Question about GE GTS22KBM Top Freezer Refrigerator
My ge GTS22KBMBRWW refrigerator freezer won't stay
My ge GTS22KBMBRWW refrigerator (approx 8 years old) the freezer won't stay cold long but when I slam the freezer door then the compresser kicks on things start to freeze but then shuts off but a fan keeps running but blows warm air in both the freezer and frig. Any clues? Fist time I ever had a problem with it.
    Problem Solver:
  • 11 Answers
If you (or someone you know is competent at soldering, you may be able to fix this without a pro (nor replacement part).
At the rear of the fridge is a metal panel at top left behind which is the motherboard. If the problem is intermittent - e.g., slamming the door yields a loud 'click' and you hear the compressor start, chances are great that the problem is a bad solder joint on the relay that switches between defrost and compressor modes. (It seems to default to defrost mode.)
Unplug the fridge!
Remove the metal panel. (1/4" hex wrench or socket set req'd.)
Gently and carefully (wiggle and) remove all molex connectors from the circuit board. (There'll be 5 or more, possibly depending upon how many extra features your fridge model has.)
Use a suitable tool - needle nose pliers or strong tweezers - to squeeze the plastic stand-offs with which the board is mounted to the fridge.
Remove the board from the fridge. (Note: it may be easier to remove the connectors at the right of the board AFTER the board is lifted off the stand-offs.)
Look at the solder-side of the board.
You'll almost certainly see charring around a particular solder joint that belongs to the large, sort of T-shaped relay (black box) on the board.
Clean up the carbon with alcohol.
Scrape away some of the (green) coating on the copper trace around the pin that comes throught the board from the relay. (This will entail removing some of the acrylic clear coat with which the board has been sealed.)
Resolder the joint.
Clean up any flux residue.
Reinstall the board - right-hand connectors first, if necessary (i.e., before mounting the board on the stand-offs).
Replace the metal panel.
Plug the fridge in.
Listen to that relaxing buzz of relief...(and $100-$200 savings).
CAUTIONS: 1) Make sure you NOTE and/or remember which connector goes where on the board BEFORE you remove it.
2) If the room is dry enough that you're getting static shocks when you walk across the carpet, you might want to make sure you discharge yourself (say, on the kitchen sink faucet) before you remove/handle the circuit board.
Posted on Jan 08, 2011
  • martinfinch4 Aug 28, 2011
    tried this solution - didn't work. Replaced motherboard - didn't work - need help
We have a GE GTS 222C top freezer refrigerator, approx. 8 years old. The freezer works fine but the frig doesn't cool and is at the highest setting. We had to turn the electricity off for some wiring...
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 23, 2010 | GE Refrigerators
Our amana refrigerator is a BX21TL. Serial # 9809197207. It is approx. 8 years old. The freezer wont stay cold enough? I would guess it approx. 35-36 degree's... Help...
First is the refrigerator running constantly, if it is then it is probably low on freon also check that all the door seals are good as this can keep it from freezing properly. If it is not running constantly but running and shutting of and restarting as it should normally then you may have a bad cold (temperature) control shutting it off before it gets cold enough. Also check that there is clearance for the air to flow around the outside of the refrigerator as the evaporator coil transfers the heat from the refrigerator. This evaporator coil is usually mounted on the back of the refrigerator and needs to have unrestricted air flow. Be careful of electrical shock while working on it. Always unplug first you only get electrocuted once no second try.
Oct 08, 2009 | Amana Refrigerators
GE GSS25LGM freezer not working. It's about 8
it seems like the thermostat on the freezer side is not function right but does the motor of the freezer run or not if not check thermostat
May 16, 2009 | GE GSS25LGM Side by Side Refrigerator
Can't find refrigerator coils/ cooling issues
There're two coils ,the condenser coil wich you already clean (also make sure the condensing fan motor works properly and the fan blades are also clean).The other is the evaporator coil wich is located inside the freezer behind the back wall cover.
Apr 21, 2009 | Refrigerators
GE side by side Refrigerator approx. 8 years old. Fridge side barely cold.
With your fridge, does the light go out when you shut the refrigerator door?
That could be your issue, that light running inside will create Alot of heat.
Also check to see if there is air circulating from the freezer to the fridge side through the damper. The damper is on the Fridge side left wall up towards the top. That is where the cold air gets to the fridge side. If that damper doesn't open that will also cause your problem, Let me know how you make out.
Bill
May 14, 2008 | Refrigerators
Refridgerator
check the condition of all the door rubbers.the fan motor could be running too slow or the defrost timmer is faulty.if all that does not solve it check the gas level and compressor efficiency.
Nov 05, 2007 | Refrigerators
GE GTS22KBM Top Freezer Refrigerator Logo
283 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
