Question about Globe Union Glacier Bay 8 In Double Handle Kitchen Faucet with Spray in Chrome F80246
We have a Glacier Bay goose neck kitchen faucet. It has separate handles for the hot and cold. I did not install the sprayer, i caped off the the opening where the sprayer would go with supplied unit from Glacier. Its a year old. Now..sometimes, not all the time, it makes a "singing noise" when hot and cold are turned on low.. I removed the aerator and cleaned it best i could.. the noise is not as bad now... but still happens now and then. Our water pressure seems low too.
  • 68 Answers
SOURCE: glacier bay kitchen faucets with 2 handles and a sprayer
to be honest with you if there is a problem the glacier bay brand is from home depot and they are usualy around 20 to 30 dollars the replacement stems are usualy 15 to 40 depending on the part plus the hours ur gonna spend fixing it your better off with a full replacement. if replaced keep in mind you might want to replace the supliy lines to the faucet with stainless steal suply lines to ensure no leaks and if your shut offs are old dont touch them shut off your water main and drain down your house by opening all the faucets and shower valvs in your house then drain at the lowest point in the house weather it be a sink in the basement or an out side faucet once the supliy lines and faucet is in place then close all the faucets you opened and slowly turn on the water to your house slowly and this will ensure you dont have any leeks from your shutoffs good luck  your friendly plumber
Posted on Apr 12, 2009
  • 23 Answers
SOURCE: moen kitchen faucet set wsprayer can't shut sprayer.
there is always water pressure on the sprayer when water is on. if sprayer is leaking check if trigger is stuck in . best to just change the sprayer handle it comes off at the base of the handle
Posted on Jul 20, 2009
  • 39 Answers
SOURCE: kitchen faucet leaking pull down sprayer spout type
try tightening the nut that attaches the flex line to the pull out spout
Posted on Aug 04, 2009
  • 349 Answers
SOURCE: I have a Glacier Bay(Costco) kitchen faucet. The
Check the weight and see if it has screws in it to move in on the hose line the distance it lacks retracting.
Most of them can be adjusted to proper retracting mode. It may have a couple of screws in it.
Posted on May 15, 2010
  • 349 Answers
SOURCE: kitchen sprayer/diverter
http://www.pricepfister.com/www/ImageAssets/mirror/model/kitchen/marielle/mar026-4n/26548-0500.pdf
Page 2 on this web site has the diverter listed. Sounds like the diverter is sticking or hanging up and not working right. The link below has information on the faucet you have so I hope this will be helpful for you.
First you could take it off and clean it and check it out for any blockage.
http://www.pricepfister.com/product_catalog/document_search_results.aspx?doctype=15&room=kitchen&collection=Marielle
Posted on Jun 06, 2010
How do I put seats and springs in a glacier bay Aragon three handle knobs
How to Repair a Glacier Bay 3 Handle Tub and Shower ...
www.faucetinstructions.com > Glacier Bay Faucet Instructions
My three Handle Glacier Bay Tub Shower Faucet Makes a High-Pitch Squealing ...The Glacier Bay tub faucet screw-cover buttons will not stay on the handles. ... Sealthe flanges to the shower wall with a high-grade anti-microbial kitchen and ...
Nov 07, 2015 | Plumbing
I have a glaicer bay kitchen faucet and when the water is turned on there is thumping. When I take the sprayer off the thumping stops.... is therea probelm with the sprayer?
to reduce the 'thumping' noise, open the supply valves more. If they are already at maximum, you may have a restriction further up the supply lines. Thumping is typically caused by unbalanced flow around the seat and washer, usually caused by restrictions.
Mar 03, 2014 | Glacier Bay Kitchen Faucets. Lyndhurst...
Wiggling Goose Neck
There could be loose hardware inside at the base of the goose neck. You will have to remove your carefully installed faucet and take a look inside to find out.
Nov 13, 2013 | Globe Union Glacier Bay 8 In Double Handle...
Have just installed glacier bay faucet model #8181/ 785 564 single handle with pull-out sprayer. once pulled out the sprayer will not re-seat into the faucet but hangs out about an inch or two. have...
Take it back to HD or Lowes where you got it and trade it in for a Delta....you will be glad you did... this is only the beginning of your problems....you get what you pay for...
heatman101
Apr 21, 2011 | Microwave Ovens
How to repair facet stem for glacier bay products kitchen sink
Theres not much you can do to repair the stem except replacing the small O-ring up inside. You can call Glacier Bay and ask for a new stem ( the faucet has a limited lifetime warranty. You can also use Delta faucet repair parts in your Glacier Bay kitchen faucet; they come from the same mold. Heres a link to Glacier Bay 2 handle kitchen faucet repair. Heres one to the Glacier Bay faucet manual for your faucet.
Sep 16, 2010 | Globe Union Glacier Bay 8 In Double Handle...
Single-handle Glacier Bay shower faucet, hot/cold reversed
Behind the handle check to see if it has a dail to take out and replace at a different postion this will change the hot and cold. It a anti scald protection device. Don't remove cartridge just adjust dail.
Mark where you start and take out and move a 1/8-1/4 turn at a time and replace til temp desired. It has teeth like a gear you move to adjust temp.
May 11, 2010 | Delta & Single Handle Shower Faucet
Hello. It sounds like your plumbing was installed wrong, with the hot and the cold supply lines reversed. If that is the case, those supply lines will have to be replumbed to make your faucet work properly. Often, if those lines are accessable, it is only a 20 minute job. Joe
Mar 18, 2010 | Delta & Single Handle Shower Faucet
Installed new faucet worked then all water stopped
If it has a side spray the diverter might be stuck. try flicking the spray handle on and off.
Jun 10, 2009 | Price Pfister Marielle Kitchen Faucet with...
Glacier bay kitchen faucets with 2 handles and a sprayer
Apr 12, 2009 | Plumbing
Globe Union Glacier Bay 8 In Double Handle Kitchen Faucet with Spray in Chrome F80246 Logo
336 people viewed this question
Top Globe Union Plumbing Experts
mike simpson
Tom Chichester
Don Tiff
Don Tiff
Level 1 Expert
Are you a Globe Union Plumbing Expert? Answer questions, earn points and help others
