I have a goldstar air conditioner wg6005r that will not start at all. It was working normal and it just stop. It is 3years old.
    President:
  • 1,515 Answers
Hi if it just stopped, have you checked that the unit has power to it, no breakers that are tripped? Does this unit have a reset on the cord? If nothing is making a sound like it has no power, it probably doesn't. Check to see. It may have stopped on the high pressure switch tripping, but the blower motor would run, it would just blow hot air. You need to see if the plug has power also. It may have a short as these units draw a lot of amps, and will burn out a receptacle.Check all of these things and let me know what you find. It shut off for a reason, and it does sound as though it lost power somewhere. Look it over and keep me posted.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor. Please be kind when rating me. Thank you.
Posted on Jul 06, 2010
  • mrscashaw1 Jul 06, 2010
    I've checked the unit and I don't get anything from the test light or power.
  • Robert Horton
    Robert Horton Jul 07, 2010
    Thank you for the great rating. I am glad you were able to find that there is no power. I hope you found out why. I believe you did.
    Sincerely,
    Shastalaker7
The copper coil had a hole in it and all the r134a leaked out. I fixed the hole but cant find a spot to add new r134a? My car is easy to add it too, I thought it would be similar? Its a LG window unit....
Hello, in order To charge freon into tne system you need to add piercing valves to the low and high sides of the system. Here is a link to pierving valves http://www.apwagner.com/index.php?main_page=index&cPath=5_227
Jul 28, 2011 | LG Goldstar WG6005R Wall/Window Air...
When it's very hot, the cold air doesn't stay on long enough. It's fine in 80 degree weather, but it's 100 degrees now, and my little place is an oven, even with the thermostat set at 60...
This sounds like a low voltage problem .. you can check all your connections AFTER you shut down the power and tighen them all the way back to the breaker.. When electrical demand is high it is common for voltage will dropp. Hope this helps
Jul 23, 2011 | LG Goldstar WG6005R Wall/Window Air...
Can I add freon to a Goldstar window air conditioner
Hello, Thank You for using FixYa. I will be helping you today. The only time you add freon to an AC unit is if you find a leak and repair it! If its not cooling well you should just clean the front and rear coils.
Thank You and please rate my answer if it was helpful..
Jun 27, 2011 | LG Goldstar WG6005R Wall/Window Air...
Does not cool room.
Goldstar WG5000 air conditioners use an R22 refrigerant. A charge kit containing the gauges needed to properly fill the unit, and the refrigerant tank/cartridge can be purchased to fill the air conditioner.
Jun 03, 2010 | Goldstar WG5000 Air Conditioner
Compressosr stays on for only 4-5 minutes but room is still hot
What do you what for 99.00 dollars ( kidding)
It sound like the stat is defected or the unit is short cycling ( air returning to the Unit ) will shut the unit off. Try running the Unit on a lower speed and sett the stat at the highest.
Jul 17, 2009 | LG Goldstar WG6005R Wall/Window Air...
LG Goldstar GWHD5000 Starts only with Remote and Display buttons dont work
sounds like a bad switch or bad connections.  Recommend having a professional look at it.  Hope that helped.
Jun 11, 2008 | LG Goldstar GWHD5000 wall/window Air...
Cooling motor shuts on and off...
No it is not normal. You might have a bad capicator to the motor.
Is your unit still under Warranty? If so. Call the service center.
May 19, 2008 | Goldstar GW-HD5000 Window Air Conditioner
GOLDSTAR BG5200ER
Measure the temp of the air blowing out. It should be 20 degrees lower than the intake air at the filter. If not, we need to dig deeper.
Aug 14, 2007 | Goldstar WG5200ER Air Conditioner
Heating & Cooling Logo
22 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
