Question about Hotpoint Ultima WF865 Front Load Washer
E05 error on hotpoint ultima wasing machine - Hotpoint Ultima WF865 Front Load Washer
    Scholar:
  • 154 Answers
E05 indicates that the pressure switch is stuck on full, this may be that your pump is jammed or blocked. Remove the filter and clean it out, also try to fish around in the tube that leads up to the drum. If this doe snot remedy the fault have it repaired by an engineer or someone whom has a rudamentary understanding of the mechanics of a washine machine.
Hope this helps, thanks for using fixya
Posted on Jul 06, 2010
Have an hotpoint ultima wt940 an error code of f05 came up.how can i fix it?
  • F05 - Pressure switch jammed on full - Check pump for blockages.
  • I would recommend you pull out your machine and check the drain pipe and pump hope this helps.
Jan 22, 2011 | Hotpoint Ultima WF860 Front Load Washer
F05 keeps coming up on my ultima 860 hotpoint 1600 spin w/m,we cant find manual,what is problem?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Fo5 is a pressure switch fault; areas to check are pressure chamber for blockage, pressure pipe sump and pump. Click on a link for more Hotpoint, Creda and Indesit error code definitions or Hotpoint WMA / WM workshop manuals
Mar 05, 2010 | Hotpoint Ultima WF860 Front Load Washer
Test Error
Hold In on/off and start buttons together for 10 secs.
Feb 20, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima F-05 errorr appears on machine
Error F05 indicates pressure switch jammed on full.
Remove lower rear cover of washer.
Locate and remove large black hose fastened to drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
This should solve the problem.
Jan 10, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima Super Silent. Was & Dry
High Temperature Rise in Drying:
check fan motor & filter for blockage. basically a reduced airflow within drum unit
Dec 12, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint aquarius wash system plus ultima 1200 wm72
it's a motor problem. could be as simple as the brushes or could be the circuit board at fault.
Jan 17, 2009 | Hotpoint Ultima WD72 Front Load...
E30 error code
Error E30 is a motor drive problem. Would check motor brushes as most likely fault.
Thanks for using Fixya.
Dec 16, 2008 | Hotpoint Ultima WD72 Front Load...
Error message f-01 on hotpoint ultima wt741 washing machine
F01 is a motor faulty normally caused by the module,but sometimes thewiring to the motor plug that works loose as its to tight,give them alla good wiggle make sure there all in!
check this link for other error codes of hotpoint machines
http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODES
Dec 15, 2008 | Hotpoint Ultima WD72 Front Load...
HOTPOINT ULTIMA 1200 WM72 Error Code
f30 code means there is a problem within the motor curcuit,check connections at the motor and check motor brushes are not worn.
May 05, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF865 Front Load Washer Logo
564 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
