Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
Craftsman garden tractor Mod # 917.257740 blows main fuse.
The tractor will blow the main 30 amp fuse when strating. The engine will just start when the fuse blows. I have checked for fraid wires (short), checked the ignition switch for continuity, and bypassed the ammeter. What else can be causing the short that blows the fuse? Please help.
    President:
  • 1,851 Answers
Try checking the battery - make sure it is not under rated - over rated and be sure the starter it's self isn't drawing too much amperage.
the battery may need replacing and for a temp fix - put in a larger fuse - say 50 amp.
Thanks for choosing FIX Ya
Gary @ Fix Ya
Posted on Jul 06, 2010
I have a newer craftsman riding mower, its a 24 horse, 42 inch cut. When I was mowing today, the deck cut off then the mower died. Upon inspection, I discovered a blown fuse (20 amp), I replaced it and it...
By uping the fuse rating you are definitely putting your equipment at risk for damage. The 20 amp fuse is doing it's job. what you need to do is find the reason it's blowing. Stop running you newer machine with the 30 amp fuse and look for the high current source. Hopefully you know what the fuse is protecting and start looking there. A fuse blows due to a high current condition. If it's a motor it could be a mechanical binding of some sort. If it's wiring, it could be caused by a loose connection or exposed wire shorting itself to ground. Look for signs of obvious damage first but if you can't figure out what it is you should have it checked out by a profesional before you cause more, damage and expense.
Jul 10, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Lawn tractor problems
What brand,model and year, If Craftsman check your owner's manual. Mine takes a 30 amp.
Feb 07, 2012 | Garden
Our 24 hp GT 5000 cutsoff and blows a 30 amp fuse when the mower is engaged. Does anyone have a solution?
The electric clutch is shorted out or defective. More than likely you will need to replace it. Check all the wiring for a short before proceeding.
Jul 02, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Tractor keeps blowing a fuse
Check for a wire that has a bare spot on it rubbing the body of this mower. The vibration the engine makes shakes the wiring so it must have a bare spot somewhere under the seat or towards the engine
May 30, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Blowing a 25 amp fuse, will not start
have you checked all the wiring. A wire may have burned up and is arking and causing the fuse to blow. That has happend to me. hope this helps.
Apr 21, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Have a Craftsman , with 25 HP Kohler engine & 50in. deck. Just stoped running whlie mowiing. Now won't start, Sounds like battery dead. Checked seat safty switch by jumping eires, did'nt solve problem
My Briggs and Stratton did the same. Look under the hood along the wiring harness for a 20 amp automotive type plug in fuse. Mine was blown, but fuses blow for a reason. One of my headlight connections came loose and shorted to ground. If yours has that fuse look for a short.
Apr 16, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman lawn tractor model new battery drains quickly...
it could be the stator in the engine check the voltage with the volt meter when its running if its low check connections on battery & voltage if its below 12.5 volts then its the stator but the only thing is the engine should run with-out the battery so there is something else going on there is a fuse in the electrical system if theres a short that fuse will blow & engine will stall
Jun 07, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Fuse blew, replaced with new, and now electric clutch will not work
sounds like you probably need a new clutch. they short out internally and blows the fuse
May 03, 2009 | Garden
Blowing fuse
youve got a short in the wireing ,prob right at the clutch peddle switch
Mar 08, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
30 amp fuse blows when trying to start engine
I always start by unplugging lights, kill wire to coil electric clutch if it has one ,sometime its the fuel shut off solenoid on the bottom of carb if it has one.
You can keep trying until you find the thing that does not blow a fuse or use an ohm meter to read from pos cable to ground of tractor unhook ground wire to battery you will read short to ground thru coil kill wire,starter solenoid small wire on spade,fuel shut off
solenoid ,electric clutch ,rectifier (charging system )and large wire to starter thats why I unplug them .
I have seen more shorts from lights , fuel shut off solenoid , charging system. not ing coil not safety switches not even bad starters.
good luck
Jan 31, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
404 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
