I've purchaced new battery for my Tom Tom GO 510 but am having terrible problems replacing the old one. Have accessed the battery but cannot remove it! Any ideas please?
JohnI've purchaced new battery for my Tom Tom GO 510 but am having terrible problems replacing the old one. Have accessed the battery but cannot remove it! Any ideas please?
John
You can't post conmments that contain an email address.
The largest battery that fits the battery holder
i fitted a lager battery than the original factory as they last longer than the original more starting power
I cut the battery holder under the seat so to fit larger batt
Try cleaning, scraping the battery contacts and then put a little petroleum jelly on the contacts and reinstall batteries. If they leaked a bunch then you may have a copper trace or a wire corroded in two.
The battery is located in the front of the rear drive mechanism. It is mounted just below the alternator control board. The following video shows the battery location along with the battery replacement procedure.
Battery 6 Volt 2 5 Amp Hr LifeFitness 0017 00003 0685 SPORTSMITH net
IF it is the toy that you are refering to then any size battery that is the same voltage if it will fit in will be ok. So if it is a 12 volt 2amp/hour and you can fit a 12v 4amp/hour in the space that will be ok ( as an example). Ni-cad batteries last longer. check the battery shops as there may be a ups battery that will fit, a battery drill pack that may fit. Terminals are easy to adapt for the job. REMEMBER it must be the same voltage or the motor will disappear in a cloud of smoke
Be very carefull of aftermarket batteries (cheap), get one from a reputable dealer. If you have a issue you can return it try here: http://www.amazon.com/Samsung-NP-N150-PLUS-Battery-4400mAh/dp/B006YZVOK0 Some cheap Replacement batteries at best will not work properly/long, at worst can be a fire hazzard. Never leave a laptop with battery inserted unattended.
Hi, Yes you can, most compatable batteries with whatever the unit is will have a unique plugin setup so only the proper battery will fit so if it fits it's OK to use.
If you remove the rechargable battery pack and put regular batteries back in, are you still having the same problem? If so, I would recommend returning the rechargable unit and replacing it.
For what it is worth, I've been using my Wii Fit board for nearly a month on 4 alkaline batteries and have not had any problems.
I recommend rechargeable NiMH batteries with a 15-minute quick charger. Always have four more batteries than you need in your machine, ie: if you have a Wii Fit, a Nyko Wireless Sensor Bar, and two Wiimotes, then you should have 16 batteries total (4 + 4 + 2 + 2 + 4 spare).
John
