Question about Philips Irons
Philips Azur 4340 Iron has stopped heating. There are lights on but no heat. How would I go about repairing this?
3 Suggested Answers
SOURCE: Problem with Philips Azur Precise 4340 Iron
i had the same problem and the Philips hekp site was no use. I turned my iron off until it was completely cooled down then switched it back on again, with the steam number turned to 5 and the heat on max. as soon as the ready light went off, i put my iron in the horizontal position and shook it back and forth (quite vigorously) and it seemed to have dont the trick!
Posted on Aug 28, 2008
  • 85 Answers
SOURCE: Steaming function stop working
its just connected with a screws on the front flap that has to be opened to seperate it into two parts,and inside there is small black coil thats is connected to the wires that wires must be short so has to be replaced with another wires. do it carefully .take care.
Posted on Feb 26, 2009
Norelco manual
Most likely problem is that the heat element in the sole plate is burned out. That being the problem, it will be less expensive to replace the entire iron than to get it repaired,if repair is even possible and parts are even available.
May 09, 2014 | Irons
Philips 6104 duble speed
follow this test and fix it. God bless you
As with many small appliances, regular maintenance makes a dramatic difference in how trouble free your electric iron will be. Even so, things can happen.
If the iron doesn't heat, make sure power is on to the outlet, check the power cord and check the thermostat and replace if necessary.
If the iron heats but steams improperly, inspect the soleplate and clean the vents and flush sediment out of the steam chamber
If the iron produces too much or too little heat, test the power cord Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Nov 29, 2013 | Philips HI-296 Iron
Philips GC 2510 won't light up or heat up
If the iron doesn't heat, make sure power is on to the outlet,,test the outlet with desk lamp for to see if working. check the electrical cord, and check the thermostat + fuse inside replace if necessary.
Jan 25, 2013 | Philips GC 2510 Iron
The auto shut off on my new iron has stopped it from heating... is there a reset option? or do I need to purchase a new iron?... The auto shut off light flashes when first plugged in, then stays off......
it has a adjusment try to adjust by rotate it to clockwise it is located inside of your iron use a screw driver to adjust then observe unit. if not u purchase new unit.
Feb 17, 2011 | Philips Irons
Phillips Azur Precice 4340 , lost instructions . How do you de calc it ? Thank you . Claire
Fill tank with water and put steam setting to 0.Set temp pial to hottest setting. Let the iron heat up till the light in the hand goes out. Switch off power and hold iron over sink. Push down and hold descale button until all the steam and water has gone from iron. Wipe plate and heat up iron again with no water in it.
Nov 09, 2009 | Philips HI-296 Iron
Iron will not heat up and the auto off red light keeps flashing
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Aug 07, 2009 | Philips HI-296 Iron
Feb 26, 2009 | Philips Irons
Jul 09, 2008 | Irons
Irons Logo
244 people viewed this question
Top Philips Irons Experts
ray gallant
Are you a Philips Iron Expert? Answer questions, earn points and help others
