Question about Garden
MOWER BED LEVELING
MURRAY RIDING LAWNMOWER deck LEVELING
    Brigadier General:
  • 3,911 Answers
Get the mower on a flat slab of concrete. Raise the deck all the way. Make sure the blades are on correctly. Measure the distance from each corner of the deck to ground. Lower the deck and take the same measurements. You will find, if you look, some threaded rod/bolt and/or pin settings to make adjustments. Most often the deck is out of whack as someone took it off and did not put it back on correctly. Google the mower's make and the word "'manual" if you cannot figure it out. Someone out there will provide you with a manual if you cannot figure it out from looking at it and there will be instructions in the manual as to making the adjustments.
Posted on Jul 07, 2010
Will an older 42 inch murray riding lawn mower deck interchange with an older rally riding lawn mower deck ?
Mower decks are very specific to the tractor. Unless it was the same manufactured mower, and just branded differently, then not likely! Belts are your next problem as even an inch longer or shorter will cause problems.
May 07, 2016 | Murray Garden
30" Murray riding mower drive belt diagram
Here's a link to your belt diagram,just click on picture to in large. motion drive belt came off 10 hp 30 deck mower Murray Riding Mower
Aug 21, 2014 | Garden
Murray Select Model # 405000X8 trong vibration when I engage mower deck. Also can't keep deck even.
Could be a number of things included but not limited to.....blade spindle bearings....idle pulley or engager pulley......could also have a bad spot in belt....causing a vibration. This vibration could also lead to deck coming out of level as that model have a leveling adjustment on the deck level control lever.
Oct 22, 2013 | Briggs & Stratton Garden
I am looking for a belt placement diagram for a 42" murray riding mower-drive belt.
Use your model number & go online for Murray Riding Lawnmower & search. Most of the time you will find it. If not reply back with model numner & HP (horse power)
Aug 03, 2010 | Garden
The mower deck drive belt slipped off the idler pulley on my 42'' Murray riding mower deck because the idler pulley was worn out. I need to know how to loop the belt back around the pulleys after I replace...
Get the model number off the tractor, go to:
www.murray.com
enter the model number and you will find a manual with pictures of how to route the belts along with a lot of other good information
Sep 30, 2009 | Garden
Having problems leveling the mower deck I have a murray 38 inch ridding mower that I can't get ythe deck to level out the mower has a leveling position on the height lever I do not have a manual for it...
put it on a level surface then put blocking ( 2x4s work) under the deck and drop it on the blocking. loosen all the adjusting bols to let it settle squarly on the blocking then re-torque the bolts. Should be level.
If not check you blade berrings as they may be worn and the blade shaft may not be square to the deck
Sep 02, 2009 | Garden
Garden Logo
431 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
