Question about Cell Phones
The normal reset code does not want to work on my nokia 6000.. Any help?? p.s i need a hard reset
  • 43 Answers
Try this code*#7370# after that you put security code for nokia 12345 or try this code *#8777#
Posted on Jul 06, 2010
Forgot my security code n i dont know how to reset it
Option 1, How to Hard Reset Nokia E7 with Software Menu:
  1. Turn On Nokia E7
  2. Go to Menu: Menu > Settings > Phone > Phone management > Factory settings > Delete data and restore
  3. Nokia E7 will ask the default security lock code is: 12345
  4. The rest will do by itself to master reset Nokia E7, this process will erase or wipe all important data
#Option 2, How to Hard Reset Nokia E7 with Hardware Button Combinations Key:
  1. Before doing the master reset and format Nokia E7, you have to backup any important data
  2. Battery Nokia E7 should full charge
  3. Turn Off Nokia E7
  4. Press and hold together: Volume Down Button key + Camera Button key + Menu Button key, after that continue with press Power Button (do not release the first three button)
  5. The process will do format to factory default Nokia E7
#Option 3, How to Hard Reset Nokia E7 with Secret Security Code:
  1. Make Sure Nokia E7 is already charge properly
  2. Turn on Nokia E7
  3. Press at Dial pad: *#7370# and wait
  4. Nokia E7 will ask for default security code, enter: 12345
  5. Nokai E7 will do format to factory default
How the Right Step to Flash and Restore Nokia E7 Unlock?
Have a good smartphone should know how to restore especially while the smartphone of Nokia E7 got problem. First step is do the soft reset first, if the Nokia E7 still get the problem, second try by doing the hard reset or restore to factory default with some options step above.
What should I do to Fix forgot or Lost Password of Nokia E7 Default Security Code?
If you never change the Nokia default security code is 12345, maybe sometime you every change the default security code and you forgot what you have change, in this case you have to go to nearest authorize service center for repair Nokia E7.
How to Restore Clean Setting at Nokia E7 Reinstall the Operating System?
Restoring the Clean setting of Nokia E7 can be done with doing the soft reset without delete any important data. If you want to reinstall clean operating system for Nokia E7, this can be done with doing the hard reset, but your data important will be deleted.
Help for Slow Respond Nokia E7, How to Make Nokia E7 Run Faster?
It will hurt to use slowly Nokia E7 smartphone, maybe it have a lot of applications or you ever try to setting the Nokia E7 with wrong way. This problem can make our Nokia E7 running slowly, so to make Nokia E7 run faster, you can try to do the soft reset and also hard reset. It depend on what the main problem with your Nokia E7.
How to Fix Forgot Nokia E7 Pin or Password ?
If you assign a pin or security password for Nokia E7 and forget about it, you have to do the hard reset of Nokia E7 with step above
The information from this page describe about nokia e7 hard reset,hard reset nokia e7,how to hard reset nokia E7,how to format nokia e7,how to reset nokia e7,e7 hard reset,hard reset e7,nokia e7 format code,nokia e7 hard reset button,how to unlock nokia e7 security code. If you need another resource for hard reset, use search function at this homepage or find from our related posts.
Mar 23, 2014 | Nokia E7 (16 GB) Smartphone
Huawei M835 low storage notification
From http://www.hard-reset.com/nokia-n70-hard-reset.html
Nokia N70 hard reset
You can format your Nokia N70 device by typing: * + 3 + call + Power on. Before the device is reset, you need to provide the lock code. The default lock code is 12345.
If it is not working try this code:
You can format your device by typing *#7370# in standby mode. Before the device is reset, you need to provide the lock code. The default lock code is 12345.
Some Nokia phone can be reset via this menu option
Press menu button or enter Menu > Settings > Phone > Phone management > Factory settings > Delete data and restore > YES
Jan 01, 2013 | Huawei M835 Ideos
I want to reset my n70 but fogot my lock code
Jan 01, 2013 | Nokia N70 Cellular Phone
How to hard reset nokia 5130
You can reset it using a soft or hard reset. The following instructions provide you with information on how to reset the Nokia 5130 using both methods.
