Question about Brother MFC-8460N All-In-One Printer
Scanning to file control center icon missing
My control center icon that I always clicked on to scan to my computer is gone. How do I scan to a file?
SOURCE: brother 5460cn won't scan to email,file,ocr,image
i have the same problem and it was resolved after downloading the control center updater.
here the link
http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/dlf/000000/003100/dlf003176.html?reg=us&c=us&lang=en&prod=dcp130c_all&type2=2&os=7&flang=8&dlid=dlf003176
Posted on Nov 20, 2007
SOURCE: Scanner Problem
The Laserjet 3050/3052/3055/3390/3392 FULL software version 4.0 (27 Mar 2007) for Windows Vista. Check out HP's download page or click the following for the US & EU version: http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=1161389&prodNameId=114078
0&swEnvOID=228&swLang=8&mode=2&taskId=135&swItem=ma-38114-4
This should fix all your problems
Posted on Aug 27, 2008
SOURCE: Dell 964 scanner
I ahve the Dell All-in-One Photo 964 Printer. The software says it can't communicate with computer. But faxes and scans can be done manually on printer, the software is needed to drop scans into e-mail, files etc. It worked perfectly fine when I had Windows XP, I now have Windows Vista. I have the same problem above also when using it manually.
Posted on Aug 29, 2008
CarlGehrke
  • 169 Answers
SOURCE: Not able to scan to pdf file with Brother MFC-240C
What you seem to want to do is not possible. Let me explain:
A file that has its data in the Adobe company Portable Document Format (or a pdf file) contains various objects that are described to the computer using a superset of the PostScript language, some of them can be images.
A file that comes from the scanner is first a very organized set of pixels and gets put into a more compact form by using a well known process as defined by the Joint Motion Picture Experts group. This is a roundabout way of saying that it has a format that isn't PDF.
What you CAN do:
a) open the jpeg file with a Macintosh, using the Print command from the file menu make a pdf file that has the image in it.
b) buy and install a PDF printer driver on a Windows machine, and then follow the same process as A above.
c) Use your favorite PDF creation program to make a file with the image embedded.
Carl
Posted on Dec 10, 2008
  • 684 Answers
SOURCE: scanner won't scan
Right Click on My Computer/Computer if Vista........ Click on Properties then click on Hardware click on Device Manager...... On that list u will see the Printer Name with an exclamation Mark........ Right Click on that click on update Drivers...... Insert the CD to the drive....... Select Browse My Computer for Driver software..... Click on Browse and then Double Click on Computer go to Lexmark X*****.......... Double click on Drivers and then click on scan and then click ok........ Now click next it will say the hardware is ready to use then u can just click on finish and scan..... Thanku
Posted on Jan 25, 2009
KODAK ESP 3200 SERIES WILL NOT SCAN
I had the same problems; missing Icon and 100-2105.
This solution on the Kodak web site solved my problem.
http://support.en.kodak.com/app/answers/detail/a_id/1276/kw/ERROR:%20100-2105/selected/true
From your computer desktop, select Start > Run.
Type %windir%, then click OK.
Double-click the twain_32 folder.
Right-click the kodak folder, then select Delete.
Insert the KODAK All-in-One Printer Software CD into the CD drive, then go to D: > printer > scanner.
NOTE: The CD is indicated by D: above. The CD drive may be a different letter on your computer.
Double-click aioscannr.msi, then follow the instructions to remove it.
Go to D: > printer > scanner, then double-click aioscannr.msi, and follow the instructions to install the file.
Start Home Center Software.
Select Scan Documents and Pictures.
Scan a document.
If the error continues using a Wi-Fi connection, make sure you select the correct printer in Home Center Software.
If the error continues using a USB connection, see the following section to reinstall the printer.
Jan 13, 2012 | Kodak ESP 3 Multifunction Printer/ Copier/...
How do I scan when I get the message "no scan options"?
You can scan from the solution center on the computer provided that the software was already
  1. look for the hp solution center icon on the main desktop screen.
  2. double-left click to open it
  3. If it's properly installed ,you should be able to see scan menu (scan document,scan picture,home,settings,etc.)
  4. scanning from solution center is an alternative way of scanning other than scanning to computer
  5. start scanning from the computer using solution center software to unveil its features.
