Question about Miele Leo S5381 Canister HEPA Vacuum Cleaner Bagged Vacuum
Power head reset will not work. Red light goes
Power head reset will not work. Red light goes on. Brushes do not turn.
Electrolux Precision vacuum brushes stopped turning and a red light turned on
there's a reset button down on left side of powerhead in the black plastic at base that corrects the problem of that red light
Jan 12, 2013 | Electrolux Vacuums
Dyson brush wont turn
Hi There is a reset switch on your Dyson that needs to be pressed when something gets stuck in the brushes. The reset switch helps protect the motor that spins the brush from damaging if something gets stuck inside the brushes. There is a little red pole that sits up behind the brushes on the vacuum head, I believe it's on the left side of the floor head as if you were behind the machine vacuuming. Try pushing this reset switch first.
Oct 08, 2012 | Dyson DC25 All Floors Bagless Upright...
Power nozzle will not turn on
Depending on the power nozzle model, does a red light come on the top of the power nozzle? If it does, then the problem could be the circuit breaker. If it does not, then the problem could be either in the hose or the connection from the hose to the main unit. Make sure you hear to clicks and the hose is connected solid to the main unit. Otherwise, the receptacles can't make contact to allow the power nozzle to turn on.
RainVac
www.rainvac.com
800-523-0510
Sep 15, 2012 | Rainbow E series Canister Wet/Dry Vacuum
My brusg stopped turning after sucking up a shoe
Hi There is a reset switch on your Dyson that needs to be pressed when something gets stuck in the brushes. The reset switch helps protect the motor that spins the brush from damaging if something gets stuck inside the brushes. There is a little red pole that sits up behind the brushes on the vacuum head, I believe it's on the left side of the floor head as if you were behind the machine vacuuming. Try pushing this reset switch first. Did this fix your problem? If no, please let me know and I'll be more then happy to do some more advanced diagnosing with you.
May 02, 2010 | Dyson DC25 All Floors Bagless Upright...
The brushes will not turn when on and cannot move them even manually
Drive belt has most likely broke and jammed inside the power head. Remove the bottom plate on the power head and replace the drive belt.
Oct 07, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Dyson DC 24 pick up head wont spin
- Look for the reset button on the side of the brushbar housing - there should be a red sticker and a red button. Push it once. It's
not gonna stay depressed, it's gonna pop right out - that's normal.
- Step on the red pedal on the back
- Turn the machine on with the red power button
- Press the gray button next to the red power button - this is the ON/OFF switch for the brushbar - if it doesn't spin, press and hold the gray button down for 10 seconds
- If it still isn't spinning, remove the brushbar and make sure nothing is blocking it and withholding it from spinning
- For further troubleshooting assistance call the Dyson helpline, they know what they're doing
Jun 20, 2009 | Dyson Ball DC24 Bagless Upright Vacuum
Irobot 4100 brushes do not turn & bin is empty but filter is full. does the roomba need a new cleaning head module?
Yes, it probably needs a new cleaning head module, if your bearings are clean and the brushes still don't turn.
Mar 28, 2009 | iRobot Roomba Red 4100 Bagless Robotic...
Miele SEB-213 powerbrush stopped working
Pull the head cover off to check the belt, if the belt is ok then it might be the power connection between the handle and the power head shaft. If the red light is on the power head, then its not the connection
because its getting power. Now some heads have a reset button on them,you could check this also.
With the cover off the power head, remove the belt, now turn it on, and be careful, but try to make the motor shaft spin,with one finger, because if it does start to spin you do not want to hurt your finger.
If the motor starts to spin,put the belt back on, if it does not spin again, the motor is too weak.
If it does not spin at all, the motor is bad.Hope this helps you,and you get it working.
Mar 24, 2009 | Miele SEB 213-2 Vacuum
Electrolux epic series 3500 sr serial v87779 l
Sorry I didn't see this sooner. Your problem may be solved as simply as pushing the small red reset button exposed on top of the power head when you tilt the arm back. Very simple. Hope this helps.
John
Aug 16, 2008 | Vacuums
Miele Leo S5381 Canister HEPA Vacuum Cleaner Bagged Vacuum Logo
194 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