  • Soft Reset
The soft reset is often the better option if you are worried about losing data. There is a chance the soft reset will also default to the factory settings, but there is a bigger chance that it will not. With a soft reset you will enter in *#7380#. This tends to clear any pending errors and on most phones it will help your phone work properly.
  • Hard Reset
  • The code for Hard Reset is *#7370#. Enter these digits into the phone and press yes to confirm. This will start the initialization process. Make certain you have already saved all important data. You do not want to lose your contacts, memo, or other information due to a hard reset. You may have issues with a Nokia phone that is not turned on. If there are problems such as these you can try hitting three buttons simultaneously. Hit the +*+3. If you can hit these three buttons all at once you may be able to get the phone to turn on, and then you can go through the hard reset with the proper codes.
These codes work with all of the Nokia models including the 5130. You may find other options do exist such as the power button while pressing the space key and delete key, and caps/ shift button will also hard reset the phone.
It all depends on whether or not the *# keys work. Sometimes they won't work if the phone is in phone lock or key pad lock and you need to get it open first.
Oct 02, 2011 | Nokia 5130 Cellular Phone
Need to reset security code for nokia 1110i
the normal code for nokia is 12345
if that does not work the website bellow has a lot of tools to help you find the master password for your device
http://www.peters1.dk/unlock/nokia/online.php?sprog=en
Mar 11, 2011 | Nokia 1110 Cellular Phone
Nokia 6300 security code reset (master code)
imei:353215034660040
i forgot my security code and i want to reset my code so how can i?
Jul 13, 2010 | Nokia 6300 Cellular Phone
Hi I wanna rest.factory settings but it needs security code to do so. I don't know its security code. please help me out to solve it.
the problem can be solved.Before you type in the factory reset code, did you use another code?, because if you have used another code for the phone the normal reset code for Nokia phones will not work for the phone.
The normal reset code for Nokia phone is (12345).So you can try it and if when you try it and it does not work, that means you have applied another code.
If you applied another code for the phone, you will need to still type the code first before you can now change security code and apply the normal Nokia default code.
Have a nice day.
Mar 16, 2010 | Nokia 6500 Slide Cellular Phone
Help! I need a Nokia Unlock code for a Nokia 6233 IMEI 353927015882365
Hi im Rain .
Ok here is the soft reset code. This will reset the phone and save your data.
Soft reset code: *#7380#
Turn on phone and enter that code.
Now if that will not reset it , you may need to do a hard reset.
To do a Hard Reset enter this code : *#7370# and press yes.
This will restore Phone back to factory settings. All data will be erased. Pictures , music , and anything else you may have stored on the phone.
I hope this was of help to you.
Dec 24, 2009 | Nokia 6233 Cellular Phone
PSC 6000 Plus not scanning
There are a few questions:
What kind of cable do you use?
USB, SERIAL, PS2
What kind of computer?
Normal computer or Laptop?
Then...
When you recieve the scanner like new you always have to program it.
First you do
Reset to factory defaults.... Never do this with working scanners
then
you have to program it.
First the Connection type
and then if needed a computer type.
After that you usually have to scan a suffix.
This means when you scan a barcode it needs to do something after.
normally it doesn't give Enter after you scan.
That is what the suffix is for.
and then you scan additional symbologies to scan
Like Code 39, UPC A etc. etc.
It needs to be programmed with the manual you recieved.
if you don't have it you can download here.
http://www.scanning.datalogic.com/sitefiles/manuals.aspx
go down in the list to quickscan 6000
and programming manual.
please don't print all the pages. only what you need.
If you need more help i will hear it.
good luck.
Jan 09, 2009 | Datalogic QuickScan® QS6000 Plus...
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