  6. for scan to PC: if your receiving no scan options error ,update the settings from solution center
  • click HOME on solution center
  • click scan settings
  • depending on your software version click the option available to you
  • scan to setup
  • front panel button settings
  • front panel scan button settings
  • transfer all files from the left hand-side over to the right-hand side by clicking on one item then by clicking on add until all get transferred.
  • click update device
  • try scanning from printer
if issue persists i suggest you download and install scan diagnostic utility to fix scan issues. http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?cc=us&lc=en&jumpid=ex_r4155/hho/ipg/ccdoc/scan_diag/&lang=en&softwareitem=oj-90927-2
Jul 28, 2011 | HP Officejet 6500 Wireless All-in-One...
Hp 6210 officejet all in one ... want to test scanner only. Took 16 hour tech assist to download (software was not provided by work associate). Ink cartridges do need to be replaced. Want to test the...
yes, you can test the scanner without inks.
use the hp solution center c01810967.gif installed on the computer Double-click the HP Solution Center icon (c01810967.gif ) on your desktop
  • For photos or artwork : Click the on-screen Scan Picture "button" in HP Solution Center.
  • For a text document with or without graphics : Click the on-screen Scan Document "button" in HP Solution Center.
    For the HP Solution Center "button" that you are using ("Scan Picture" or "Scan Document"), set the option to prompt for settings each time you scan, and then click OK .
    • Scan to: Select your scan destination from the drop-down list.
    • File Type: Select the file type from the drop-down list.
    • ...Save Options...: (available only for certain "Scan to" destinations): For example, if you are saving to a file, click this option to select your Save Location .
    • Show preview...: Select this check box if you want to see a preview before the actual scan.
      Click Scan
Jun 05, 2011 | HP OfficeJet 6210 All-In-One InkJet...
I have HP7410. When I loaded to my laptop after desktop died, I keep getting HP Imaging device not found when I try to go into it to scan photo. Printer works. Laptop OS is VIsta
To scan a document using Windows Photo Gallery in Windows Vista, follow these steps:
  1. Click the Windows Vista (c01319360.gif ) icon, click All Programs , and then click Windows Photo Gallery .
  2. Click File , and then click Import From Camera or Scanner .
  3. Click Import , and then click Scan .
To scan a document using Paint in Windows Vista, follow these steps:
  1. Click the Windows Vista (c01319360.gif ) icon, click All Programs , click Accessories , and then click Paint .
  3. Make any desired setting changes, and then click Scan .
If you have trouble viewing the video or to view the video in a different size, click here to play the video on YouTube. The following scan options and file types are available when you scan with WIA drivers:
c02222409.gif If you experience an error during scanning, try these general scan troubleshooting steps (c02114802) (in English). Workaround Perform the following steps if you are unable to scan directly from HP Solution Center in Windows Vista.
  1. Click the Windows icon (c01319360.gif ), and then click Computer .
  2. Double-click Local Disc (C:) .
  3. Double-click Program Files .
  4. Double-click HP .
  5. Double-click Digital Imaging .
  6. Double-click Bin .
  7. Locate and double-click one of the following files. You will only have one to choose from.
    • Hpiscnapp.exe
    • Hpqscnvw.exe
    This will launch the HP Scan application.
  8. Select New Scan , and then change any desired settings to the scan.
  9. Click Accept to save the scan to the desired location.
Dec 27, 2010 | HP OfficeJet 7410 All-In-One InkJet...
Purchased a new ThinkCenter desktop computer and my Logitech X-230 speakeers will not work with it. Help! Ken
Probably your problem is your PC audio device not your new speakers.
First verify you see a small sound icon sound3.gif or sound.jpg in the Systray (generally at the bottom right hand corner of your screen). If this icon is missing follow the below section.
Windows XP
  1. Open the Control panel
  2. Open the "Sounds and Audio Devices" icon.
  3. Verify the "Place volume icon in the taskbar" checkbox is checked. If this option is not available or is grayed out, skip to the next section of this document.
  4. If you were able to check this box, click ok and close out of this window and the Control Panel.
  5. Double-click the sound icon in the Systray and verify that all the sound volumes are mid-way or higher.
Also looks like there are some corrupt system files on the computer I would suggest that you run SFC scan which would scan for corrupt system files on the computer and replace them.
Steps to perform SFC scan:
1. Click the Start button
2. From the Start Menu, Click All programs followed by Accessories
3. In the Accessories menu, Right Click on the Command Prompt option
4. From the drop down menu that appears, Click on the 'Run as administrator' option
5. If you have the User Account Control (UAC) enabled you will be asked for authorization prior to the command prompt opening. You may simply need to press the Continue button if you are the administrator or insert the administrator password etc.
