Question about Shure SM58 Professional Microphone
Hi i cant set my microphones group or channel
    Prodigy:
    An expert who has answered 500 questions.
  • Shure Expert
  • 611 Answers
Look inside the battery compartment for the model number of the wireless system. Unfortunately, the SM58 is just the cartridge on the top and is used on nearly all Shure wireless systems. The model number might be under the battery and will be similar to PG2, SLX2, ULX2, etc.
Posted on Jul 22, 2010
  • 677 Answers
Hello,It all depends on the kind of mixer and microphone you are using.
Please describe the kind on mixer and microphone you are using so i can know how to help you out with a solution .
Hope you understand.
Posted on Jul 06, 2010
Canon 580exii speedlight, I want to only use the slaves, but they won't fire when I turn off the master
You didn't say what camera model you are using.
If you have 7D/60D/T4i you can have a total of 3 wireless ir flashes.
580EX II must be set at Master, say Group A & Channel 1
Two 270EX II must be set at Slave, say Group A & Channel 1
or
One 270EX II set at Group A & Channel 1
Second 270EX II set Group A & Channel 2
Then go into camera menu & turn off Master flash & turn settings for those two flashes.
Send me a email, then I can help you much better.
atdlee@netzero.com
Nov 17, 2012 | Canon Speedlite 580EX II TTL Flash
How do I reset the channel and group on my SHURE SM58?
The easiest way to change the microphone is to sync it to the receiver.
Jun 03, 2011 | Shure SLX Series Wireless Microphone...
Need hep programming a new uniden bcd396xt scanner
Unfortunately, you didn't specify if you needed assistance with programming digital or conventional radio systems.. but here is the info for conventional systems. Since a conventional system is really a collection of frequencies, the first thing you need to know is the frequency for each channel you want to program.
  1. Go to the Program System menu and choose New System .
  2. The scanner will prompt you for the System Type. Select Conventional .
  3. When the scanner prompts you confirm, tap YES .
  4. The scanner creates the system with a default name. Select Edit Name if you want to change it.
  5. If you need to change any of the system properties, you can do that now. Unless a property is Required , you can operate the system without changing the default settings.
Create at least 1 channel group Each conventional system can contain up to 20 channel groups, and all systems must contain at least 1 channel group.
  1. On the Program System menu, select the system you just created.
  2. Go to the Edit Group menu and select New Group .
  3. If you need to change any of the channel group properties, you can do that now. Unless a property is Required , you can operate the system without changing the default settings.
Create at least 1 channel in each group Each conventional system can contain up to 1000 channels in each group, and all groups must contain at least 1 channel.
  1. On the Edit Group menu, select the channel group you just created.
  2. Go to the Edit Channel menu and select New Channel .
  3. Input the frequency for this channel in MHz.
  4. If you need to change any of the channel properties, you can do that now. Unless a property is Required , you can operate the system without changing the default settings.
Mar 04, 2011 | Uniden BCD396T Handheld Scanner
Model: PGX2L5644-662MHz. Its causing a loud sound as if its lost or is loosing frequency even if I am standing with the mic close to the reciever. The ready light comes on and also the signal light when I...
Reset the channel/group on both the mike and the reciever. Shure reuses frequencies by groups so if the group is different, but the channel is the same then you aren't on the same actual frequency.
There should be an auto-set option on the recievers display as well as the mike. Turn them both on, and then just hold the mike up to the reciever so that the little IR window can see the reciever and the 2 with sync together.
If they are both on the same group and channel then turn the mike off, and adjust the squelch control until static is heard, then turn it back until it just goes away.
Feb 28, 2011 | Shure LX2 / Beta58 Microphone
NT1-A just stopped working, Any ideas?
It could be caused by a range of things. but before blaming the mic, try a few things first.
To test it is actually the mic that is broken, and not any of your other gear, try using your current set up with another condenser mic. If this works, your mic is broken.
If you dont have another condeser mic available to you, try, one by one, replacing the cable, and changing the input channel on your mixer/interface.
When you try a different channel, choose an input that is on a different Phantom selector than your current one (most mixers/interfaces of 8+ channels will let you apply phantom to a group of channels, instead of all). If your mic works then, it could be an issue with your mixer's phantom power.
If all the above fails, then you should still be covered by Rode's 10 year warranty, provided it is not caused by missuse/misshandling (http://www.rodemic.com/warranty.php).
Nov 16, 2009 | Rode NT1A Professional Microphone
How do I program the frequency of transmission on the mic?
Some of these have a body cover that just unscrews off, and expose a set of rotary channel and group selector that you can turn with a small flat screw driver. Match to the new numbers letters on the receiver. If it is the LED type you just need to hold the ch or grp button down until the display flashes then just toggle through the codes.
Jul 27, 2009 | Audio Technica ATW-T52 Professional...
Receiver is making a humming noise when turned up
your mic is misup that happein to my mic to so get i new one !!!!!!!!!!!!!!!!
Apr 14, 2009 | ElectroVoice Electro Voice RE-97TX...
We've got a signal on the mg32fx14 mixer from the microphone. There is no sound from the speaker. We tried the Group out there is no sound. So where do we connect the output from the backpanel of the mixer...
mg32fx14 monitors intermitently cut off, smoke comes out the back . aux 2 changes aux 1 and aux 2 at same time. 1 channel will over drive then change channels without changing enything else and its ok eny ideas or do i have a boat ancor
Apr 02, 2009 | Yamaha Mg3214fx 32 Channel Mixer With Fx...
Sb-600 and d80 sync, connecting, off camera..
  1. On the SB 600, activate the custom settings menu by pressing the ZOOM and '-' buttons simultaneously for a few seconds.
  2. In the custom settings menu, set the Wireless Remote Flash option (indicated by a curled arrowhead) to 'ON' (use + and - buttons to toggle between options)
  3. Set the flash mode to Master (do not set it as AA or A)
  4. Press Mode button and select one of the four channels available (ensure that you set the camera also on this channel)
  5. On the D80, from custom settings menu, select Built-in-flash
  6. Set the built-in-flash to '--' if you do not want the flash to show up in the scene
  7. Set the mode of the group to i-TTL (this menu can be used to control multiple flashes in different groups. since you are using only one remote flash, select the group you have set in the SB600)
  8. Set the channel to the same as in step 4
Now you are ready to use the remote off-camera flash.
Jan 24, 2009 | Nikon Speedlight SB-600 TTL Flash
Shure SM58 Professional Microphone Logo
32 people viewed this question
Top Shure Audio Players & Recorders Experts
Ben Armstrong
Vito Vacirca Jr.
Jerry Greenberg
Jerry Greenberg
Are you a Shure Audio Player and Recorder Expert? Answer questions, earn points and help others
