Question about Tomtom GO 510 GPS Receiver
HOW TO FIT BATTERY INTO 510 TOMTOM SAT NAV - Tomtom GO 510 GPS Receiver
  • Anonymous Apr 12, 2009
    how do you fit a new battery in a tomtom 510 satnav
I have a tomtomgo700 and need to change battery please help
Posted on Nov 28, 2008
FITTING TOMTOM BATTERY
Posted on Oct 06, 2008
My tomtom go 510 will not charge in car but ok at home
The Car chargers are generally the defective unit.
I have also faced a similar issue as the spring loaded cigarette lighter was pushing the charger causing it to disconnect.
Jul 31, 2016 | Tomtom GPS
Iwant to download truck routes to my tom tom 510
Just go to the tomtom website (see below), and find the desired map (update) for your device.
https://tomtom.com/en_gb/sat-nav/maps-services/shop/travel-map/
Dec 31, 2015 | Tomtom GO 510 Car GPS Receiver
TOMTOM 510 SAT NAV
honestly there is no way to fix battery, as the units are not designed to be opened. if the unit is in waranty contact tomtom for replacement, it not there is not too much that can be done
Apr 25, 2008 | Tomtom GO 510 GPS Receiver
TomTom 510 Sat Nav
Most likey its not worth fixing. Look at it like this. While it may have only been 6 volts versus 5. One volt in a 5 volt system is a 20 percent increase.
If you took something that ran on 120 volts and plugged it into a 144 volt source you can figure the damage that would do.
Mar 22, 2008 | Tomtom GO 510 GPS Receiver
Tom tom go 510 Sat Nav
leave on charge for two hours, then with the SD card out hold down the reset button at the back of unit for ten seconds and then the 'on' switch for ten seconds.
STEP 1
Connect your TomTom to your
computer True True (``````````` (``````````` 0 95250 95250 clip_image002.gif via USB and open up your Windows Explorer and go to the drive. (It will be listed as TOMTOM (E) or some other drive letter).
Copy the Yellow Folders one by one to your PC. Ideally, save all the folders under a new folder that you name.
You may find that the folder ttntools and gns may not be copied. This is o.k. if they aren't.
STEP 2
Format your Tomtom via MY Computer.
STEP 3
Copy the Yellow Folders from the
backup True True (``````````` (``````````` 0 95250 95250 clip_image002.gif you made in STEP 1 back to the TomTom.
STEP 4
Open TomTom Home
Click on Upate Now.
Install the latest update onto your TomTom.
Once installed, switch your TomTom off, then disconnect if from the PC.
Thats it. From now on, make a full backup using TomTom Home prior to any updates.
Also note, that copying all the files will take some time.
Jan 25, 2008 | Tomtom GO 510 GPS Receiver
Tomtom300 gps mains charging +
1= My battery is flat, but when i put it on charge in the house it doesnt charge and no green light comes on, on my sat nav why would this be?
Could be your house charger is bad or the power connector on the back of the Tomtom is bad.
2= But when i put it in car charge it works perfect 'Y'?
You are using the "power shoe" to charge the battery. For a test unplug the power cord from the power shoe and hook it to the back of the Tomtom. If this work then the house charger is bad. If this doesn't work then the Tomtom rear power connector is bad
3= If ever i have to change battery how is this done?
You will have to remove the faceplate and disassemble the Tomtom in order to get to the battery. Or you can find a shop that repairs small electronic. Find the battery on Ebay.
Jan 12, 2008 | Tomtom GO 300 GPS Receiver
TomTom Home does not recognise device
Have you created a TomTom account? For each device you own it needs its own e mail address which it links to and you need to be logged in when you plug in your Tomtom.
Oct 22, 2007 | Tomtom ONE GPS Receiver
TomTom ONE
uninstall tomtom home from your computer & restart, then reinstall it from scratch.
This should fix it.
http://www.tomtom.com/support/support.php?ID=2
Jun 20, 2007 | Tomtom One Europe v2 GPS Receiver
Frozen tomtom
Is there a reset button? See this from PocketGPSworld.com: Reset hole The Reset hole is hard to find, you need to first remove it from the mount, turn it upside down, and within the mounting base area of GO you will see two interface slots (currently only one is being used) and towards the front of the unit on the base you will see a little hole marked reset. This is just like soft resetting a Palm or Pocket PC, it requires something small like a paperclip, and nothing was supplied with GO to enable you to easily reset the device.
Feb 25, 2007 | Tomtom GO 510 GPS Receiver
GPS Logo
539 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
