slipped in between the gasket and the drum that might be stopping the drum from spinning. Check to see if there are any clothes that might be missing and possibly stuck between the drum and gasket.
If you have tried the above solutions and are still having trouble, I suggest giving your washer a hard reset. You will do this by either unplugging it or shutting the power off at your home's circuit breaker for 2-3 minutes. After the time has passed, restore power and start a cycle. If your appliance is still buzzing and not spinning, I suggest that you contact your local authorized technician for further assistance. They will be able to diagnose your washer and determine the cause of the buzzing and why it is not spinning. Hope this is helpful.
-Best Regards-
WP
May 05, 2014 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire Affinity Washer making clicking sounds after power outage.
Sounds like either the control board or the timer is faulty at this point. Contact a professional so they can diagnose the unit fully and repair where needed.
Jul 28, 2012 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire Affinity Glacier Stackable upright washer. Washer will not agitate and makes a buzzing sound from the pump that extracts water from the drum. Water collects and remains in bottom of washer.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 29, 2010 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Error code ESE
This is a problem whith your speed controll replace the the speed controll in the bootom of the washer
May 24, 2009 | Frigidaire Affinity ATF7000E Front Load...
I have a affinity Frigidaire dryer and it won't run on, it makes
A buzzing when you start the dryer sounds like a motor is faulty or something is stopping the blower wheel from turning.
Feb 19, 2009 | Frigidaire Affinity ATF7000E Front Load...
MY AFFINITY WASHER WONT WORK
It is the door lock that may be broken, that's what happened with my maching last summer. The lock is made of plastic if you can imagine. So if you slam the door it can break. A washing machine gets wear and tear how can closing a door be owners fault?
This is a crappy machine in terms of maintenance, it is a maintenance nightmaire!!
Oct 30, 2008 | Frigidaire Affinity ATF7000E Front Load...
Washing Machines Logo
119 people viewed this question
Top Washing Machines Experts
