I bought an old Technics RS-M22 single cassette deck to play tapes to my computer. It worked great for several months. The last time I used it the tape speed seemed a litlle slow. The audio was not right. The drive belt seems to be in good shape. Does any one know how to adjust the tape speed. Thanks
I wish i knew the answer ..... i have the exact same problem
Posted on Nov 29, 2011
I can't find the manual to my Technics RS-TR272 Stereo Cassette Deck. How do you tape something on one cassette to another?
Place the tape you want to record into the left deck, Then the blank tape into the right deck. Press play on the left deck and record on the right deck.
It may be opposite depending on which side your recording deck is on.
Which ever deck has record, place blank cassette into that one and the cassette you want to copy into the other deck.
Hope this helps and please rate thanks
Mar 13, 2011 | Technics RS-TR272 Single Cassette Deck
Need to find user manual. I have a problem in recording a tape. I put in deck1 --- cassette to be recorded in deck2 new cassette start play on deck1 ... turn on record and play in deck2 as...
for a start your title says "Problem with the Technics RS-TR272 Single Cassette Deck"
So is it a single or double?
i'm assuming it's a double,right only one of the decks records so put the blank tape into it make sure the tabs on the top of the tape haven't been broke or you'll need to cover the holes with the labels you get with the tape.
put the tape with the music on it, in the other deck rewind them both then press "sync rec" & they should both set off.
Mar 01, 2011 | Technics RS-TR272 Single Cassette Deck
Technics RS-TR373 is chewing tapes
A lot of tape chewing problems are caused by the capstan roller being worn. Check for wear or oxide on that first.
Jan 18, 2009 | Technics RS-TR373 Single Cassette Deck
Connection between CD, EQ, SP technics
Each unit (the EQ and the Processor) should have left/right in/out rca jacks as well as L/R tape in/outs. The EQ or processor use the receiver's tape loop and then provide a tape loop to replace the one they've used on the receiver.
You plug the first unit (let's say the Sound Processor into your receiver/amp as if it were a tape deck (Processor's outs connect to reciever's tape ins (play) while the Processor's ins connect to the receiver's tape outs (record).
Then you chain the EQ off the Processor in the same way (EQ outs connect to Processor's tape ins (play) and EQ ins connect to the Processor's tape outs (record).
Last you connect the tape deck to the EQ as follows. Tape deck outs connect to EQ's tape ins (play) and the tape deck ins connect to the EQ's outs (record).
This will put both the Sound Processor and the EQ in the receiver's tape loop. In order to have all the receiver's source signals routed through them you may have to engage a Tape Monitor switch or button somwhere on your amp which will route the tape loop to your speakers.
Jan 09, 2008 | Technics RS-TR272 Single Cassette Deck
Remote control for Technics RS TR 272 Dual Cassette Deck
a system remote is the only option for you here. The deck does not have its own remote receiver. Sorry to break the bad news to you.
Tape shows playing but no sound
Is sound at the headphone socket?
Does the meter show audio output?
If the answer is yes to these questions check that the connections to the amp are correct and the amp is set up is ok.
Regards
John
Nov 25, 2007 | Technics RS-TR272 Single Cassette Deck
Help
Just connect you EQ to your receiver as if it were a tape deck: EQ's outs connect to receiver's tape ins (play) and EQ's ins connect to receiver's tape outs (record).
Then you hook the tape deck up to the tape ins and outs on the EQ: Tape deck outs connect to EQ's tape ins (play) and tape deck ins connect to EQ's tape outs (record).
This will put the EQ in your receiver's tape loop. To hear the EQed signal with all receiver sources you'll need to engage the 'Tape Monitor' button or switch which will route the tape loop to the speakers.
Nov 22, 2007 | Technics RS-TR272 Single Cassette Deck
Technics RS-TR272-no sound during play
CHECK CONNECTIONS AT THE BASE OF THE READ HEADS AS THEY HAVE A TENDENCY TO CRACK OVER A PERIOD OF USE. CAREFULLY STRIP BACK AND RESOLDER, REMEMBER TO LEAVE SOME SLACK AS THE HEADS REVOLVE ON TAPE REVERSAL.
Jun 09, 2007 | Technics RS-TR272 Single Cassette Deck
Technics RS-TR272 dual cassette deck
Ahh, Another Dual cassette deck. These are typically not worth a repair charge. I went looking for a service manual but Hi Fi Engine did not have one but they had a Owners Manual. Any unit that has a specification as to wow and flutter starting new at .18% was never made to be a long lasting deck of any quality. I don't like to be negative about people equipment but you might be better off getting a better deck from the start. If you think it is worth the repair, then send it to someone but I don't think you will want to sink $100 into a unit like this.
I am not saying it is unrepairable but that with what you come out in the end you could have made a better choice for a deck to buy.
It is probably a bad solder joint or bad capacitor on the circuit board.
I am in Chicago and would look at it for you if you want.
Televison & Video Logo
208 people viewed this question
Top Televison & Video Experts
