Question about Samsung SGH-a737 Cellular Phone
My screen goes off when opened occasionally and doesn't turn off when I shut the slider in the off position. I think it may have to do with the power going out when I was charging it a while back. It worked fine before that but after that, it started doing this.
  • 43 Answers
Change flex cable..tested 100/100
Posted on Jul 06, 2010
I smell gas occasionally. Doesn't seem to be any leaks anywhere. the check engine light comes on occasionally, then goes off.
I wish I could be sure and say its the evap hose or the charcle canister that collect gas fume a sends it to the intake for fuel,but in your case you just bought it, be safe take it to a shop let them inspect the vehicle for your concern
Nov 09, 2012 | Cars & Trucks
How do you set the aperture lock on the Nikon 50mm AF F1.8 non D lens?
On my lens I just turn the ring to its smallest setting. I can't seem to move the orange slider very well, and it doesn't seem to matter. I think it's just there to prevent the ring from moving accidentally, and the camera only cares about the ring position.
Dec 14, 2011 | Nikon Cameras
The apple appears on the screen and never goes away. 3GS
Turn the iphone off, hold the menu button, now plug in the usb cord that is connected to the computer. Keep holding the menu button until a dock connector appears on the screen. You're now in recovery mode and should be able to restore your iPhone. If that doesn't work you may have a broken logic board. Here is an iPhone Repair Guide that shows how to open an iPhone. Boards are easily available on Ebay2_bing.gif. If you want somebody else to do it for you go to iPad Repair
Mar 09, 2010 | Apple iPhone Smartphone
2002 isuzu rodeo. rear wiper continues to run after car is shut off. it eventually stops but is not in the right position
probably a worn motor, they have a brass slider that rubs on a track on a gear in the motor this gives it the park position, usually it gives an earth return to the motor, to set it going the switch provides an earth, when you turn it off it runs until the slider detects the park position,with wear and water ingress this all goes unreliable
Nov 29, 2009 | 2002 Isuzu Rodeo
LG Xenon keypad slid open will not turn horizontal on the screen
I read that you can rub a magnet on the backside of the slider and it makes the screen turn portrait and horizontal - you can see that when you rub the magnet on the backside. I just rubbed the magnet with the slider open on the horizontal side (only the right side) - if you rub the left side it makes it portrait. I did that a few times and my phone turns horizontal now when I open the keypad slider. It appears to have worked doing this at this point.
Nov 16, 2009 | LG Xenon GR500 Cell Phone
The TV started turning itself off occasionally a
Most likley what it could be is an interferance in the TV. Modern TV's have a feature that will shut itself off when it is not receving a picture. For instance, after so many minutes of "snow" it will shut off.sometimes this can make the TV think there is no signal at shut itself off.Anyway, I suspect its an interferance issue. Perhaps moving the TV further from the source of the interferance might help.
Sep 17, 2009 | Televison & Video
Cold side of faucet, when turned on, occasionally stops flowing.
Sounds like the valve is comming apart internally. This allows the water to get into places it shouldn't and the water pressure forces the valve closed even though the handle is in the open position. Take it apart and check for loose screws and broken pieces. Lowes or Home Depot should have parts. Don't forget to shut off the valve below the faucet (if the plumber installed one) if not one will have ot shut off incomeing water supply.
Sep 02, 2009 | Price Pfister Plumbing
LG Rumor Phone's screen frozen
If you have a memory card in the phone...take it out. then turn take out the battery. Turn it back on. And if that works. its because you have a virus and or corrupted file on that memory card. Same thing happened to me. But now the screen is all messed up everytime i slide it open or closed.
Feb 11, 2008 | LG RUMOR Cellular Phone
DVD loader mechanism
It is called the slider assy. The slider moves the laser assy back to home or start position. It is a small belt underneath or there is gunk or hair in the gear mechanism. A very common problem with CD/DVD players/recorders. Very good though that you saw it was not comming back to home place. I wish I had a manual to assist you but I do not. Im telling you the most common problems with the slider mechanism. Good Lck
Oct 08, 2006 | Sanyo DVW-6000 DVD Player/VCR
Slider Prob
Dang, what a weird design. The lens needs to go threw a cycle before it can reach the idle position where it waits for a comand from the user. If its in the closed position and you turn it on it extends to its full range then stops at the idle position. It sounds like it is stuck in some spot between close and idle. Since it cant reach the closed position or idle its shutting down. The only way to get it to work is to try and free the lens so it can cycle threw. There must be a lip on the slider and the lens is stuck on this lip so you cant slide it. Remove the batteries then try and slide the door open try and slide somthing between the lens and the door to free it up. This is the only way to get it threw the cycle. It may need to be serviced It sounds like the switch for the slider door is warn or has broken. It may work again if you can free the lens.
Aug 31, 2005 | Canon PowerShot S30 Digital Camera
Samsung SGH-a737 Cellular Phone Logo
64 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
