Question about Kenmore 51562 / 51564 / 51569
WHERE IS THE WATER FILTER LOCATED ON A 2001 KENMORE COLDSPOT SIDE BY SIDE MODEL # 51564101 WITH ICE MAKER IN THE DOOR
    President:
  • 405 Answers
Check out this link, its a video that shows you how to replace the water filter.
http://www.youtube.com/watch?v=YRsvfaKABLI
Posted on Jul 06, 2010
I have a Kenmore Coldspot Side by side refrigerator model 58787892. The ice maker is not making ice. The mechanics of the maker work but it does not fill up with water. The filter is changed regularly...
check to see if the ice tube going into the ice maker is frozen up. you may have to thaw it out to get water to reach the ice maker again. lmk if that's not it
Aug 05, 2013 | Refrigerators
No ice is being made.
Most likely either water valve is bad or ice maker is bad. You would need to determine if Ice Maker is sending voltage to water valve. If it is, replace valve. If it's not, replace ice maker. Also be sure filler tube going through back wall is not frozen. If it is, replace water valve.
Sep 02, 2017 | Kenmore 22.0 cu. ft. Side-By-Side...
Kenmore coldspot water dispenser stopped working. Ice maker works. What could be possibly wrong?
On the rear of your refrigerator there is a dual water control valve. One side for ice maker and one side for water dispenser. I believe your side for the water dispenser has failed and they come as a set. Send the Kenmore model number and I will find you one. The number will look like this, 326.256489 for example only. Found near the bottom of the fresh food section door. Thanks, Sea Breeze
Nov 29, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker won't stop producing ice, even when bucket is full.
the arm that swing up and down maybe able to be ajst by bending arm and the water leaking down the icemaker. is it unlevel when if fills if not unlevel is it hooked up to an r/o system if it is when was the last time filter were replaced if not, does it have a water filter has it been changed lately.
Aug 20, 2009 | Kenmore 57029 Side by Side Refrigerator
Kenmore Coldspot Model 70162990 - not making ice
You've either got a bad timer on the ice maker or the water valve is defective. You need to verify that the timer is moving first. If it isn't try pushing in on the dial on the end of the ice maker. It is under the white square cover at the end of the ice maker, usually towards the door, but in some units it points to the left side wall. If it begins to run when you do that, then the timer is broken. If not then I would say that the valve is defective.
Feb 01, 2009 | Kenmore 53642 / 53644 Side by Side...
What size is this fridge?
there is a sticker some where inside that will tell you cubic feet
Dec 12, 2008 | Kenmore 53542 / 53544 Side by Side...
Ice maker won't make ice
The ice maker tells the water valve when to send the water on up. Replace the ice maker! goodluck!!!
Dec 16, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
ICE MAKER NOT WORKING Kenmore cold Spot model# 106.55536400
there is some times a water relay that turns the water on and off the over heats, it located in the back where the water connects
Dec 08, 2007 | Refrigerators
Kenmore 51562 / 51564 / 51569 Logo
441 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
