Question about Toshiba Computers & Internet
I have a Toshiba Qosmio F60 series. My son using
I have a Toshiba Qosmio F60 series. My son was using my laptop and some how turned off the wireless internet. I have tried turning it back on and it keeps popping up with refer to my manual for the location of the wireless communication switch which is located of the front or side of the computer. Which I did go through the manual and could not find anything in there relating to a wireless communication switch. I did notice there was a picture of an airel of the front of the computer but no switch.
We had the same problem and the above solution didn't work. It wasn't anything your son did, but obviously a problem with the computer itself. Disconnect from the mains and pull out the battery with the computer still going, then restart. When prompted just open Windows normally and the wifi was now functional again.
Posted on Jul 13, 2010
  • scarlettr769
    scarlettr769 Jul 03, 2013
    So simple that I didn't even think to try it. Worked PERFECTLY. Thank you.
  • 748 Answers
Do you have a similar aerial symbol on the F8 key? Or some other function key for that matter?
If so, try a Fn + F8 key combination (Fn is second in the lower key row, next to Ctrl). This should turn the wireless back on, and the LED with the antenna symbol you mentioned should light up. It should toggle the state each time you press this combination.
Good luck, and please leave a testimonial if helped :)
Posted on Jul 06, 2010
I can't log on to the internet on my Toshiba Qosmio F25-av205 laptop. It is asking me to turn on the wireless communication switch. I can't find the switch. Please help me. Thank you.
look on the right side of the laptop at the bottom of those indicator lights. try to slide and check if connection will be there.
thanks
Mar 28, 2014 | Toshiba Qosmio F25-AV205 Notebook
Qosmio f60 fan goes on high speed and freez. It keep freezing.The only way to reboot it is to hold down the power button to turn it off and then turn it back on.
I have the same "computer" qosmio f60. I've replaced the hard drive, installed a new window 7 OS, changed RAM paging, power options, run the things with a fan pointed at the computer fan.
The fan goes to high speed and the HDD LED unblinking. I've brought the laptop to two computer shops whose owners knew less about computers than I did. I tried to go to a Toshiba recommended shop in Toronto except they changed to Apple-service only. I tried phoning Toshiba, they just want to change 4 bucks a minute for technical assistance. I've had this Toshiba-thing going on 3 years with the troubles starting after the first year. No one cares about this problem. If I see a Toshiba factory I'm going to chuck this red brick of cra through the window.
BTW it's not a virus or rootkit. I had to learn how to partition a HDD sector through some crazy BIOS program before installing windows. There's no virus or rootkit that's causing this problem.
It's mostly been freezing on me with games.
Aug 31, 2013 | Toshiba Qosmio G15 Notebook
How to install windows xp in toshiba qosmio f30-112
If the Notebook cannot find the device driver it is looking for then use this restore disk for an easy solution.
WINDOWS IS NOT ON THIS RESTORE DISK
This restore disk will only work for use with Toshiba Qosmio F30-112. This restore disk contains every driver for the Toshiba Qosmio F30-112.
http://restore-disk.com/shop/CartAdd.asp?ID=149816
Toshiba Qosmio F30-112 XP ... windows XP restore disk is a one stop solution. The Qosmio F30-112 drivers in ... Toshiba Qosmio F30-112 XP Notebook plug and play will install ...
TOTAL: $15.92
hope this helps
Sep 12, 2012 | Toshiba Qosmio F30-112 Laptop DC Car...
I want ot do a fresh instillation of windows 7 on my Toshiba Qosmio f60 laptop. How do you do that without the use of another PC?
Insert the Windows 7 Install disk or upgrade disk in teh DVD drive of the laptop and boot the laptop. Windows will do the install process. Assuming that laptop supports Windows 7. Make sure you get the Windows 7 drivers for all your devices before you start the process.
Jul 15, 2011 | Computers & Internet
How do i remove back and reinstall fan?
Welcome to Fixya
Here's the procedure:
1. Shutdown the laptop and remove the AC adapter. Disconnect any devices, such as a printer or external DVD-ROM or drive, that are attached to the laptop
2. Remove the laptop battery. Turn the laptop upside down, slide the battery release latch and then pull the battery out of the bay.
3. Unscrew the hard drive cover. Grab the hard drive tab and shift the hard drive to the left to unplug it. Lift the hard drive out of the bay.
4. Unscrew and remove the PCI memory cover, the optical drive cover, and switch cover.
5. Unscrew the two screws that hold the keyboard to the base, these are located in the middle of the rear panel. Flip the laptop over so it is right side up, open and remove the keyboard by using the keyboard release switches located above the keyboard. Next, unplug the Toshiba Qosmio E15-AV101 Fan cable.
6. Close the laptop and turn it over so it is bottom up. Unscrew the display assembly screws located under the laptop screen hinges. Turn the laptop over so it is right side up. Open the laptop and unplug the display assembly cable and disconnect the wireless antenna from the display assembly. Unscrew the display assembly from the laptop base and remove.
7. Unplug the mouse pad cable. Turn the laptop over so the bottom side is up and unscrew the base screws which are located along all four sides of the laptop base. Gently remove the base of the laptop.
8. Turn the laptop over so it is right side up. Unplug the fan cable from the circuit board. Unscrew the screws holding the Toshiba Qosmio E15-AV101 CPU fan assembly to the laptop. Lift the fan assembly out of the laptop.
9. Insert the new Toshiba Qosmio E15-AV101 CPU fan assembly into the lap top. Screw the assembly unit to the lap top and plug the Toshiba Qosmio E15-AV101 CPU cooling fan cable into the circuit board.
10. Reassemble the laptop by repeating the previous steps in reverse order.
Thank you for using Fixya!
May 10, 2011 | Toshiba QOSMIO E15-AV101 Notebook
I purschased new notebook (Toshiba Qosmio F60-111) with windows 7, and found that the FN key not working, actually i don't know what is the driver name for that to install it from Toshiba site. please i...
Reference: http://www.ozzu.com/hardware/toshiba-laptop-problem-t52121.html
Resolved on my Toshiba by deactivating the Toshiba Flash Card program. Step 1. Press the "Windows Key" and R at the same time. Type msconfig and under start tab disable Toshiba Flash Card. Hope this works for you also.
Aug 01, 2010 | Microsoft Windows Vista Ultimate Edition
How do you reconnect wireless network connections on toshiba qosmio f25-av205 using windows xp have drivers but the wizard says diconnected
Ok, first you want to right click on my computer, select manage, services, and double click on wireless zero configuration and select automatically under startup type and click on start. Double click on the icon for the wireless zero configuration next to the clock. Select the correct wireless connection and click connect.
May 17, 2010 | Toshiba Qosmio F25-AV205 Notebook
My daughter put a password for the bios and cant remember it.
Try holding down the "Left Shift Key" when turning on the system
Nov 28, 2008 | Toshiba Qosmio G15-AV501 Notebook
Computers & Internet Logo
1,215 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
