Question about Bernina Activa 130
Sewing Machine Problem
I have a 830 Bernina Sewing machine and none of the zig zag stitches will work, blind hem, ect. Have any idea what the problem might be? I've had this machine for years and have never had any problems with it until now.
I would appreciate any help you might have.
Thank you,
    Problem Solver:
  • 5 Answers
Check to see if the cam stack gear does not have a crack in it. The other problem is the cam engager lever is does not engage the cam stitches because it is gummy. To solve this, lift the lid and follow the lever to where it make contact, add a penetrant oil. More the lever back and forth as fast as you can and work the penetrating oil into the area. It should click back and forth and snap between the back and front V's. One is for the zig zag and straight stitches and the other is for all cam patterns. Once it is clicking and snapping back add regular oil. Thensew out your pattern stitches. If the machine binds then you could have a cracked cam stack gear and has to be change by a Bernina service center.
Posted on Apr 21, 2008
If part of the selection lever is broken on the bernina 1030 can it be fixed
Depends on how it's broken, but as the saying goes - with enough time and money, anything is possible.
Nov 02, 2017 | Bernina Sewing Machines
I cant get my stitch Width Zig zag knob to turn om my bernina record 930. Any one have this problem?
Most likely because your machine has not been serviced (oiled & cleaned) in a long time and the old oil has turned to glue and seized. This is probably the most common problem with mechanical sewing machines. A mechanical sewing machine should be regularly every 40 hours of sewing use or at least every six months when not in use. You may want to take it to a Bernina service technician. Ask for a bottle of Bernina oil for CB hook machines and ask if they will show you how to oil it.
My machine Bernina 830 does not run
Bernina 830 won zig zag won buttonhole no decorative stitch
Bernina 930 Record oiling diagram
Questions Answers for Bernina seized Sewing Machines
Aug 14, 2016 | Bernina Sewing Machines
Hi, I have purchased an adjustable blind hem foot for my Classica 90. Would you please advise what the setting for blind hemming is on the sewing machine is? I cannot locate it. Thank you.
Perhaps this video will help:
How To Sew Blind Hem Stitch 2
Unfortunately, after reviewing your machine's manual, your manual does not indicate that your machine provides a blindhem stitch. The blindhem stitch generally is a stitch that takes several straight stitches and then zags to the left to catch the garment fabric. You can, however, use a zig-zag. You will just have more stitches into the garment that may show on the right side.
Aug 23, 2015 | Husqvarna Sewing Machines
Zig zag problem on Bernina 910
Have you rethreaded the machine, making sure to get the thread between the tension discs?
Jan 31, 2013 | Bernina Sewing Machines
Can't get the Husqvarna Viking Platinum 775 to do a zig zag
it's very possible that a cam or gear has worn down or broken
inside the machine and also if the sewing machine is computerized
then there could be a problem there, having the machine checked
would tell you for sure.
Nov 08, 2012 | Sewing Machines
Why won't my Bernina Activa 140 sew the blind hem stitch?
Are you absolutley sure you're not getting a problem with stitch formation on, for example, wide zig-zag. Check again, using a different colour top and bottom and make sure that the stitch is being formed properly with only the top colour on top and bottom colour on the bottom. It sounds as though the bottom loop is not being picked-up by the hook properly. Make sure you've thoroughly cleaned-out any fluff under the stitch-plate and remove the hook/shuttle and give the hook race a good clean and give it a single drop of oil, even if you've got the lightweight part-plastic hook/shuttle fitted.
Nov 19, 2011 | Bernina Activa 140
Trouble sewing lycra fabric using a zig zag stitch
You have the machine set for blind hem stitching. Change the stitch selector to stretch stitch, which is a single, in line stitching zig zag stitch.
Embroidery Services
San Diego, CA
Sep 13, 2017 | Sewing Machines
Does the singer 3116 come with a blind stitch for hemming
Most sewing machines come with a blind hem stitch. It is the one that looks like several small zig-zags then occasionally a large one, or several straight stitches then a large zig-zag. Either will result in an invisible hem.
Some machines have a special foot but it is not necessary, mine does not. There is however a special way of folding the fabric.
Or also an instructional video:
Hope this straightens things out for you!
Nov 06, 2011 | Singer 3116 Simple
I need to know how to do the blind stitch hem
here is a link to great info on which explains this technique with images,
In brief, you need to fold the fabric to be hemmed into a Z shape with the wrong side hem edge at the bottom of the Z.
The Blind stitch is either three straight stitches then a wide zig zag which swings to the left and catches a little bit of the folded edge, or three small zig zags, then one wide zig zag to the left to catch one stitch into the folded edge. The zig zag style has a little more stretch in it so works good on jerseys and knits.
tally_girl_0.gif You need to use the blind hemming foot which helps you to line up the folded edge and keep it at a constant distance from the needle. It will look like this.
tally_girl_53.jpg Turn the little silver screw to move the white plastic guide left or right until you've got just a smidgen of fabric being stitched by the left wide stitch. Always do a practice sample first to get the stitching and guide set right. On most machines you can vary the width of the big zig by adjusting the stitch width dial a little.
You need to adjust the blind hemming foot guide so that the needle is just catching a tiny amount of your folded fabric because this is the stitch which shows on the right side of the fabric when you unfold the Z. So forget trying to hem satin or expensive fabrics this way, a hand sewn stitch will give a much better finish.
Blind hemming works best on a hem which is continuously straight on the same grain line, its not great for a curved hem. So if you've got a tiered skirt or the frill on a bed valance, it is fine as the fabric edge to be hemmed will be a continuous straight length. You can use it on a slightly curved hem for jerseys as the fabric has more give, and patterns will help to disguise the stitching too.
I hope that this helps you to sew your blind hem, 4 thumbs up if so.
Jul 19, 2011 | Brother LS2020 Sewing Machine
Hi, i want to know the weight and if have zig zag stitch
read the reviews at
Amazon says:
Product Details
  • Product Dimensions: 12.8 x 10.8 x 5.9 inches ; 4.2 pounds
  • Shipping Weight: 5.7 pounds , eight stitches including zig zag and blind hem.
4 out of 5 purchasers who reviewed it weren't thrilled with it though
Apr 16, 2011 | Euro-Pro 150 Mechanical Sewing Machine
Sewing Machines Logo
315 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
