Question about Canon Office Equipment & Supplies
I have a Canon MP600 and with all cartridges full the screen keeps saying, "More Than One Ink Tank of The Following Color is Installed" - and it refers to the black on the far left that does not indicate that it is empty. Ditto on the 8M tank that just got replaced. Any suggestions? Jack Stengel "jstengel@sio.midco.net"
  • 600 Answers
You may try cleaning the part where the cartridges meet, it is often copper use a cotton cloth and clean with a very light pressure,
If it doesn't solve the problem you may try using another ink cartridge or try to use your cartridge on other printer of the same model,
I would suggest you use original ink cartridges because using non genuine inks causes errors such as this, may i suggest you check also your cartridge for the possibility of it not being genuine or just a replacement part
Posted on Jul 06, 2010
Showing Check Ink U051 COL. Have removed the
Hi there
For troubleshooting purposes,
Perform the following:
1. Open the printer and remove all ink tanks.
2. Insert a single ink tank in the printer then close the cover.
3. Confirm whether the printer recognizes the installed tank
properly. If it does, it will indicate it does not detect the other ink tanks, as
they are not currently installed in the printer.
4. Repeat steps 1-3 with another ink tank.
5. If the printer at any time indicates two of the same ink tanks are
installed, the cause will be the last tank installed. For example, if
you inserted an ink tank earlier, and you later inserted another ink
tank, and it said two of the same inks were installed, the cause of
the issue is the last ink tank.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 10, 2010 | Canon PIXMA MX310 All-In-One Printer
I get the U043 error on my Magenta. Cartridge is set properly.
Ink tank not installed.
[1660]
U043 (Applicable ink tank
icon)
The following ink tank
cannot be recognized.
Install the applicable ink tank(s) properly,
and confirm that the LED's of all the ink
tanks light red.
Sep 13, 2009 | Canon PIXMA MP600 all-In-One InkJet...
"More Than One Ink Tank Of The Following Color Is Installed"
Try using clean cotton cloth, like from an old t-shirt, and clean the contacts on both the ink cartridge and the seat inside the slot where the ink cart goes. If you clean them both, for each cart color, you might fix this problem.
Be sure that the power is off when you do this first!
Jun 21, 2009 | Canon Pixma MP800 All-In-One InkJet...
CanonPIXMA iP90 Color Ink Tank installation problem
yeah it sounds like a cartridge sensors are stuck or broken. i would say to replace the whole print unit. It will need a service support dealer to fit this part unless you can buy it and fir it yourself.
part number: QM2-2020-020
hope this helps
Oct 20, 2008 | Canon PIXMA iP90 Mobile Printer
Canon mp500 printer
plz check you have placed the ink tank in the appropriate slot otherwise you have to try with new one
Aug 31, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Canon IP5200 printer - "duplicate ink tanks"
Hi i have Ip 5200 but the pawer lamp and yelow lamp are blink
Mar 26, 2008 | Canon PIXMA IP5200 InkJet Photo Printer
MP500 ink tank cannot be recognized error U043
Same problem - two solutions I found helped me work out mine. One said contacts needed to be cleaned and it worked to use a Q-tip and alcohol or just click it in position several times until it recognizes the cartridge - this may work. Another said that they got it to work by installing a brand new cartridge - cool, but I have one full of ink it won't recognize. So I pulled the little circuit board off a used cartridge (like you need to do with some refills) and put it on the cartridge that it wouldn't recogrnize - works great. Still haven't figured out how to get it to acknowledge ink levels though. Canon really should be more consumer friendly since these problems seem to be intended to compel the use of proprietary cartridges.
Dec 27, 2007 | Canon PIXMA MP600 all-In-One InkJet...
Error code: U150 The following ink tank cannon be recognized (Cyan)
U150 ink error fixed!
I too was getting the error for unrecognized ink cartridge. Then the little green circ board fell out of the end of the ink cartridge and it hit me that maybe if I put in the little green circ board from the old ink cartridge of the same color, then maybe the ink cartridge would be recognized. It worked! So don't throw out an ink cartridge that still has ink just because of that error and hold onto your empty cartridges in case you need the little green/gold circ boards.
This works!
Dec 26, 2007 | Canon PIXMA MP600 all-In-One InkJet...
20 people viewed this question
old marine
old marine
