Question about Fedders A6X05F2G Wall/Window Air Conditioner
WHERE CAN I FINE A USED FAN MOTOR FOR MY A6X05F2G-A FEDDERS AC GOOD LITTLE UNIT JUST CANT SEE BUYING A NEW MOTOR FOR IT
Saigua
  • 981 Answers
SOURCE: FEDDERS D CHASSIS A6D24E7A
Oh, the compressor motor's borked or overworked and overheating, or its capacitor failed short (perhaps the motor is shutting off from thermal shutdown...but you get to find out whether that's so. Be safe.) Alternately the temperature sensors have gone touchy on you. Once you gently vacuum it clean, try keeping incandecent bulbs in series with the compressor to get an idea of how loaded that thing is as it runs for those 5 minutes or so; the load might change more than you expect, just pay attention.
Hopefully you won't have to replace the compressor or motor; but it's doable if you're a certified technician with like equipment (so you can handle the refrigerant decently.) Most shops will streamline a bunch of similar jobs together to cut the waste and setup time.
Bigger conditioners are so much more efficient than little ones...syndicate the A/C?
Posted on May 30, 2008
  • 659 Answers
SOURCE: heat doesn't work on ac
You need to check if the heat strip is still good on it or that it is receiving power. If its getting power, then the strip is bad.
Posted on Apr 01, 2009
bobicehouse
  • 1524 Answers
SOURCE: need to replace seized fan motor
Fan motor has nothing to do with the refrigerant portion.
Posted on May 13, 2009
  • 534 Answers
SOURCE: fedder split unit
Your heat strip is burnt out . You will need a tech to come out and replace this heater strip due to the complexity of installation
Dave
Posted on Jan 09, 2010
Kinesky
  • 8 Answers
SOURCE: fedders window ac was running control lights
assuming that you have a reset button on the power cord and after pushing the button you dont hear a beeping sound, there's the possibility that your cord is defective. Check it with a volt metter at the end of the terminals.
Posted on Feb 03, 2010
I have a fedders window ac unit 110 model A6X06F2A works fine for about 10 mins the the fan stops
i would try to oil bearings on motor. that failing replace run capacitor. motor must be getting hot.
Aug 01, 2015 | Fedders Heating & Cooling
How to replace the blower wheel on a Fedders AC - Model AED24E7G
loosen and remove screws holding condenser in . carefully bend back to gain space.
Jul 29, 2014 | Fedders Heating & Cooling
Motor won't spin. Magnets inside motor are not working right! what do i need to do?
Assuming the electrical components are working (inside the AC unit) and the motor will not spin - the most likely problem is that the motor itself is bad and needs replacing.
There is a slight chance that the capacitor (small electrical device attached by wires to the motor) is bad and if it is - it will most likely be 'bulged,' in which case you might solve your problem by simply replacing the capacitor although this (as indicated above) is a remote possibility.
I would probably replace the motor or get a AC Tech to troubleshoot the unit.
Hope this has helped.
Aug 05, 2011 | Fedders A6X05F2G Wall/Window Air...
It runs awhile then beeps and shuts off
hello
Is the unit set for economy or on a timed mode?
If so, set it for cool .
Aug 29, 2010 | Fedders A6X05F2G Wall/Window Air...
My fedders a/c will turn on fine but after some minutes the fan will stop but the compresor will still work. i will haveto turn it off and turn it on again after 10 minutes and it will work fine again. but...
You need to replace you fan motor. It is going bad and the amount of amps to keep it going is causing it to over heat. The next time you try it and the motor kicks off see if the motor frame is hot. Be careful I have seen the hot enough to cook eggs. These motors can run between 68 dollars and 160 dollars. The age of the unit and your ability to replace the motor dictates a repair or a replacement. If you ck on the price of the motor and want to do it your self I will be happy to walk you thru it. good luck
Aug 26, 2010 | Fedders A6X05F2D Air Conditioner
Replace fan motor overheating fan is fyk-62s helix motor ltd
my ac motor no work at all is a FYK-62-S ,how much cost to buy a new fan motor?
Jul 30, 2010 | Fedders X Chassis A3X05F2B Air Conditioner
My AC unit wont blow the cold air.
if the ac outside is working, but not the furnace, means there is a control problem with the furnace, check wires in the furnace, make sure there is a blower wire plugged into the contact marked cool on the control panel of the furnace
Jul 09, 2009 | Fedders A&B Chassis A1A07W2B Air...
Need to replace seized fan motor
May 12, 2009 | Fedders A6P09S2A Air Conditioner
May 30, 2008 | Fedders D Chassis A6D24E7A Air Conditioner
Drain pan fills quickly
Can you descibe where the unit is located and what climate you are in? Thanks
Aug 09, 2007 | Fedders A6P09S2A Air Conditioner
Fedders A6X05F2G Wall/Window Air Conditioner Logo
44 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
