Question about Epson Stylus RX425 Multifunction All-In-One InkJet Printer
I have an Epson Printe RX 420 and now an E has appeared while the green lights go on and off. What to do? many thanks, Yvano
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 31 Answers
Power off printer.check for obstructions/foreign objects. remove obstructions/foreign objects. power on printer.
Posted on Jul 06, 2010
How to reset "needs service" on Epson Stylus Photo RX500 Printer?
it's all on my website's resetting page
http://www.the-inkstore.co.uk/frame/pages/Epson%20printer%20resetting.htm
But if you want the info right here and now, it's:
How to unlock your Epson RX500 printer
If your RX-500 printer has stopped printing and can't be reset, you will usually see either a steady red light or alternating red and green lights and the printer will not respond. There may also be a message in your computer status monitor saying "communication error" / "printer requires maintenance".
This is caused by built in software / firmware which counts the amount of prints you've made and stops when the protection counter reaches a predetermined limit, also giving the message that your ink pad is full. You will be allowed a certain amount of overflow prints to the protection topbutton1.gif counter limit, after which the printer will completely stop.
There is software online that will normally reset most Epson printers that have reached this limit and is used by Epson Service Engineers called SSC Service Utility (sscserve.exe), however this does not reset the Epson RX-500 protection counter / firmware.
All is not lost, you can manually reset the firmware using the following sequence of actions:
Close down all Epson programs
Exit all Epson printer programs that may be running in the background or on your task bar.
The quickest way to do this is to press Ctrl, Alt & Del on your keyboard and release, which will open your Windows Task Manager.
Click on [Processes] and a list of all processes running on your computer will appear, look for any in the list that say Epson, highlight it and select [End Process]. Carry this out for any Epson programs running.
Now to reset your printer.
Switch off the printer using the power button.
PRESS and HOLD all following printer buttons: Power, Load/Eject, Stop, B&W, Color and continue to hold until "Init eeprom" appears on the printer screen, then RELEASE ALL BUTTONS.
Next press the Color button to clear the protection counter.
Follow any other instructions given by the printer.
I know this will do it for you!
Glad I could help, just sending your friends and family to our site for ink will be thanks enough.
Kind Regards
Nige
Jan 04, 2013 | Computers & Internet
Epson r230 printer service required software free download
Resetter Printer Epson R230x Download ' Download Drivers
loadriver.com > Resetter Printe
Resetter Printer Epson R230x Download How to Perform a Reset Printer Epson ...epson r230 printer service required software free download; epson r230 ..
Sep 12, 2012 | Epson STYLUS R230 InkJet Photo Printer
I have a Epson Stylus All in one Rx 420 I am searching the drivers for Windows 7
From http://esupport.epson-europe.com....
...If your product is not listed, where available please download and install the Windows Vista driver from the Epson website...
Here is the link to the vista-drivers for your product
http://esupport.epson-europe.com/ProductHome.aspx?lng=en-IE&data=nKGrQtfEm6nklAFAU002FI5XulUnXahGGzFymQyp3UZx8RYU003D&tc=6
Jun 03, 2012 | Epson Stylus Multifunction Inkjet Printer/...
Printer head
Thermal paper uses heat to "write" onto the paper.
Normal paper is heat-resistant, and so it would be "blank".
Probably, you're OK. Try using thermal paper -- you've got nothing to lose, at this point.
May 31, 2010 | Epson C31C412144 Thermal Printer
RX 420 PRINTER WONT PRINT AS PAPER JAMMED WARNING KEEPS FLASHING
hi i hope i can help you? remove the cover from the machine and load paper as normal. and watch if the mechanics is sticking or anything that you can see give a clean with wd40clean all rollers check that you are puting in the correct amount off paper.check for loose connections.check for dirt on the switches.
May 04, 2009 | Xerox Phaser 8400 Laser Printer
FREE DOWNLOAD DRIVER Download CD Driver to install printer printer software i dont have driver printe epson LQ-300+
Hi...
Click me to get the driver that you need....
Please don't forget to rate....
Thanks for your support.
Happy Fixya....
Apr 06, 2009 | Epson Dot Matrix LQ-300+ Printer
Remot control dont working
dropping to a hard floor is always the reason when remote dont work.change the transmiter led or check some crack inside.clean the board and the rubber button with alcohol.
Oct 21, 2008 | Yamaha RX-V420 Receiver
Epson stylus d92 printer
I think that this "error"is due to an internal copy counter.
I have a Epson Stylus D68PE, and had the same problem.
I performed a research for a file to reset the internal counter, and I found a file "C67C68D68" that is an "EPSON ADJUSTEMENT PROGRAM", with different softwares for each type of printer.
after launch the program, and reset the counter, the printe work OK.
This counter is as similar as the counter of the laser copiers.
As you reset the chip on ink tank, after a specific numbers of print, you must reset the internal counter. By yourself, of by MAINTENANCE (very expensive) Good luck.
Sep 11, 2008 | Office Equipment & Supplies
Epson Rx420
Click Start - Printers and faxes
Right click on the printer icon and select properties.
Click on Advanced tab. Enable the option print directly to printer.
Click apply n OK.
Check for the result.
Dec 22, 2007 | Epson Stylus 1400 InkJet Photo Printer
Epson rx 420 comunication problem
But you install the software precisley as instructed? Remove all Epson software from the computer. Do a disk and registry clean. Come off line and disable the A/V software. Disconnect the printer Now reinstall from the disc and do exactly as the prompts. Epson is very fussy in installing .
Jul 12, 2007 | Epson Stylus RX425 Multifunction...
Epson Stylus RX425 Multifunction All-In-One InkJet Printer Logo
290 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
