Question about Vizio VO47L 47 in. LCD TV
The left half of the TV screen is dark. The
Many times the left half of the TV screen is dark when turned on. The right half is OK. There is no distinct line between the normal and dark portion-it is a gradual deterioration. The problem normally improves with time if the TV is left on. In the dark section there are some red shadows visible, so it is not completely dark. Sometimes the upper third of the screen clears, with a distinct horizontal demarcation line between the working and impaired parts while the lower 2/3 of the screen stays dark. The right side of the screen is always OK. It has been getting worse with time, and now sometimes occurs even after the set has been on for hours. The TV is 2 1/2 years old. The problem will normally but not always spontaneously clear with time.
  • 1011 Answers
SOURCE: my tv picture is dark and flickers
is there any spar, u observed inside the tv when it do like this.
Posted on Jul 29, 2008
  • 1779 Answers
SOURCE: red line down right side of screen
I would have a tech come out and look at it. Sometimes the ribbon connectors from the upper or lower buffer boards have poor or corroded contacts. Should'nt be a major deal since it comes and goes.
Posted on Apr 21, 2009
  • 105 Answers
SOURCE: Green outline/shadow on dark images or backgrounds
LVDS Cable is corroded - This is the cable the provides video from the TV Video Process board to the LCD Panels Timing Control Board.
Honestly, if you can take the TV back do so. If not, Service it using the manufacturer warranty
Posted on Jun 24, 2009
  • 8457 Answers
SOURCE: I have a 42" Vizio picture has an annoying thick red line
Ur backlight inverter video board is dying.
Need a new one.
Posted on Sep 22, 2009
  • 79 Answers
SOURCE: Our Vizeo P42 purchased in
sadly no.
either your panel has been hit and damaged or the panel itself is failing.
without some sort of warranty coverage, your repair cost would exceed the price of replacement.
Posted on Apr 12, 2011
How to fix my sony tv?
When a TV is defect, there is no such thing as a magic word over the internet that can heal it. For defects, you really must visit a repair store, or contact Sony, when it still is under warranty.
Feb 16, 2015 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
HELP! Olevia lt37hvs screen went blank. No Sound, panel buttons wont work. Backlight is only on on half of screen.
if you had audio i wold say its most likely the Tconn or its upper two connections to the Panel itself. But since you dont have any sound either I would assume its either the LVDS cable from the main board to the Tconn or the Main board itself as audio and video are produced on the main board, You can get replacement boards from
Aug 12, 2012 | Olevia LT37HVS 37 in. LCD HDTV
On my monitor W1941S half of area (left side) changed all colours to darker then right side (which is o.k.), What is the problem? Thank you.
Press f-Engine button (it is on the right side of MENU button), select your desired setting, if it doesn't help, select the "X" (none) mode - the half dark screen will reset to full screen OK mode.
Jan 08, 2011 | LG W1941S-PF Monitor
Right side of screen becomes discolored and fuzzy after 15min
if its an lcd, it could be a bad lcd panel
does the menu or volume get distorted or dark too?
yes - likely lcd panel
no - video board (main board) problem
a technician would use a can of "freeze spray" to find the issue inside, by cooling down the parts until the problem goes away.. the part you froze to reverse the issue is the bad part.
Jun 06, 2010 | Televison & Video
Hp dv6149us right half of LCD is dark, left half is OK
Sorry to say, I had a similar problem except my screen was upper/lower not left/right. If the drivers and hardware appear fine then it is the screen or connection to the screen. If under warranty send it in now! If not you may need to buy a replacement screen. Shop around for prices AND other solutions- (not being there to give it hands-on care) I may be mistaken.
Jan 30, 2009 | HP Pavilion dv6000z Notebook
42" LCD tv shows picture on only half of the screen,other half dark!
The T-Con board (otherwise known as LVDS) connects to two seperste parts of the LCD panel. If you do have half a picture (left or right) replacing the T-Con board should resolve this issue. Open your TV, find the part number and search on eBay or at sites like where you can search by TV model number.
Oct 27, 2008 | RCA L26WD26D 26 in. LCD TV
Vizio VO47L 47 in. LCD TV Logo
223 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