6. In the Command Prompt window, type: sfc /scannow and then press Enter
7. A message will appear stating that 'the system scan will begin'
8. Be patient because the scan may take some time
9. If any files require replacing SFC will replace them. You may be asked to insert your Vista DVD for this process to continue
10. If everything is okay you should, after the scan, see the following message "Windows resource protection did not find any integrity violations"
11. After the scan has completed, Close the command prompt window restart the computer and check.
The scan may take some time, so be patient. Windows will repair any corrupted or missing files that it finds. If information from the installation CD is needed to repair the problem, you may be prompted to insert your Windows Vista / 7 installation disk.
Dec 01, 2010 | Logitech X-230 Computer Speakers
How to install add/remove icon
Assumption you are using XP Operating System(OS).
You cannot install "add/Remove" icon to your system, because it is part of the OS.
For some reasons the add/remove programs option (appwiz.cpl) is corrupted has `gone missing` from the control panel? Your PC might be infected with Malwares or "Nasty Root-Kits".
Resolution
1. Download "Malwarebytes Anti-Malware free version", install update and do a full scan and remove any of those "nasty files".
2. Download "SUPERAntiSpyware Free Edition", install update and do a full scan and remove any of those "nasty files".
3. Do a virus scan too!
After the clean up, reboot your PC and see whether your 'Add/Remove' is there.
If you still can't see the "Add/Remove" icon,
then download the Registry file "28. Control Panel Icons are Missing" - download the registry file and add to your registry @ kellys-korner-xp.com.
Hope it helps.
Oct 11, 2010 | Computers & Internet
How to scan using hp j4580. Booklet only tells how to fax!!!!
  1. Open HP Solution Center with one of the following methods:
    • Click the Windows icon c01319360.gif , click All Programs , click the HP folder, and then click HP Solution Center.
    • Double-click the HP Solution Center icon on your desktop.
  2. If you have more than one HP device installed, click the tab or icon for the product that you are using to scan.
  3. Use one of the following methods to start the scan:
    A screen displays to prompt for scan settings. If a settings screen does not display before the scan starts, a preference was set to bypass the prompt. To adjust settings, follow these steps to turn the prompt back on:
    1. Cancel the scan, return to the home screen of HP Solution Center, and then click the Settings option.
    2. For the HP Solution Center "button" that you are using ("Scan Picture" or "Scan Document"), set the option to prompt for settings each time you scan, and then click OK .
    3. Start the scan again.
  4. Read through the various options for the scan settings. Make selections for at least the following items:
    Important : HP Solution Center software versions vary, depending on the age of your product, and whether you installed updated software after the initial setup. For specific instructions on all the settings the software offers, click the Help button on the home screen or settings screens in HP Solution Center.
  5. Click Scan . The preview screen might display, if you selected an option to show a preview. Use the options on the preview screen to make any desired adjustments before you complete the scan.
After the scan completes, it goes to the destination that you specified in the settings.
Jul 18, 2010 | HP OfficeJet J4580 All-In-One Laser...
Control panel icons and properties tab are not working
The first step is to scan for spyware. These nasties can alter system files. Download MS Antispyware and Ad Aware and scan or spyware.
Also run a system file checker command to update any missing files Go to Start>Run>type "sfc /scannow" without quotes.
Note: it is advised to keep the original windows CD handy while prforming SFC \scannow as it tries to update the missing/ corrupt files.
Regards,
Arpit
Apr 19, 2009 | Computers & Internet
I am trying to scan a picture to my computer and when i press "scan to" it says "no scan options". Please help as i can't afford to keep buying printers since i have TWO of these and neither of them...
You need to update the front panel button settings from Solution center or HP Director or you canuse these steps toscan without HP software.
VISTA
1. Click the Start (Windows) icon.
2. Click All Programs.
3. Click Windows Photo Gallery.
4. Click File and then click Import From Scanner or Camera.
5. Click Import.
6. Click Scan.
XP:
=== Scanning with Paint: ===
3. Click Accessories.
4. Click Paint.
5. Click File and then click From Scanner or Camera.
6. Click Scan.
Dec 18, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
Brother MFC-8460N All-In-One Printer Logo
626 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
