Question about Husqvarna Chain Saw 20" Bar
Chain not lubricating
Bar oil is leaking out bottom of motor housing, but not getting to chain.
    Brigadier General:
  • 4,088 Answers
Remove the bar and chain. Clean all parts exposed including the bar drive-end small oil channels that feed oil out to the chain groove on both sides of the bar. Start the engine and look for oil oozing out of a small side port where the bar fits to. If ok and no oil seems to coming from under the case, reassemble all components. Start the engine and run the bar tip at speed near some cardboard--it should throw off a thin line of oil. This saw should have an oil volume adjustment screw in the case back near the lower run of chain or just under the case in the same area. Turn CW to reduce volume. Hope this helps!
Posted on Jul 07, 2010
What chain oil in RM1015P
Hello, The chain lubrication oil is called bar and chain oil. It is specially formulated to cling to the bar and chain to ensure maximum lubrication. You can obtain bar and chain oil at any hardware store or power equipment shop.
Jul 14, 2014 | Remington 10" Model Rm-1015p Electric Pole...
Which oil do i use in a ryobi C4620 chainsaw?
Do NOT use lightweight motor oil for that bar! Use only bar/chain oil for it - nearly any brand will do just fine, but it needs to be bar/chain oil. Bar/chain oil is specially formulated to stay on the bar & chain in use - motor oil will fling away & your bar won't get the lubrication it needs.
For fuel mixing, use nearly any brand of 2-cycle oil, which is specially formulated to provide lubrication even when it's mixed into your fuel. Use about 3.2 ounces of 2-cycle oil per every gallon of gasoline - a little more won't hurt (it'll make the saw smoke a little), but never use less. Always shake the gas can just before you refill your saw's tank - shaking helps make sure the oil & gas are well-mixed.
Mar 13, 2013 | Garden
I have a bosch ake 4o Chainsaw I live in Crete what no oil do I use, I cannot get bosch biodegradeable oil Here
sae 30 will be ok in the oil tank to lubricate the chain, most manufacturers will recommend bio oil as we live in a green age, mineral chain oil has a non fling addative so as the oil lubricates the bottom of the bar where most cutting is done and not just fly off the end of the bar.
Nov 22, 2012 | Garden
What Oil is used for the bar & chain lubrication
Hi khipiercy...
You will use "Bar and Chain Oil" for your chain and bar lubricant...it is specially formulated to be used on chains and bars of chainsaws...
You can buy it at any Loews,HomeDepot, Ace Hardware, etc.
Please take time to rate me
Sep 22, 2011 | McCulloch Garden
Not sure what kind of oil for the chain to use? 10w30?
Chain oil is usually much thicker and has an anti fling addative, if you use too light an oil it will just fling off the end of the bar and not lubricate the bottom of the bar where most cutting is done, if you cannot get chain oil use as thick an oil as you can get.
Aug 27, 2011 | Garden
Where do i purchase chain saw oil for electric chain saw
Hi
It would be helpful to know where durban is. In most parts of America "Bar Oil" is available at many hardware stores, and certainly at any chain saw dealership.
Oddly enough, many "Green" aware saw operators are now using vegetable oil as a lubricant. So Canola oil, Corn oil, or any other fairly thick, heavy vegetable oil will work fine.
The oil is pumped onto the bar at the top of where it exits the motor housing, and then circulates around the bar. Much of it is lost on the first pass the chain makes through the wood. This is carried away in the chip stream coming out of the cut. On many gas saws, you can see oil being slung off the chain when you rev the motor up.
The green feeling is, all this oil is left where we cut. Are we leaving a biodegradable oil behind? Or a contaminant that will take years to degrade.
See also:
http://www.fs.fed.us/eng/pubs/html/98511316/98511316.html
Stay safe, keep the blade sharp - use the protective gear as directed.
HF
Feb 13, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
Need service manual for Homelite 16'' electric chain saw model UT 41320. Motor runs but chain stopped in middle of second cut.
chain is too tight on the bar or is lacking lubrication oil. loosen up the bar nuts and back off the chain tensioning screw a touch. make sure the bar oil reservoir is full and the chain is receiving oil when its running.
Oct 20, 2009 | Homelite Garden
What type of oil I use
The Remington manual for model 111409-01 states: "This Pole Saw requires lubrication only to prevent rust on the guide bar and saw chain. The saw chain provided is pre-lubricated at the factory. With each use of the Pole Saw apply a small amount of lubricating oil directly to the saw chain (see Figure 8). The oil will distribute itself around the chain and guide bar groove during use?preventing rust. We recommend using SAE #30 motor oil for lubrication and rust prevention."
Aug 08, 2009 | Remington Polesaw Wizard
Lubrication
The cap on top with the bulb, screws off. Use bar oil. Give the bulb a pump every 30 seconds of operation or so. This will keep your chain and bar lubricated.
Regards, --WoobieDog--
Jul 10, 2009 | Remington Electric Pole Saw
Chainsaw chain won't move on 16" Homelite bar
Sounds like th clutch brake is engaged. Try Pushing firmly foward on the hand guard in front of the handle. It should click to release the clutch brake.
Let me know if this helps.
Dec 29, 2008 | Homelite Consumer Products 9.0 Amp, 14 In....
Husqvarna Chain Saw 20" Bar Logo
363 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
