Question about NewAir AI-200SS Stainless Steel Ice Cream Maker
When I start the machine, the water flows about 20 seconds after the tray is full? The cubes are about 1/2 normal size when a cycle is finished. It will stop before a complete tray of ice is made, usually after 5 or 6 cycles.
  • 2 more comments
  • arizonagn Jul 06, 2010
    I have Newair AI-200 ice maker and when I start the machine, the water flows about 20 seconds after the tray is full? The cubes are about 1/2 normal size when a cycle is finished. It will stop before a complete tray of ice is made, usually after 5 or 6 cycles.
  • arizonagn Jul 07, 2010
    This is a portable ice maker by NewAir, model AI-200.
  • 484 Answers
There are several causes that may be attached to this problem, and common solutions to them, are as follows:
  1. Shut off the ice maker dispenser completely. Look behind the appliance. You'll see a long, narrow tube. This tube is the ice maker dispenser water line. Disconnect the ice maker dispenser water line from the unit.
  2. Flush the ice maker dispenser water line with hot water. Examine the water line for dirt, mold and clogs. Clean the tube thoroughly. If the ice maker dispenser water line is very dirty or completely blocked, replace it with a new ice maker dispenser water line tube. If you can unblock and thoroughly clean it, replace.
  3. Turn the ice maker dispenser back on. Wait for it to cycle another round of ice. The ice being dispensed from the ice maker dispenser should be the correct size pieces. If the ice from the ice maker dispenser is still small, continue to the next steps.
  4. Place a freezer thermometer in the freezer section of the appliance. Allow it to read the temperature. Read the thermometer. Adjust the freezer temperature to 8 F degrees or less to allow the ice maker dispenser to completely cycle. If the temperature is too high, the ice maker dispenser won't be able to do its job and completely cycle. Cubes will be smaller than they're supposed to be when spit out by the ice maker dispenser unit.
Posted on Jul 07, 2010
  • 2,272 Answers
If it stops midway before all the water is used, try leveling the ice cubes in the tray. The portable ice makers function on valves.If the valves gets stuck after few cycles then it will stop functioning. Get the water valve checked. These machines turn the water stored in molds and placed inside it into ice. Either a valve for constant supply of water is present else water can be poured into the unit as and when required. The valve can be connected to a tap using a small hose pipe. The cooling unit present freezes the water into ice. Thermostats may be present to allow the user to set and adjust the temperature if required. A drain pipe is available that allows drainage of any excessive water.
Check out this valve if its checked ok then other cause can be fault in thermostat if it stops functioning then unit will stop in between. and the last thing to check is the internal circuit control board.If its getting overheated due to short in internal wiring then this can be the issue.I think circuit board can be the problem because as you mentioned in your question that it works for few cycles then stops before forming ice.So this time the control board got overheated. This short has to be checked with meter and also the thermostat. Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
  • raj somaiya
    raj somaiya Jul 07, 2010
    Keep updated with what faulty part you get after you test all the mentioned possibilities.
    The water valve,the thermostat and the control board.
    thanks.
  • 677 Answers
Hi, Having an ice maker is a wonderful convenience, but when it stops working it can be terribly inconvenient. It can be too expensive to call a repairman when the rest of your refrigerator and freezer is working perfectly. Before you go out and buy a few ice trays, take a few minutes to see if you can resolve the problem yourself.
Things You'll Need:
  • Refrigerator
  • Refrigerator manual (optional)
First Steps
  • Step 1 Check your ice bucket. If it is not inserted properly, then the sensor beam may be blocked and cause the ice maker not to cycle.
  • Step 2 Check that the ice maker shutoff arm has not been triggered. Usually ice makers are turned off by lifting the arm up.
  • Step 3 Turn the ice maker switch off for a few seconds. When you turn it back on, it may reset the system and cause the ice maker to cycle normally.
  • Read more: How to Troubleshoot an Ice Maker | eHow.com http://www.ehow.com/how_4760408_troubleshoot-ice-maker.html#ixzz0syouDpC6
    Check the back of your refrigerator to see if the water hose is properly connected. If it is not, there will be no water to make ice.
    Inspect the ice maker for any broken parts. If there are, then you will need to call a repairman or replace them yourself.
    Ice Trays or Mold is Not Being Refilled If the ice trays are not being refilled, then there is a problem in the water delivery system. Listen to see if you here the water valve being energized. If you don't, then there is a problem with the wiring or a bad valve. Call a technician to repair this problem.
    If the ice trays are not being refilled, but you hear the valve energize, then you could have a clog in the water line. Usually this occurs in the portion of the tube that extends into the freezer. Check to see if it is clogged with ice. If it is, use a hair dryer to melt the ice.
    Check the water filter. If it hasn't been changed within the last six months, it could be clogged. Take out the filter for a couple of hours and see if you get ice. Water will bypass the filter and go directly to the ice maker when this happens.
    Small or Too Few Ice CubesUse a thermometer to check the temperature in your freezer. It should be below 14 degrees Fahrenheit. If it is higher, try adjusting the thermostat on the freezer.
    Make sure that there is good water flow from the water line that is attached to the back of the fridge. The tubing may need to be cleaned or replaced.
    Make sure that the ice maker mold thermostat is cycling properly.
    Another problem that can reduce your ice cubes is the water-inlet valve. Try replacing this and see if it fixes the problem.
    Other Problems,
    If you find dark specks in your ice cubes, then the protective coating on your ice cube tray might be peeling away. If this happens, the best solution is to replace the ice maker.
    If the ice maker is make frozen cubes but not ejecting them, then it is most likely a problem with the mechanical module of your ice maker.
    If the ice tastes bad, then clean your fridge and freezer thoroughly and replace the filter. If your ice maker doesn't have a filter, then you may want to add a supply line filter.
