Question about Goldstar GW-HD5000 Window Air Conditioner
I can not get any power on my Goldstar wg6005r window unit.What is wrong with it?
  • 2,272 Answers
Check out this possibilities:--
1) First of all Confirm  that the power cord is securely plugged into the electrical outlet and that the power switch is in the "On" position.
2)  Plug another device into the electrical outlet to ensure it is working. If the other device does not work, check the fuse box for a blown fuse or tripped circuit breaker. Replace the fuse and reset the circuit breaker as needed.
3) The other possibility is the fault in the power supply board.On the power supply board there are some tiny electrical components.This components gets short and the power supply board stops working so there is no power on the unit.
In some cases the components needs replacement but in some cases the power supply board itself gets faulty.
4) In power supply board testing the board needs to be tested with multimeter and continuity tester to locate the faulty component on the board.If not familiar with this then its advisable to get it checked by local electrician familiar with this brand and model.
Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Posted on Jul 06, 2010
The copper coil had a hole in it and all the r134a leaked out. I fixed the hole but cant find a spot to add new r134a? My car is easy to add it too, I thought it would be similar? Its a LG window unit....
Hello, in order To charge freon into tne system you need to add piercing valves to the low and high sides of the system. Here is a link to pierving valves http://www.apwagner.com/index.php?main_page=index&cPath=5_227
Jul 28, 2011 | LG Goldstar WG6005R Wall/Window Air...
When it's very hot, the cold air doesn't stay on long enough. It's fine in 80 degree weather, but it's 100 degrees now, and my little place is an oven, even with the thermostat set at 60...
This sounds like a low voltage problem .. you can check all your connections AFTER you shut down the power and tighen them all the way back to the breaker.. When electrical demand is high it is common for voltage will dropp. Hope this helps
Jul 23, 2011 | LG Goldstar WG6005R Wall/Window Air...
Can I add freon to a Goldstar window air conditioner
Hello, Thank You for using FixYa. I will be helping you today. The only time you add freon to an AC unit is if you find a leak and repair it! If its not cooling well you should just clean the front and rear coils.
Thank You and please rate my answer if it was helpful..
Jun 27, 2011 | LG Goldstar WG6005R Wall/Window Air...
Where is the drain plug on this unit goldstar 6500 airconditione
There is no drain plug,if it is not draining,then the drain holes are stopped up with trash and debris,remove the unit from the window,and take it out side,use a water hose to clean it out,and you will be fine,if this was at all helpful,please rate,thank you.
Jul 05, 2010 | Goldstar KG6000R Window Air Conditioner
Compressosr stays on for only 4-5 minutes but room is still hot
What do you what for 99.00 dollars ( kidding)
It sound like the stat is defected or the unit is short cycling ( air returning to the Unit ) will shut the unit off. Try running the Unit on a lower speed and sett the stat at the highest.
Jul 17, 2009 | LG Goldstar WG6005R Wall/Window Air...
Have 5000BTU Goldstar window unit. Water dripping
the bottom of the case from the outside usually has a "divot" in it below the coil to allow flow from the hose that runs across the bottom of the unit, try pressuring up and "blowing out" any obstruction, if this does not work then you may have to disassemble the unit and verify the drainpan is not cracked below the indoor coil (rare)
Jul 13, 2009 | Goldstar WG5000 Air Conditioner
GOLDSTAR AIR CONDICION (WALL UNIT) MODEL # BG8000ERY3
Download it from the manufacture webpage and the model #.
Sep 04, 2008 | Goldstar Heating & Cooling
Ac unit not powering / starting up
Did you try to plug a lamp into the same outlet as you have the A/C plugged into? It could be that you have no power at the outlet or the circuit breaker could be off or tripped. Something should run like the fan only position.
May 24, 2008 | Goldstar KG6000R Window Air Conditioner
Wiring diagram for a Goldstar A/C R6004
If you remove the cover it should be on a sticker in the control area. If it's unreadable you will need to contact the Goldstar.
May 19, 2008 | Goldstar R6004 Air Conditioner
Heating & Cooling Logo
42 people viewed this question
Top Goldstar Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
