Question about RCA Audio Players & Recorders
I have an rca stereo system and it has been programmed to certain channels and i don't have an operating manual or remote to go to other channels.
  • carol wright Jul 08, 2010
    i haven't had a chance to try it yet, i'm sure this well work. thanks so much.
  • 17,970 Answers
Tell us the right mode about you devce. PLS.
Posted on Jul 06, 2010
  • carol wright Jul 06, 2010
    my stereo is a home system. it has a 6-disc changer and cassette deck along with am/fm stereo. the number on the front is rs2650b, 4530ca, cd-r/rw compatible. the serial no. is 530400611. can i get a manual or remote for this system?
  • ZJ Limited
    ZJ Limited Jul 07, 2010
    Auto Preset Programming (FM only)
    Press and hold BAND button for 2 seconds to scan stations in FM band. The stations will then be stored as preset channels. A maximum of 32 stations can be stored. Beware of your preset channels being erased accidentally because the scanning and storing process is automatic upon pressing the button. You can stop the automatic scan by pressing any button, but the erased stations cannot be recovered.
    Manually Setting Presets
    1. Press TUNE•PRESET button to enter TUNE mode.
    2. Press SKIP BACKWARD / SKIP FORWARD to access the desired frequency.
    3. Press the PROG•SET button once.
    4. The most recently accessed program location will be displayed.
    5. If a different program location is preferred, press SKIP BACKWARD / SKIP FORWARD to move to the desired preset number (1-32).
    6. Press PROG•SET
    Probably, one easy way to solve it, just need find the Remote Control (click over image)
    Also, if you are interesting, can find and download the User Guide from RCA Home System RS2650 - User Manual.
    Hope helps.
RCA LCD TV gets stuck on one channel
sounds like you have an intermittent defective main board. ebay rca model for replacement board.
Jan 11, 2015 | RCA Televison & Video
The audio keeps going in and out and cuts off. Also I have other devices going into aux in but it doesn't show 5.1 surround it only shows the front L, Front R, and CT speakers in stereo. I want everything...
If you are playing a source that is Stereo such as FM Radio or a CD the sound will not use all 5.1 speakers unless you enable the correct Surround Mode. On the remote there is a button on the lower right of the remote that says SURROUND. You can toggle through the various surround modes with this button the mode you want is Dolby Pro Logic The Pro Logic mode uses the built-in circuit to steer the Left, Center, Right and Mono Surround channel audio signals and uses all five speakers to play both stereo and Dolby Pro Logic program source, such as TV and VCR. You can use this mode with any stereo program source (such as VCR/TV) to enjoy multi-channel sound experience.
Mar 02, 2011 | RCA RTD317W Theater System
How do I get my rca truflat tv to get out of mono?
Hello
Press the MTS on the remote control handset to select STEREO, MONO or SAP. All the options will be available only when the current TV channel is broadcasting that option. Channels will not always carry programes, that have all MTS options. If "STEREO" appears on the screen when you select a channel means stereo sound is available with current programme. You can hear sound from both speakers. If broadcast is not strong and clear, stereo sound will not be available. Press "MTS" button to change it to "Mono". This will eliminate the noise. If "MONO" appears on the screen when you select a channel, stereo effect will not be availabe, even though you have set it to stereo. If "SAP" appears when you select a channel 'Second Audio Programe' [SAP] broadcasting is available for that programme. Press the "MTS" button to 'SAP' and you can hear that programe in different language or some other kind of audio.
Oct 28, 2010 | RCA TruFlat 27F520T 27" TV
I need a remote code for my RCA TV . Comcast Cable provided a remote for their digital adapter and was told to enter one of the RCA codes. None would work. Comcast and RCA told me to use both remotes which...
your rca does it have a button for cable. then you can program your tv remote to work with the cable box. go to the manual and try all the codes for rca tv. if this does not work then you have to try it manually. have them give you a different adapter. it might be in the box or remote.
Feb 09, 2010 | Televison & Video
Need 1992 Remote Control For RCA ColorTrak TV Set
Tries 1-800-Factory remotes originals Website.
U get same as the original remote.
Aug 17, 2009 | RCA F27450 27" TV
Does my toshiba model have a digital tuner?
Negative. Here are the specs for your TV/DVD combo: I hope this solution is helpful. Please take a moment to rate this solution.
Toshiba MD13M1 Dvd Type: DVD player - built-in
Media Type: DVD, CD, Video CD
DVD Repeat Modes: A-B repeat, title, chapter
CD Playback Modes: Program play, random play / shuffle, all tracks repeat, one track repeat
Tv tuner Analog TV Tuner: NTSC
Reception System: NTSC-M
Analog Channel Qty: 181 channel(s)
Channel Coverage: VHF:2-13, UHF:14-69, Cable:1-125
MTS Stereo: Yes
Secondary Audio Program (SAP): Yes
Video features Closed Caption Capability: Yes
Closed Captioning on Mute: Yes
Remote control Type: Remote control - infrared
Features: Back-lit buttons
Connections Connector Type:
  • 1 x headphones ( mini-phone stereo 3.5 mm ) - front
  • 1 x composite video/audio input ( RCA phono x 3 ) - front
  • 1 x SPDIF output ( RCA phono ) - rear
  • Composite video/audio input ( RCA phono x 3 ) - rear
  • 1 x antenna ( F connector ) - rear
Jan 28, 2009 | Toshiba MD13M1 13 in. TV/DVD Combo
RCA GuidePlus Gemstar Universal Remote Control 242524
i need to program my remote for my tv with this gemstar universal remote control "crk76te1 . how do i do this ? its for a zenth televison . thanks
Jun 08, 2008 | RCA Universal Remote Control
Unusable Signal for PS2
If you want to use a PS2 with an RCA stereo monitor Colortrak plus television, folllow these steps:
1.Buy a universal remote compatible with RCA televisions if you don't have the original.
2.If your remote needs programming, program it with the manual provided.
3.Goto Menu
4.Goto Alarm
5.Goto Alarm Channel
6.Set Alarm Channel to 00
7.Exit Menu
8.Goto channel 00 on the television by using the remote.
9.You should be in AV mode, and able to play your PS2.
P.S. I don't know if you need to set Alarm Channel to 00, but that's how i did it.
May 13, 2008 | Televison & Video
SET CODE FOR RCA MODEL RS2654
I need to program my stereo Durabrand (HM3817DT) to operate with universal remote Philips (SRU4105WM/17) can you please get me the search code for it.
Thank you
Nov 26, 2007 | GPX HM3817DT Shelf System
22 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