    Take care.
    Posted on Jul 06, 2010
    • 3,083 Answers
    A sensor should be shutting the water flow when it becomes full. Either that, or the water shut off is faulty, or sticking. I went up on the net to research reviews, and I mainly found people were happy, or had problems with it, with little to no support, or poor support, at best. Here's the reviews, and one of them kind of fits your situation, but not quite. Sorry, that's all I have, since I've never serviced one. Here's the reviews:
    http://www.amazon.com/NewAir-AI-210SS-Portable-HighQuality-Stainless/product-reviews/B000N66I8O
    Hope this helps.
    Compressor hpco
    Compressor hpco or (High Pressure Cut Out) means the high side pressure has went over the limit the machine has been set too. The safety is there to protect the compressor. If the machine is water cooled, the water flow has most likely been interrupted. So often the machine was moved for cleaning and the wheel is on the water hose. If the machine is air cooled, Either 1. the fan has stopped, 2. the condensers are dirty or 3. It's just too hot where you are trying to run the machine.
    Soft Serve Parts C723
    May 06, 2017 | Taylor Ice Cream Makers
    I purchased the ice cream maker without a user guide. Is one available?
    Are you looking for operating instructions or recipes? Recipes available everywhere ... really. Operating? Here is what you do: Get some ice cubes ... crush them with a hammer ... you will need a lot ... the finer crushed the smoother the ice cream. Put the mix in the metal container and put about 4 -6 inches of ice in the bucket with some water. Put about 1# of rock salt on the ice. More ice ... more salt ... more ice ... more salt ... more ice ... more salt until the bucket is full. Start the machine. Your ice cream should be ready in about 1/2 hour. When the machine stops cranking ... remove the mixer from the can. If you can stand it ... let the ice cream sit in the container for 1/2 hour ... the longer you wait the better the batch. But who can wait???
    The ice cools the water, the salt reduces the temp of the water to cause the mix to freeze.
    I hope this helps you ... this is how we make home made ice cream every summer ... what a special treat for the kids ... young and old alike.
    Thanks for your question @ FixYa.com
    Mar 18, 2011 | Rival 8605-M 6 Quart Ice Cream Maker
    Polar Ice maker says low water level when full of water
    Replace the motor. During the cycle of the unit if the water flow circuit does not scence flow, the unit faults with a low water indication
    Jun 22, 2010 | Polar PIM15W Ice Cream Maker
    Clean light stays on,help me trouble shoot
    Fill water reservoir with 1/3 carafe distilled white vinegar, 2/3 carafe water and hit the self-clean button - it will take about 35 mins to complete. When it is done, it will beep like it normally does when brewing regular coffee. Self-clean light should go off after this. If it doesn't, simply unplug the machine for 20 minutes or longer. The manual is available for your inspection on the Cuisinart website.
    If your Cuisinart is one that is missing the Self-Clean function, just brew the vinegar and water like it is coffee by using the brew function.
    Sep 19, 2009 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
    How long does it take to make ice cream?
    Not long at all, maybe 20 minutes.
    Jun 02, 2009 | Ice Cream Makers
    No accumulation of ice
    Check to see if your condensor coil is clean, use an air compressor or other source to blow thourgh the coil,dont just brush it off. newer refrigerant charged systems need as much air flow as possible to work ,also make sure the cover is on the condensor section while the ubit is in nrmal operation. try setting the cube size to lowest setting and let run for 24 hrs. Let me know if you need further assistance.
    Nov 16, 2008 | Ice Cream Makers
    Cuisinart dcc-1150 coffeemaker
    To replace water filter: Pull water filter holder out of reservoir, snap open, insert new charcoal water filters (can be ordered from Cuisinart or purchased froma store like william-Sonoma)
    To clean machine: Run 2 cups water and 2 cups distilled white vinegar through machine like you would normal coffee.
    To get rid of annoying self-clean lite: unplug machine from wall outlet for 20 minutes or longer.
    -Tha Mp3 Doctor
    Oct 24, 2008 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
    Emerson IM90 Portale Ice Maker
    My friend bought this item last week at Target for the $99 sale price. The reviews were all horrible about the red light (add water) indicator going on after the first or several first ice cube runs and never going out. About 40 out of 60 reviewers had this problem. We experienced it right after the first run when the ice cube full light went on. We emptied it and the add water red light was on. I looked all over the web for a solution and only found one that suggested tilting the unit backwards for 45 degrees and that would magically reset the light. It did not after several angles, light taps and basic shaking. Since there was no alternative and everyone who returned it also got the exact same problem with the new replaced model - we decided to open it up and investigate.
    The electronics diagram is on the back of the machine and tell you where the water indicator is. We took it out (an inch long black tube along the water pump and backflow valve) and dried it completely. The cycle still had the red light. We submerged it completely in water and the red light still went on saying that the unit needs water. We determined that this is the bad part and the water indicator is faulty. We cut it out and joined the two wires. IT ALL WORKS NOW FLAWLESSLY. You only have to shut the unit off when you leave since it will ocntinue to run if out of water. If you're looking for a quick mechanical fix and have a unit that works when you need it and you are around - this isthe fix.
    Aug 23, 2008 | Ice Cream Makers
    Polar Ice Maker Portable
    there is a little sensor inside on the top right, it is a little wire if there is anything on it it will not work, i took at small pair of pliers and gently cleaned it
    Jun 21, 2008 | Polar PIM15W Ice Cream Maker
    NewAir AI-200SS Stainless Steel Ice Cream Maker Logo
    195 people viewed this question
    Top NewAir Ice Cream Makers Experts
    ray gallant
    Are you a NewAir Ice Cream Maker Expert? Answer questions, earn points and help others
