Question about Ranger Communications RCI-6900F-25 CB Radio
How do I remove the timing belt cover on a 1995 ford ranger?
I need to change the timing belt and have everything off except the timing belt cover. I removed the single screw and unclipped all the clips but there is not enough clearance for the cover to come out.
    Problem Solver:
  • 5 Answers
Try lowering or raisin the motor
Posted on Jul 26, 2010
How to set the timing mark on a crankshaft for a 1997 Ford Ranger 2.3
u can find the answer here: http://autorepair.about.com/----------------------------------------------------------------------------------------
NEXIQ 125032
Feb 02, 2013 | 1995 Ford Ranger Supercab
Engine Timing marks on a 4.0 ford ranger on a 2005
Rotate the engine so that No. 1 cylinder is at TDC on the compression stroke. Check that the timing marks are aligned on the camshaft and crankshaft pulleys. An access plug is provided in the cam belt cover so that the camshaft timing can be checked without removal of the cover or any other parts. Set the crankshaft to TDC by aligning the timing mark on the crank pulley with the TDC mark on the belt cover. Look through the access hole in the belt cover to make sure that the timing mark on the cam drive sprocket is lined up with the pointer on the inner belt cover.
Nov 02, 2011 | 2005 Ford Ranger
How 2 change timing belt 4 cly
7cb50cb.gifRemove timing belt cover to get to timing belt, it's not that bad, you will need a harmanic pulley puller.
Jun 29, 2010 | 1991 Ford Ranger Supercab
Changing water pump on ford ranger w/AC. 3.0L
b y removing the timing belt cover and all the belts.
Mar 10, 2010 | 2001 Ford Ranger Regular Cab
How to change timing belt on a 1987 ford ranger 2.0L 4C 5speed
You need to get a manual. Try the Haynes manual for your car. Try autozone; generally available for around $20. This is not the type of thing that can be covered here in enough detail to do you any good.
Buy new timing belt. Disconnect negative battery cable. Remove timing belt cover. make sure cylined #1 is set at TDC. making sure all componets are properly alligned and losen tensioner to remove old timing belt. Install new timing belt. Tension belt, ensure all components are alligned properly, replace timing belt covers and reconnect battery.
Feb 21, 2010 | 1987 Ford Ranger
Timing belt broke on a 95 ford ranger.new belt
you have to line up the two marks on the gears and set the tension to the correct setting. then check the marks again. trial and error. i just did my timing belt on my ranger haha
Feb 18, 2010 | 1995 Ford Ranger Supercab
Camshaft timing mark crankshaft timing mark
Belt covers need to be on. Timing mark on crankshaft (while on compression stroke) should line up with TDC mark on cover. then Camshaft mark, needs to line up by looking through access hole of cover, and align mark on cam sprocket with pointer on inside of belt cover.
Oct 22, 2009 | 1987 Ford Ranger
1995 ford ranger 2.5 L engine,finding all the timing marks on the sprockets to set timing belt
I have your information and pictures just need your email address to send the pictures and info.
Aug 25, 2009 | 1995 Ford Ranger Supercab
95 ranger 2.3l spark knock problem
Is this a manual trans in this truck, if so, try shifting down a gear. But yes a timing belt could cause this, but usually they wont run very well if the timing belt is that bad worn.
Jul 03, 2009 | 1995 Ford Ranger Supercab
Ranger Communications RCI-6900F-25 CB Radio Logo
42 people viewed this question
Top Ranger Radio Communications Experts
AnyMHz.com
AnyMHz.com
Jon Piercy
Mike Charette
Are you a Ranger Radio Communication Expert? Answer questions, earn points and help others
